Old 09-02-2009   #1 (permalink)
The Menace
Cruising In Fourth Gear
The Menace's Avatar
Default Thanks, Kawasaki!
I've been noticing the front brakes on my V2k have been pulsing for the last several thousand miles. Realizing the warranty is expiring in a couple of weeks, I took the bike to the dealer to have it checked out. Turns out the right rotor was out by .024 and the left was out .007. They called Kawasaki for me and they are covering the replacement of both rotors! If I was to buy them myself, they're $310 each. I will have to pay for the new pads, but I'm really happy about this.
Thanks, Kawasaki!
2007 V2K Classic LT
Phat risers, Bakup rest, Kawi engine guards, Kuryakyn highway pegs, Kawi rack
The Menace is offline   Reply With Quote
Old 09-02-2009   #2 (permalink)
TejasDevil
Drill here, drill now!
TejasDevil's Avatar
Nice to see a positive warranty experience. Usually we just hear the negative ones.
2007 Vulcan 900LT
TejasDevil is offline   Reply With Quote
Old 09-02-2009   #3 (permalink)
g1nomad
Sit speling cheker
g1nomad's Avatar
What do you mean by out? Where they wavy, and not flat the whole way around?
'08 Victory Vision, Silver
'05 VN2000 Kawasaki, Black
'02 GL1800A Honda, Black
'02 Bushtec, Black
g1nomad is offline   Reply With Quote
Old 09-02-2009   #4 (permalink)
wild_deuce03
Yes it is this bad!
wild_deuce03's Avatar
Location: Wanted - Professional football team needed in Cleveland!
$310 each........for rotors??? Someone want to tell me why rotors are so expensive??? Or is that including labor? Man, glad to know they covered it for you!!!
Go OHIO STATE!!! Beat Michigan!!!
wild_deuce03 is offline   Reply With Quote
Old 09-02-2009   #5 (permalink)
The Menace
The Menace's Avatar
Yes, they were not flat. One place was bent in toward the hub.
And the $310 per rotor is the price, sans installation. I would have installed them myself, if not covered under warranty.
They sure like their rotors!
2007 V2K Classic LT
Old 09-02-2009   #6 (permalink)
wild_deuce03
Yes it is this bad!
That's crazy!!!
Old 09-02-2009   #7 (permalink)
captain Rando
Vegas Vulcan
captain Rando's Avatar
I've found that Kawasaki sells their bikes for less but it seems their replacement parts prices are about double everyone elses. Babbitt's has those rotors listed for $264 and I think Beartooth would be cheaper. By comparison, a front rotor for a Honda VTX1800 from Babbitt's sells for just $119.
I am curious why they warped so quickly with your bike just being a couple years old. I've not had any issue with my 1600 but I use my rear brake more than my front. The 1600 and the 2000 use the exact same rotor.
Randall
2006 Vulcan 1600 Classic
captain Rando is offline   Reply With Quote
Old 09-02-2009   #8 (permalink)
The Menace
The Menace's Avatar
That's a good question. When my dealer called Kawasaki, the first thing the guy asked was had it been hit. There's been nothing abnormal to happed to my bike, just normal riding. It has a little over 18,000 miles on it. I have used my front brakes hard at times, but not long enough to cause excessive heat to the point of warpage, in my opinion.
I certainly hope I get better service out of the new ones. I was told this is a one-time deal, and they would not replace them again.
2007 V2K Classic LT
Old 09-02-2009   #9 (permalink)
2thdr
Workin' to ride
2thdr's Avatar
...The 1600 and the 2000 use the exact same rotor.
Maybe that's the problem. The 1600 dry weight is 675, but the V2K weighs in at 838! Maybe the V2K should have bigger rotors? Just a thought.
'09 VN900 Custom, Cobra Speedster Slashdowns, Kawi engine guard, gel seat, sissy bar/rack, shield.
2thdr is offline   Reply With Quote
Old 09-02-2009   #10 (permalink)
wild_deuce03
Yes it is this bad!
There's some nice service for ya. So if someone has an extended warranty when they buy the bike, rotors go bad in the first year , they get replaced and then if it happens again they won't replace them??? That sure sucks!
Old 09-02-2009   #11 (permalink)
rogue3
rogue3's Avatar
I know rotors on cars can be machined back to spec sometimes, is this a no-no on bikes?
2004 Vulcan 800 Classic (VN800-B9) 21k miles and counting
rogue3 is offline   Reply With Quote
Old 09-02-2009   #12 (permalink)
Utah Motorcyclist
Riding daily
Utah Motorcyclist's Avatar
I was about to ask the same thing...
Jared
1600 Nomad
VROC#26705
KawaNOW#01051
http://www.utahmotorcyclist.blogspot.com/
Utah Motorcyclist is online now   Reply With Quote
Old 09-02-2009   #13 (permalink)
rogue3
rogue3's Avatar
I know the answer anyway, I was just being retarded. Machining removes wear grooves but wont fix a warped rotor
Old 09-02-2009   #14 (permalink)
BrianTSmith99
Third Gear And Gaining
Some car rotors are thicker and can be "cleaned up". Some have a bevel on the outside rim to show how far they can be turned down. Some can not be turned at all (disposible). I think most bike rotors are too thin to turn. All disks have a minimum thickness after which they are not safe.
Brian
'08 Ninja 500
'85 Pontiac Fiero with 4.9l Caddy V8
BrianTSmith99 is offline   Reply With Quote
Old 09-02-2009   #15 (permalink)
V2KCruiser
*** V2K Rocks!!! ***
V2KCruiser's Avatar
kawasakipartsnation.com has the V2K rotors listed for $241 each. Even still that's pretty steep if you have to buy 2 of them.
2006 Vulcan 2000 Classic
V2KCruiser is offline   Reply With Quote
Old 09-02-2009   #16 (permalink)
k5d
Made It To Second Gear
one problem with turning bike rotors is the holes in the rotor when the cutting bit hits the hole it digs in deeper and screws up the rotor.i know because i tried it, so yes its a no no!
2007 900 classic lt
k5d is offline   Reply With Quote
Old 09-02-2009   #17 (permalink)
NewRoadie
Crazy Old Guy
NewRoadie's Avatar
I believe the Kawi rotors are more expensive than the Honda rotors due to the full floating capability. In other words, the rotor is two pieces-one that mounts to the wheel and the outer piece that 'floats' that is where the pads squeeze. Many rotors, including my brother's Harley rotors are one piece-i.e. cheaper to manufacture.
Bryan (Big B)
07 Vulcan 900 Custom
Candy Plasma Blue
VROC Member #27075
MRCA Member #90008991
NewRoadie is offline   Reply With Quote
Old 09-03-2009   #18 (permalink)
g1nomad
Sit speling cheker
g1nomad's Avatar
You know, I think I know what you are saying. Thank you. After all these years of reading reviews & specs on bikes, I never really knew what they meant by "floating". But I have also seen where the two peices are joined together with the little round peices. I don't know the advantage, but I might be a little smarter today, and I didn't even stay at a Holday Inn Express.
'02 Bushtec, Black
Old 09-03-2009   #19 (permalink)
The Menace
The Menace's Avatar
I've been told that bike rotors just don't have enough metal to be able to turn them.
I mentioned to my son, who's a mechanic, that it was out 24 thousandths, and he said when he turns car rotors, he starts at 2 thousandths on the first pass, then 1 1/2 thousandths on the second. That wouldn't have even come close to correcting my issue, even if possible.
2007 V2K Classic LT
Old 09-03-2009   #20 (permalink)
Vulcan900
Vee-Too-Kay
Vulcan900's Avatar
Had the same problem on the rear of my 900 while still under warranty. Kawi told me it was a wear item and I had to pay for repairs.
2006 VN2000 LT - Fire Breathing Dragon
2006 VN900 Classic - Mellow Kitten
Vulcan900 is offline   Reply With Quote
Thanks to National Cycle and Kawasaki padrel Kawasaki Cruisers 3 1 Week Ago 12:18 AM
Kawasaki can make you sick. Uncle Bob Off Topic 24 01-15-2009 03:00 PM
Original color of my 1973 Kawasaki F11 250 metalfab24 Vintage Motorcyle Info 20 10-01-2008 01:53 PM
***1600/1500 Classic/Nomad/Meanstreak/Maurader - Photo Contest*** Spok Kawasaki Cruisers 170 12-12-2006 06:12 PM
Kawasaki customer Mid-Ohio track day $99 extremelean Main Lobby 0 07-27-2006 09:24 PM
