97 Vulcan Classic gas out the hypercharger
+ Reply to Thread
Results 1 to 5 of 5
Thread: 97 Vulcan Classic gas out the hypercharger
  1. #1
    Newbie glitch67's Avatar
    Join Date
    Aug 2009
    Posts
    2
    Default 97 Vulcan Classic gas out the hypercharger
    First post - Unfortunately with a big thorn in my side.
    I have a '97 Vulcan Classic 1500 with Kuryakyn Hypercharger and VH Longshots. Have had problems when trying to start it fuel dumps out the hypercharger/air cleaner. Pulled and cleaned the carb, checked the floats - seemed working properly, found a bad air cut valve diaphragm and replaced it. The rest of the carb seemed clear and in good shape. Put it all back together. Fresh gas. Pushed the starter, tried to fire once and then started dumping fuel again. Any suggestions?
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Nothin But Time BTK Intermediate ohiovulcan's Avatar
    Join Date
    Jan 2007
    Location
    Elyria,Ohio
    Posts
    211
    When did the problem start or was anything done to the bike prior to the problem
    Steve
    VROC #1899
    PGR Rider
    98 800 Classic
  4. #3
    Join Date
    Aug 2009
    Posts
    2
    Started in the spring. Thought it might have been a gummed up carb from over the winter. Thats why I pulled and cleaned it. But nothing seemed plugged or any signs of stale fuel.
  5. #4
    Needs A Real Job BTK Expert rfb92345's Avatar
    Join Date
    Aug 2007
    Location
    Hesperia, CA
    Posts
    2,344
    Check the bowl vent. If it goes to a carbon canister, that may be the problem. Not sure if all have the system. Disconnect the bowl vent hose and see if it cures the problem. If it does, you can replace the carbon canister........or just run a hose down to the bottom of the bike and chuck the whole system. That's what I did.
    '96 Kawasaki Vulcan Classic 1500
    "Happiness is a Colt .45...a cold one and a loaded one"
  6. #5
    recovering workaholic Forum Supporter bigjohnyeti's Avatar
    Join Date
    Feb 2006
    Location
    Holbrook,LI,NY
    Posts
    1,057
    Sounds like something stuck in the needle /seat area..the floats aren`t able to shut off the gas flow into the bowl. I had a similar problem years ago with a different bike, found a piece of rust stuck in the seat so the needle couldn`t close the inlet gas.
    If you can hook up a hose to the gas inlet of the carb try blowing into the carb. If you can blow air(lung power,not compressor) in with the float up all the way,then there is either something in the way,or the seat is bad. If you can`t,then maybe you just need to bend the tab to make the float shut the gas off at a lower level..
    Hope this helps,check back and let us know how you make out.
    By the way,welcome to the forum,and post up some pics of your bike-we all wanna see..
    One more thing- check that gas didn`t get past your rings and contaminate the oil..
    John
    `03 Meanie, `93 Electra Glide
    RIP my daughter Dawn. 5/10/69-12/29/2011. I will always miss you.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. 2006 Vulcan Nomad FI Light, Gas in Oil
    By rkilgor in forum Kawasaki Cruisers
    Last Post: 07-12-2009, 06:56 PM
  2. FS: Kawasaki Vulcan 800 Classic - $3200 obo (Chicagoland area)
    By Beknatok in forum Streetbikes Buy/Sell/Trade
    Last Post: 06-17-2009, 09:28 AM
  3. 07 Vulcan Classic to 07 Vulcan Ultra Classic. ;)
    By 9511234 in forum Kawasaki Cruisers
    Last Post: 06-11-2009, 08:09 PM
  4. Vulcan 800 Classic vs. Boulevard C50
    By buellwinkle in forum Kawasaki Cruisers
    Last Post: 02-25-2008, 04:21 PM
  5. Too much gas - flooding? VN800 classic
    By mightybhwk in forum The Mechanics Corner
    Last Post: 10-26-2004, 08:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
