Old 2 Weeks Ago   #1 (permalink)
Pseudo-Fed
Made It To Second Gear
Pseudo-Fed's Avatar
Default Please Help! Fuel Dripping from Overflow Hose-Tank Almost Empty
Okay, first I confess this is not on a Kawi bike. But you guys were very helpful when I had my 900, and I'm hoping this is a generic problem.
My VTX1800, 2007, bought with 0 miles a month ago, and now has 900 miles is venting fuel through the overflow hose. I first noticed it after fill up, riding about 30 miles, then parking in sun at work. But now, with 110 miles on the 4.8 gallon tank, it is still dripping. Took a 60 mile ride (in the dark) and stopped in the middle and the hose end was dry. After getting back home and the bike parked a few mins, it started dripping again. Seems to stop after 20-30 mins.
The cooling fan is working normally. The overflow hose seems to be attached under the left side of the tank. With a flashlight I can see a copper looking tube coming into the tank there and going up.
What should cause the hose to drip when operating normally? Assuming it is similar for all such bikes, is there a section of the tank that gets some gas in it and would cause this? Could the gas cap be involved?
From a few dark spots on the concrete under the hose end where I park I presume this has been happening and I've not noticed.
Any help/suggestions are appreciated.
Jeff H.
2008 C14
2009 Custom
Pseudo-Fed is offline   Reply With Quote
Old 2 Weeks Ago   #2 (permalink)
BikerEm
Cruising In Fourth Gear
Pseudo-Fed - I don't have any direct suggestions but there are some good folks here who you may want to also consider:
VTXOA - Powered by vBulletin
Vulcan 900 Classic
Honda Aero 750 (Mrs. BikerEm)
Triumph Bonneville T100
BikerEm is offline   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
Pseudo-Fed
Pseudo-Fed's Avatar
Thanks. I'm on VTXOA as well as VTXcafe and posted question there too. Many responses on VTXcafe, but none on VTXOA yet....
Jeff H.
2008 C14
2009 Custom
Old 2 Weeks Ago   #4 (permalink)
wayne1001
Sit speling cheker
Not sure about the Honda but Kawis have a pressure relief spring near the cap where the vent line attatches. If the spring is weak it could cause that. Mine only drips if I fill it up and then park it.
wayne1001 is offline   Reply With Quote
Fuel Overflow problem Ojisan Kawasaki Cruisers 13 07-23-2009 09:31 AM
Help 81 KZ1000 ltd fuel tank ratvespa Vintage Motorcyle Info 12 05-04-2009 10:37 PM
How to hook up fuel tank jdub8949 Kawasaki Cruisers 5 11-24-2008 02:33 PM
Removing the Fuel Tank on an 800 Classic Classic800 The Mechanics Corner 6 07-29-2008 08:26 PM
Fuel overflow hose? Can I plug it? Cerberus23 The Mechanics Corner 1 12-27-2003 01:58 AM
