Old 07-03-2009   #1 (permalink)
900LT
Finally Got Into First Gear
Default Is VN900 Front suspension adjustable?
The front suspension has normal travel and rebounds fully as it should, but it still seems soft. Is there any adjustment similar to the rear?
No leaks noted.
06' 900LT Black & Red
900LT is offline   Reply With Quote
Old 07-03-2009   #2 (permalink)
bobalu
Back in the saddle.......
bobalu's Avatar
The front fork is non-adjustable. You can, however, change the fork oil to a different weight to acheive some degree of adjustment.
2007 VN900 Classic
bobalu is offline   Reply With Quote
Old 07-03-2009   #3 (permalink)
RichLockyer
RichLockyer's Avatar
Heavier fork oil... factory fill is 10w20, which you will not find.
You can also replace the springs with Progressives... it'll soften it up a little at the beginning but get progressively firmed as it compresses and reduce bottoming out.
You can also increase the preload by going to longer spacers on top of the springs.
- Rich
2006 1600 Ultra-Classic
Patriot Guard Rider
I need front tube forks from VN900 classic ! Chelie Kawasaki Cruisers 5 06-09-2009 05:34 AM
vn900 suspension cisco6460 Kawasaki Cruisers 1 02-03-2009 02:51 PM
Adjustable clutch lever for VN900 Classic Rocket_88 Kawasaki Cruisers 2 12-01-2008 06:05 AM
VN900 Loose Front Tire Axle MLC Kawasaki Cruisers 2 10-08-2006 07:54 PM
Choppy Front Suspension TheShadow The Mechanics Corner 1 10-08-2006 02:52 PM
