Old 07-27-2009   #1 (permalink)
broncoboy36081
Turtle Wax Taster
broncoboy36081's Avatar
Default 900 shifting problem
Ok i just changed the oil in my 900 and i was letting her warm up and checking for leaks. I didnt find any leaks but when i started to pull her in the garage i noticed that it was hard to shift from neutral to first and back to neutral! And now im getting a rough clunk when i shift any ideas where to start? thanks guys in advance
broncoboy36081 is offline   Reply With Quote
Old 07-27-2009   #2 (permalink)
VULCAN ACEHOLE
You hate me, & I hate you
VULCAN ACEHOLE's Avatar
What kind of oil did you use?
My mom told me, "If you cant get yourself a ten the least you could do is score five twos'.
VULCAN ACEHOLE is offline   Reply With Quote
Old 07-27-2009   #3 (permalink)
broncoboy36081
Turtle Wax Taster
Castrol 20-50 motorcycle oil
Old 07-27-2009   #4 (permalink)
VULCAN ACEHOLE
Is that different oil than before? Is the clutch sticking or just making a loud noise? How many miles you have. Have you checked you clutch cable adjustment? Mines a little louder than it was when I bought my bike but it isnt hard to put it in or get it out of gear after 9400 miles.
Old 07-27-2009   #5 (permalink)
broncoboy36081
Turtle Wax Taster
its the same oil as last time and it seemed to do great last time the bike has just over 10000 miles now and i dont think its the clutch cable but i havent checked it yet this oil change but even before i changed the oil it seemed to shift fine
Old 07-27-2009   #6 (permalink)
VULCAN ACEHOLE
I would check the clutch cable to be sure. If its not that Im not sure but someone here will be able to help out as soon as the see this thread (maybe RichL.).
Old 07-27-2009   #7 (permalink)
broncoboy36081
Turtle Wax Taster
yeah thanks for the help bro for some reason the gears r feeling sticky
kinda worries me a little
Old 07-27-2009   #8 (permalink)
VULCAN ACEHOLE
Thats the oil Im running so I dont think its that.
Old 07-27-2009   #9 (permalink)
ClarkeyBalboa
Can't find time to ride
ClarkeyBalboa's Avatar
Why are you guys running 20w50? Spec in the 900 is 10w40
Chris
07 900 Custom, Candy Plasma Blue
ClarkeyBalboa is offline   Reply With Quote
Old 07-27-2009   #10 (permalink)
broncoboy36081
Turtle Wax Taster
im in alabama so its very hot here the heat index can hit 115 easy and its still 90 degrees at night thats why i run 20w50
Old 07-27-2009   #11 (permalink)
ClarkeyBalboa
Doesnt get quite that hot where I am Hopefully you can figure out whats causing these problems, im not much of a gearhead, just figured i'd ask if there was a reason behind changing oil grades away from factory spec.
Chris
Old 07-27-2009   #12 (permalink)
VULCAN ACEHOLE
Its been up to 100F during the day and no lower than 63F at night and I ride out to Riverside county alot where it can be like 115F and 85F/90F at night.
Old 07-27-2009   #13 (permalink)
yo4joy
MIKE SR. 1963
yo4joy's Avatar
Bikes don't know a d a m thing about an index. It is what it is.
No PORK!
yo4joy is offline   Reply With Quote
Old 07-27-2009   #14 (permalink)
broncoboy36081
Turtle Wax Taster
The bikes dont know about index but the ambient temp around the bike a long with the heat coming off the asphault does matter. if the heat index doesnt matter neither should wind chill?
Old 07-27-2009   #15 (permalink)
V-Twin
VN 900 Classtom
V-Twin's Avatar
It gets pretty hot here in Texas too but I wouldn't use anything over 10-40. My first oil change I got the 20-50 and my VN900 became so loud that after like 500 miles I drained and changed to 10-40.
For me no more 20-50
and no more valvoline.
2007 Vulcan 900 Classtom
V-Twin is offline   Reply With Quote
Old 07-27-2009   #16 (permalink)
Ruger
Poser ProudŽ
Ruger's Avatar
+1
I went by the dealer and asked about the switch to 20W-50. He said they have had no problems even with the heat we have been having. He did show me the new 10W-50 that Kawa has. That is what I'll be going to on my next change.
2006 VN900 Classic -
Freedom of the press is limited to those who own one.
- A. J. Liebling
Ruger is offline   Reply With Quote
Old 07-27-2009   #17 (permalink)
broncoboy36081
Turtle Wax Taster
Ok the bike is still having that sticky and chunk when i put it in first gear idk what could be causing it! Sometimes it will go in fine and sometimes it will push down and the neutral light will go off but it is still not in gear
Old 07-28-2009   #18 (permalink)
spitfire9
Climbing for altitude.
spitfire9's Avatar
Mine always clunks like he|| going into first but then shifts like butter running through them. What- it's not supposed to? Okay, I do like my idle real high.
Did you happen to adjust that recently?
Kevin.
'07 Plasma Blue 900 Custom.
Aviation and history fanatic.
spitfire9 is offline   Reply With Quote
Battery or Charging problem with 900 bigdaddyeo Kawasaki Cruisers 8 07-26-2009 02:53 PM
2007 vulcan 900 electrical problem rnzgonz Kawasaki Cruisers 3 07-09-2009 11:17 PM
1985 Kawasaki GPZ 900 A2 - starting problem deepak Vintage Motorcyle Info 5 08-08-2008 11:10 AM
Newbie 900 Custom Debaffling Problem The Beast Kawasaki Cruisers 11 07-07-2008 01:07 PM
Bayou shifting problem scoobasteve Kawasaki ATV and Mule 2 11-05-2007 09:54 AM
