Wants better weather!
When it is necessary to add coolant or change it out, what brand are you using, on my Honda cars I always use there brands of tranny fluid, coolant, p/s fluid, motor oil, brake fliud, different story. .
2008 Vulcan 900 LT Red/Black Cobra Highway bars, Cobra Light Bar, Scootsworks Front Pulley. |
Top Gear Full Throttle
I have used the store brands. If you have your manual look in there it will tell you the type. Cant think of what the regular type is called off hand. Go to the store and get that you will be fine.
Finally scrapin' boards!
Do you have to worry about silicates in the coolant? I know that the Honda that I had could not have silicates, or it would cause water pump failure w/in a few hundred miles. Regular antifreeze has silicates in it.
2006 V2K Limited - Marbled, Powershots, Power Commander III; Kuryakyn Pro Hypercharger; |
#4 (permalink) |
08 FatBob
Although that was true years ago (due to cast iron blocks/ heads and steel radiators) in autos. The coolants have changed over the years to acommodate Alum. blocks /heads and radiators that are now common in todays auto's and bikes. If you look at most coolants today they all say "safe" for alum. radiators and engines. Times change and so do the materials used in both motors and coolants. Oh and if you look at the manual that came with the bike ,it should say something like changing the coolant every 2 years or so.
Treat everyone you meet with dignity and respect....but have a plan to kill them just in case. |
#6 (permalink) |
Crazy Old Guy
Unfortunately, most 'house brand' lubricants (i.e. Motorcraft, Honda, etc) will change due to bidding by the lubricant companies. For example, Motorcraft oil was Mobil brand oil for a few years until someone else underbid them. The house brands will list what specifications they meet. Know your needs and then fill them . . .
Bryan (Big B) 07 Vulcan 900 Custom Candy Plasma Blue VROC Member #27075 MRCA Member #90008991 |
#8 (permalink) |
Third Gear And Gaining
They claim it runs 50 degrees cooler. I do not see that necessarily, but hard to tell with the analog gauge. It works good. No silicates, and a little pricey, but my bike is worth it
Brian
'08 Ninja 500 '85 Pontiac Fiero with 4.9l Caddy V8 |
| Coolant pump problem. Can you help? | raduadi | The Mechanics Corner | 2 | 03-28-2009 05:54 PM |
