Old 10-11-2009   #1 (permalink)
Sped1966
sped1966
Sped1966's Avatar
Send a message via Yahoo to Sped1966
Default Fuse Burnt After Bulb Change
Hey fellow cruisers. First off this forum is great. I have heard and learned a lot from a lot of cool riders. I've only had my vulcan 900 custom 3 or 4 months...love it. Was just needing an answer to a question.....I'm basically a newbie. I recently changed headlight bulbs from a H4 85/80 to a Wagner BP1210-H4 100/80. About an hour after riding I burnt the 10 amp headlight fuse. Was this coincidence or do I need to go to a little bigger fuse. If anyone can help I would appreciate it.
Thanks...........sped1966
Sped1966 is offline   Reply With Quote
Old 10-11-2009   #2 (permalink)
BrianTSmith99
Third Gear And Gaining
If I "did the math" right, 100 watts at 12 v should be 8.3 amps. So unless you have something else on that circuit you should be under the 10. It is never a good idea to swap a fuse to a larger size.
Are there any electrical mods to the bike?
Initially I'd try a new 10A fuse and the old bulb and see what happens.
Brian
'08 Ninja 500
'85 Pontiac Fiero with 4.9l Caddy V8
BrianTSmith99 is offline   Reply With Quote
Old 10-11-2009   #3 (permalink)
Sped1966
sped1966
Sped1966's Avatar
Default added led's
I did add two 4 cluster led accent pods and about 6 single led's. Would that make the difference. I put the 80/85 back in and so far no burnt fuse.
Old 10-11-2009   #4 (permalink)
BrianTSmith99
I also got that as a "private message", and not being sure if my response went out, copying it here. (I *AM* the newbie )
LEDs use almost 0 power. You'd have to have MANY to make a difference. Hmmmm. The danger with "upsizing" the fuse is the wire harness was designed and sized with that fuse in mind. It sounds like you are just "going over" for whatever reason. What I'd do... Run a NICE FAT WIRE (one size larger than what is currently running to the headlight) from the battery, thru the upsize fuse, thru a relay controlled by the old headlight wire. So rather than powering the headlight from the old wire, the old wire is activating the new relay, that is powering the headlight.
Someone here referenced...
http://www.easternbeaver.com/Main/Pr...s/h4_kits.html
that could simplify your life. They sell some neat stuff. I'm ordering one of their fuse blocks.
Brian
'08 Ninja 500
Old 10-11-2009   #5 (permalink)
RichLockyer
RichLockyer's Avatar
LEDs draw less than incandescent, but they do not draw "almost 0".
This is particularly the case with low voltage systems. While LEDs present a significant savings on 120v systems, the savings is less so at 12v.
What is the actual wattage rating and/or current draw on the clusters that were installed?
While 8.3a is okay for a 10a fuse, it is still on the ragged edge of the recommended 80% continuous current capacity (fuses should not be run 24/7 at more than 80% of their rating). Any excess current draw in the system, coupled with manufacturing tolerances in the fuse and lamps, can cause it to blow.
- Rich
2006 1600 Ultra-Classic
Patriot Guard Rider
Old 10-11-2009   #6 (permalink)
LabGuy
Old Dudes Rule
If I'm following correctly, you have a total of 14 led's. At roughly 24 miliamps each, that would be 336 miliamps, or roughly 1/3 amp. Add that to the 8.3 amps draw of the headlight, and you've got 8.6 amps, without factoring in the tail light and front running lights. Blown fuse time.
Mike-
'06 900 Classic
Centreville, Va.
LabGuy is offline   Reply With Quote
Old 10-11-2009   #7 (permalink)
RichLockyer
Taillight, front running lights, and brake light are on their own fuse on the 900 and 1600. Headlight is dedicated.
- Rich
Patriot Guard Rider
Old 10-12-2009   #8 (permalink)
anarkust
Night Rider
anarkust's Avatar
The OP never mentioned which circuit he connected the leds up to. He might have a dedicated circuit, or maybe he did hook it up to the wiring in the headlight bucket. Unless it's connected to the wiring in the bucket, I don't see what reason the leds would be adding to the draw from the headlight fuse and possibly blowing it.
'08 Vulcan 900 Classic - "Jessica"
anarkust is offline   Reply With Quote
Old 10-12-2009   #9 (permalink)
Ride4Life
900 LT
Ride4Life's Avatar
could have possibly been a bad bulb, i ran the bp1200 but the reason i dont anymore is it only lasted 4 months
2007 900 LT
Ebony / Galaxy Silver
CC Envy???
Never had it - Never will
Ride4Life is offline   Reply With Quote
Old 10-12-2009   #10 (permalink)
RichLockyer
My first one went about 6, but the 2nd one went almost 2 years before I replaced it with an HID system.
- Rich
Patriot Guard Rider
Old 10-12-2009   #11 (permalink)
2thdr
Workin' to ride
2thdr's Avatar
I LOVED the HID's on my Honda S2000. Rich, does yours do the high beam and the low? What one did you get? Thanks.
Steve
'09 VN900 Custom, Cobra Speedster Slashdowns, Kawi engine guard, gel seat, sissy bar/rack, shield.
2thdr is offline   Reply With Quote
Old 10-12-2009   #12 (permalink)
RichLockyer
Yup.... 35w, 6000k, direct H4 replacement with high and low (movable burner, not a secondary halogen lamp), for under $100.
http://www.kawasakimotorcycle.org/fo...d-ballast.html
I put the system in my '93 Blazer too.
- Rich
Patriot Guard Rider
Old 10-12-2009   #13 (permalink)
Twopoint
Apprentice Bug Killer
Twopoint's Avatar
Location: Pacific NorthWet!, a crossed the water from Seattle
something I didn't see mentioned, check to make sure you have good connections. a loose connection or some corrosion will cause some increase resistance to the circuit, which will in turn increase the amperage draw
05 Vulcan 1500 Classic FI
V&H longshots
PC III
VROC #27909
Bike Pics
Twopoint is offline   Reply With Quote
Old 10-12-2009   #14 (permalink)
2thdr
Workin' to ride
2thdr's Avatar
Thanks, I'll check into those...
Main fuse jw11432 The Mechanics Corner 15 06-16-2008 08:18 PM
Xenon Gas Superwhite Headlight Bulb dave007 Kawasaki Cruisers 2 02-24-2008 09:10 AM
05 636 Main Fuse bzoid The Mechanics Corner 2 07-21-2006 05:16 PM
K&N Air Filter/Wagner LazerBlue H4 Bulb - 04 Nomad FI dfgpilot Kawasaki Cruisers 8 09-12-2004 05:44 AM
