John 3:16
![]() Join Date: Jun 2009
Last week while riding my bike the temp. light came on. I had been running it really hard before that and it was like 95 that day. When it came on I was sitting at a stop sign so I figured it was a combination of both. When i got home I checked and the coolant was a little low. So i filled the reserve up. I rode today with no problems. But when I got home, and pulled in my driveway it came back on again. Checked the coolant and it was still on the full line. What could be causing this? It was only like 75 this evening.
Life Begins at 200 mph
Your coolant temperature sensor is probably going. It is like a 15 dollar part and screws into the radiator. When the temp hits a certain point it completes the circuit and the fan turns on.
Have you noticed your fan running as normal, or running less frequent? |
I see you have an 09 and yes you can have a fulty switch. It will be covered under warrenty.
I had mine go 2 weeks after I bought my ZX-12R and there was only 2700 miles on it. Found out it was an issue with the 00-02 bikes. They either went in the first 4000 miles or not at all. |
#4 (permalink) | |
John 3:16
#5 (permalink) |
Well it looks like you have an actual thermostat on that bike instead. so you may have to replace that.
From the Ron Ayers online microfiche. Parts found with Part Number: 49054-1067 Description THERMOSTAT Price $28.77 |
#6 (permalink) | |
When I had my problem the fan didn't run at all due to the sensor being bad. With you having a thermostat and the fan still running, I'm not sure what it is. Maybe it is not opening up and allowing the collant to circulate. Or it could be a water pump. If it is under warrenty take it to the dealership. Another thing check your oil level and make sure you are not too low. |
#9 (permalink) |
John 3:16
im gong to..well i dont know if they can get it in tomorrow but at least i can report the problem and schedule it in. i will ride it again tomorrow and if it comes on i will just park it until then.
#11 (permalink) |
Third Gear And Gaining
Did you check you oil level ? what bike do you have ? is it the old 1500 ? they had a plastic oil pump empeler that used to fail around 15000 miles and cause overheating and even engin siezed. There is a metal replacement for that and solved the problem of overheating.
#12 (permalink) | |
He has an 09 VN900 |
#14 (permalink) |
John 3:16
i rode it agan this morning around 60 miles and no problems. light never came on. i dont think anything is wrong or it would have overheated by now. when i changed the clutch cover i never touched the water pump or anything behind it. I did drain the coolant. i just wonder if maybe i got some air in the coolant system making it do that. becuase i rode all day in the heat yesterday and it didnt come one. then it did when i got home last night. and it was a lot cooler out by that time.
#15 (permalink) | |
#19 (permalink) |
Alf not Elf
Not to chime in late but you could have some air in the system that is affecting the water pumps ability to circulate coolant intermittently. Maybe someone with the service manual could chime in and tell us what it says about bleeding air from the coolant system...
When arguing with a idiot make sure he isn't... My bike 900 LT Red/Black. |
#20 (permalink) | |
The problem was corrected in production in 2000.
- Rich 2006 1600 Ultra-Classic Patriot Guard Rider Please put your bike year/model in your sig line or fill in your profile before asking for help. |
| Ways to drop your motorcycle | Freakinout | Main Lobby | 174 | 3 Weeks Ago 02:58 AM |
| 250 too slow? | brooklynyte | Kawasaki Streetbikes/Sportbikes | 39 | 09-25-2008 08:22 PM |
