LinkBack | Thread Tools |
Organ Donor
I just put on some Road Burner Street lites last night and was a bit confused when everything was done. As you can hopefully see from the marketing image below, the pipes look like they should be parallel and the ends should line up. I am running 0 for 2. Don't have a camera at the moment so can't take a picture of my bike. I haven't found any other pictures of these pipes on a 1600 Classic. I mounted everything loose and then tightened up the bolts on the head before tightening the bolts on the support bracket. I have tried loosening the bolts on the support and nudging things around, which helps a bit but I don't want to get carried away.
Am I doing something wrong? Is this a common problem with pipes of this design or am I the only one? My bike is up on jack stands right now since I have the final drive pulled off so maybe that has something tweaked a little bit? Image from Road Burner ![]()
2007 Ebony Vulcan 1600 Classic VROC #21369 VNOG #78 |
Uncle Bob's Love Child
Yes. Assemble everything finger tight, including the nuts on the head flanges. Get everything aligned and then tighten starting at the rear. Snug first then tight. Head flanges last.
Start tightening at the heads and as you found, things will be mis-aligned and then stressed being pulled into alignment. That leads to vibration. |
Workin' to ride
You're going to find differing opinions here! I agree on finger tighten everything while supporting the pipes in a parallel configuration. But what worked best for me, and advice given by many to me was to start tightening at head flanges first. The last thing you want is to have at the very end the head flange not aligned flat to the exhaust port and then tightening it down...great way to crack the flange or bend a stud.
'09 VN900 Custom, Cobra Speedster Slashdowns, Kawi engine guard, gel seat, sissy bar/rack, shield. |
#4 (permalink) | |
#6 (permalink) |
nu2kawi
![]() Join Date: Sep 2007
When they make a set of pipes or what ever for a bike they make them from a bike they have and fit them to that bike. Problem is not all bikes are made the same. To get my pipes to fit, I had to do some drilling to align some holes. I don't have a torque wrench that I could use on the head bolts so I torque a bolt in a vice and checked it with a combination wrench to see how tight it felt. Finger tight to start, then start snugging all the bolts about the same going front to back, like you would torquing a head in place. In the end everything sealed great and lined up good. I have a diff bike and diff pipes, but the basics are the same. You'll get it. Just don't tighten any one bolt till all are snug.
07, Z1000 01, XVS1100LC Yam cust. |
#7 (permalink) |
Fine, but the point is that if you tighten at the head first, you have to pull the rear into alignment stressing the pipes. If you tighten the rear first the crush gasket will accomodate the misalignment and leave the pipes unstressed. Stressing the pipes during installation is frequently the reason people wonder why their bike vibrates more after installing pipes.
#8 (permalink) | |
Workin' to ride
#9 (permalink) | |
I've been doing this alot longer than Rich. Last edited by BillyBobby : 2 Weeks Ago at 02:06 PM. |
#10 (permalink) |
Organ Donor
Thanks for all of the advice. I will loosen everything up tonight and start tightening from the rear this time. I just hope I don't futz with it enough that I have to go get new new gaskets. I will have to post a pic when my camera comes back from vacation.
#12 (permalink) |
Workin' to ride
Just because I've been practicing dentistry longer doesn't necessarily make me a better dentist than my peers...there's more to it than that in my opinion. I am only proposing that there are differing opinions...it doesn't need to be perceived as an attack on yours. Sounds like you have a competitive streak...
#13 (permalink) |
Organ Donor
I used BillyBobby's advice and it looks good now and didn't seem to put pressure in the wrong places on the head. I did not replace the gaskets and everything seams sealed. The most accessible dealer charges $6+ each for the OEM gaskets. I didn't check at the Harley dealer, which is closer, but I do have their part number now. Still waiting on parts to fix my final drive so I won't know about vibration for a few days at least.
I always appreciate the differing opinions. Sometimes you can piece together different ideas to come up with your own solution. The right solution is what works for you, not necessarily what is written in a manual.
#16 (permalink) | |
Workin' to ride
We need pics! And a sound clip would be nice! Congrats on getting them lined up.
#17 (permalink) | |
status? don't need it.
nobody seems to know where Rich is --> http://www.kawasakimotorcycle.org/fo...ml#post1831024 |
| Aftermarket pipes | mikehw516 | Kawasaki Cruisers | 16 | 07-25-2009 03:52 PM |
| Anyone ever modify baffles in aftermarket pipes | billymac814 | Kawasaki Cruisers | 14 | 02-03-2009 08:59 PM |
| Help! Anybody here familiar with Muzzy Long Shot straight cut pipes? | Humbucker | Kawasaki Cruisers | 12 | 01-13-2009 06:43 AM |
| aftermarket pipes? | dspauls | Vintage Motorcyle Info | 6 | 08-25-2008 01:38 AM |
| 2002 Drifter aftermarket pipes | bjones | Kawasaki Cruisers | 1 | 05-20-2004 10:18 AM |
