Old 07-04-2009   #1 (permalink)
ky_paramedic
John 3:16
ky_paramedic's Avatar
Default Aftermarket Turn Signals
Anyone know of any aftermarket turn signals that look really good? i cant find any. prefer black but chrome would be ok. thanks
ky_paramedic is offline   Reply With Quote
Old 07-04-2009   #2 (permalink)
fritzi93
Thread Killer
fritzi93's Avatar
Not knowing your tastes, it's hard to say.
But here are a couple of outfits that offer aftermarket parts:
J&P*Cycles® - Keeping the World on Two Wheels!
Motorcycle Parts and Motorcycle Accessories for Cruisers: Honda VTX, Yamaha Roadstar, Kawasaki Mean Streak, Suzuki Volusia and more ...
I got a set of arrows for my 800 to make it easier to open my saddlebags. Got 'em from J&P. There are lots more vendors, no doubt you'll get more suggestions. Good luck.
fritzi93 is offline   Reply With Quote
Old 07-04-2009   #3 (permalink)
wild_deuce03
Yes it is this bad!
wild_deuce03's Avatar
Location: Wanted - Professional football team needed in Cleveland!
I've got some links at home that I'll get ya.
Go OHIO STATE!!! Beat Michigan!!!
wild_deuce03 is offline   Reply With Quote
Old 07-04-2009   #4 (permalink)
MFolks
Needs A Real Job
MFolks's Avatar
Try here:K&S Technologies
Mike Folks
MFolks is online now   Reply With Quote
Old 07-04-2009   #5 (permalink)
ky_paramedic
John 3:16
thanks guys for all the responses...has anyone went with aftermarket on a 900? on the front signals they are 3 wires and only 2 on the back. all the aftermarkets i have seen only have 2 wires. so what do you do with the extra wire on the front signals? i bought a pair on ebay that i really dont like and im looking for new ones.
Old 07-04-2009   #6 (permalink)
MFolks
Needs A Real Job
MFolks's Avatar
The third wire on the front turn signals is usually for the running light circuit. Use either a multimeter or a power source to determine which bulb element is brighter. This will probably be the turn signal element. The lower wattage element wiring can be cut back at the socket,or dead ended with tape.
Mike Folks
Old 07-04-2009   #7 (permalink)
ky_paramedic
John 3:16
when i hooked the ones i got now up. i just used 2 of the wires on the front. now my flashers are blinking faster then before. just trying to figure this out before i buy my new set.
Old 07-04-2009   #8 (permalink)
MFolks
Needs A Real Job
MFolks's Avatar
Additional lamps(lights) will make the older style flasher relays blink/flash faster due to increased heating of the internal bi-metal strip inside the metal can.
Changing to a newer electronic flasher should bring the blink/flash rate down in speed.I'd imagine most good auto parts stores carry them.
Mike Folks
Old 07-04-2009   #9 (permalink)
ky_paramedic
John 3:16
Sounds like i may be better off just to put the oem signals back on
Old 07-04-2009   #10 (permalink)
ky_paramedic
John 3:16
Hitting front turn signals jerkybear Kawasaki Cruisers 6 06-12-2008 03:27 AM
Self Cancellation turn signals bhanse Vintage Motorcyle Info 2 03-14-2008 08:38 AM
Flush mount/Integrated Turn Signals NinjaJeeper Kawasaki Streetbikes/Sportbikes 17 09-20-2006 01:21 PM
'77 KZ650 Turn signals Cowski Kawasaki Cruisers 5 04-12-2006 12:40 PM
500R aftermarket turn signals? dsauer608 Kawasaki Streetbikes/Sportbikes 4 02-06-2004 03:51 PM
