Old 2 Weeks Ago   #1 (permalink)
mgilde13
Default VN1500E Drive shaft removal- HELP!!
Hello,
I'm working on a coworker's bike and I am desparate for help. It's a 1999 Vulcan 1500 Classic and it's leaking oil from the top of the rear cylinder. Easy fix, right? Wrong. I've got pretty much the whole thing torn apart, to drop the motor, with the exception of where the drive shaft bolts up to the engine. How is this removed and are there special tool required? I've searched and searched these forums and I can't see where this has been addressed before. Also, once the motor is removed, is there anything that I should be looking for or addressing while the motor's out? Any help that could be provided would be greatly appreciated.
Thanks,
Mike
mgilde13 is offline   Reply With Quote
Old 2 Weeks Ago   #2 (permalink)
Spok
RIP Deron - 1400Pilot
Spok's Avatar
look at this thread, this might help. its specifically for the swing arm maintenance but addresses the drive shaft removal as well
http://www.kawasakimotorcycle.org/fo...2-22-07-a.html
AUGUST 2006 MOM
Spok is online now   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
Deeppurple52
Deeppurple52
Deeppurple52's Avatar
There is a small pin that has to be pushed in to remove the shaft. Rotate shaft until it is visible, use small pick or nail, push in, pull off shaft. Samie, same to reinstall.
Enjoy the ride!
2002 Honda ST1100
1996 BMW R1100RT
2004 1600 Classic
2006 900 Classic
Deeppurple52 is offline   Reply With Quote
Old 2 Weeks Ago   #4 (permalink)
mgilde13
Thank you for the reponse. So, do I just peel back the rubber boot or do I need to unbolt the four socket head bolts that are holding on, what appears to be, the bearing retainer?
Thanks
Old 2 Weeks Ago   #5 (permalink)
vulcancowboy
Love my 1500!
vulcancowboy's Avatar
If I remember, that pin has a spring behind it and will shoot across the room if your not ready!
Jim/1500 Classic
When the people fear their government, there is tyranny;
when the government fears the people, there is liberty. Thomas Jefferson
vulcancowboy is offline   Reply With Quote
Old 2 Weeks Ago   #6 (permalink)
mgilde13
Does anybody know if there is a right up on the process of removing the engine? I know the standard response is "Buy a manual" but I'm not willing to buy a book for a bike that isn't mine. I've searched and I've searched but I can't find the info that I need.
Old 2 Weeks Ago   #7 (permalink)
rfb92345
Forensic Bug Splatter Analyst
rfb92345's Avatar
If you are doing the work for free.....then he should buy the manual. Standard procedure for me in removing the motor................remove the rear wheel. Unbolt the final drive case from the swingarm. Remove the swing arm. Peel back the boot and push in the pin and remove the driveshaft. Remove the tank, seat, all that crap. From here it is pretty straight forward. Nice to have someone holding the bike when you remove the motor. Oil filter gets in the way when it comes out on my bike, so removing that will help.
'96 Kawasaki Vulcan Classic 1500
"Better to die living, than to live dying"
rfb92345 is online now   Reply With Quote
Old 2 Weeks Ago   #8 (permalink)
Deeppurple52
Deeppurple52
The pin is located under the boot. It is really easy once you see it. It sure as he** won't come off any other way.
Enjoy the ride!
2002 Honda ST1100
1996 BMW R1100RT
2004 1600 Classic
2006 900 Classic
Shaft drive wheel bentshaft Vintage Motorcyle Info 5 03-10-2009 12:42 AM
Belt drive ? Shaft Drive ? Chain Drive ? vulcan85 The Mechanics Corner 32 10-18-2008 03:00 AM
83 kz750 shaft drive HELP..Newb morhaven Kawasaki Streetbikes/Sportbikes 1 08-02-2008 12:44 AM
Shaft drive to Belt drive conversions AZ rider Kawasaki Cruisers 51 03-23-2007 11:16 AM
chrome drive shaft cover dickwol Kawasaki Cruisers 3 09-22-2004 02:20 PM
