LinkBack | Thread Tools |
Way Too Much Free Time
I'm looking to see what it will take to install the Scootworks lowering kit for the rear of an 800. The Cobra kit says you need a tool to compress the spring but the Scootworks kit doesn't say anything about a spring compress tool.
Thanks! |
#4 (permalink) |
Clutch Cadet
I think the Scootworks lowering kit does not require the spring compressor but the shock improvement kit does. That was a must have on my 800 when it was lowered.
http://community.cruisercustomizing.com/fordtrucktough |
#5 (permalink) |
Member
Tweek's Vulcan Cruiser
Gadget's Fixit Page For Kawasaki Nomad & Classic Modification Maintenance & Repair The first page has some excellent info on 800's. The page I've directed you to will go into detail on how to lower it and how to use regular hose clamps to do it. I used this site alot when I had my 800 and it was invaluable. The second page is more dedicated to 1500's but has some usefull info as well. Hope that helps you out! Hmm the site has changed a bit. Follow the top link and go to the bottom of the page. ( stuff about LoRidres Bike ) Look for ( Lowering the rear ) In that area. That will take you directly to it. Last edited by VindianaJones : 2 Weeks Ago at 03:19 PM. |
#6 (permalink) |
Cruising In Fourth Gear
you might hear from scootworks late next week. when i ordered the front wheel kit it took 3 weeks for them to get back to me. I emailed them and called them. I have also heard of guys on the board who had good luck with them but i didnt.
vroc#26204 03 800A alot of custom stuff stock sucks |
#7 (permalink) |
i love male chickens
just wing it. haha. once you get your rear wheel off and the shock assembly exposed, it shouldnt be too much of a problem. pretty straight forward. if wrenchin aint a problem for ya, you should be okay. i think.
SUPPORT YOUR LOCAL STOCKER |
#9 (permalink) |
for lowering kit instructions go to scootworks.com, click on info center, click on lower kit,
SCOOTWORKS - Information Resource Center I installed mine 2yrs ago. if you have a frame mounted fender, you are going to need to mod the shock with s.w. shock kit-spacers to prevent fender scrub and eating up your wiring, which requires the spring compressor. I did when I installed mine had the stock fender sit up. but with the bobber swing arm mounted fender the tire will not scrub the fender. installing the lowering kit was easy but the shock gave me some frustration.hopes this helps |
| Britt lowering kit on the 900c, the bad | Bustcard | Kawasaki Cruisers | 21 | 06-01-2009 08:09 PM |
| LowRider lowering kit instuctions... Help! | Bigdadyvulcan | Kawasaki Cruisers | 15 | 04-06-2009 02:51 PM |
| First Aid Kit | DebbieW | Main Lobby | 10 | 03-30-2009 11:13 AM |
| motorcycle camera kit for sale | 749carbon | Accessory Swap Meet | 0 | 09-11-2006 02:04 PM |
| Jet Kit Info | diablo13346 | Kawasaki Streetbikes/Sportbikes | 7 | 07-25-2006 01:13 PM |
