+ Reply to Thread
Results 1 to 15 of 15
Thread: Gps Socket
  1. #1
    Retired & loving it. SgtWilliam's Avatar
    Join Date
    Aug 2009
    Location
    Kingwood Texas
    Posts
    26
    Default Gps Socket
    Hi all, I recently bought a gps for my 97 kw 1500 classic and I was wondering if anyone else put a lighter socket on their bike and where did you put it.
    thanks
    Bill
    97 1500 Classic D-2
    Patriot Guard Rider
    Retired LEO
  2. #2
    Made It To Second Gear BTK Beginner
    Join Date
    Sep 2008
    Posts
    95
    Tap in directly to the battery with a fuse inline if you want it hot all the time.
    If you want it switched, tap into the headlight and add a relay that pulls in when the headlight is on. Using a relay is simple and isolates the outlet from adding extra loading to existing wiring harness.
    In any case use an inline fuse and use high quality crimp connectors, don't add a potential problem with twisted wires and tape.
    I did it on my 900 works great. I don't have a schematic of the 1500 so wire colors would probably be different.
    A voltmeter and some simple checks would tell you which wires to tap into.
    06' 900LT Black & Red
  3. #3
    IBA#34418 Extreme Forum Supporter pat0021's Avatar
    Join Date
    Aug 2006
    Location
    Ashland, Oh
    Posts
    5,336
    Unless you wanna spend high dollars to get one that clamps to your bars, I would suggest the relay method.
    If you like your freedom thank a Vet!
    2006 VN900LT
    U.S Navy Vet
    http://patsrides.blogspot.com/
  4. #4
    Uncle Bob's Love Child BTK Intermediate vulpine's Avatar
    Join Date
    May 2009
    Location
    Central Pa.
    Posts
    251
    2004 Suzuki Marauder
  5. #5
    Giant Biker BTK Expert Lattimer's Avatar
    Join Date
    Apr 2005
    Location
    Mount Royal, NJ
    Posts
    1,921
    I bought a handlebar mount 12v outlet from the local dealer for about $16. Wired it into the headlight, works great. I think its made by Emgo. Basic black plastic.
    Nice chrome ones are spendy......
    Shawn Lattimer
    '06 Silver V2K Classic VROC #22980 ROG #464
  6. #6
    Enjoying midlife Crisis! BTK Expert ersterhernd's Avatar
    Join Date
    May 2008
    Location
    Cloverdale, BC
    Posts
    431
    SgtWilliam, if your GPS is a Garmin and you don't intend to use the cigarette lighter socket for anything else, check out the Gilsson Bare Wire Power Cable. Very clean when wired to the headlight, no excess bulky cable laying on your bars.
    Gilsson Bare Wire Power Cable (GPSCity.com)
    '07 900 Classic LT
    Ebony/Silver
  7. #7
    Join Date
    May 2009
    Location
    Papillion, NE
    Posts
    80
    Quote Originally Posted by ersterhernd View Post
    this is what i did with mine.....wired it to the accessory plugs in the headlight....nice thing is it will power my garmin AND charge my blackberry......
    '08 Vulcan 900 Custom Darkside
    HK 2 into 1 Sideburner
    Baron's BAK
    Cobra fi2000r
    SW Front Pulley
  8. #8
    Crazy Old Guy BTK Expert NewRoadie's Avatar
    Join Date
    Jan 2008
    Location
    Surprise, AZ
    Posts
    1,061
    I wired mine direct to the battery and unplug it and take it into the hotel with me.
    Bryan (Big B)
    07 900 Custom
    Candy Plasma Blue
    Secretary-Phoenix VRA
    VROC #27075
    MRCA #90008991
  9. #9
    Flash Frozen Forum Supporter freezeradio's Avatar
    Join Date
    Jul 2007
    Location
    Oswego,Illinois
    Posts
    731
    Wink gust ordered
    I just ordered mime thanx
    Right around Chicagotown Freezeradio Just got down !!!
  10. #10
    Cruising In Fourth Gear BTK Intermediate SteelCityVROC's Avatar
    Join Date
    Aug 2006
    Location
    Lancaster, PA
    Posts
    236
    Default Re: Gps Socket
    I'm considering installing a cigarette lighter, but this caught my attention too. Is this something only available with GPSCity or is it also maybe available in a store like Auto Zone etc?
    08 Vulcan 1600 Classic
    Lancaster, PA - just moved from Pittsburgh
    Enjoy the ride
  11. #11
    98' 1500 Classic BTK Expert Cranky CJ's Avatar
    Join Date
    Aug 2007
    Location
    Loveland, CO
    Posts
    978
    there should be a lead off the pos terminal off the battery under the seat. i tapped into that, fuse protected it, and ran a line under the tank out the front and mounted a power socket on the front on the windshield bracket.
    I cremped the connections with heat wrap to keep moisture out. fuse protected it again on the other end, only so i can remove the fuse and kill the power to it when i want, without taking the seat off. i cleaned the wires up by tieing them off, taping them off so everything looks clean and there isnt a rats nest of wires all over.
    got a ram mount for my model of gps and wala, done deal.
    My Toys:
    98 1500 Classic
    04 HD XL1200C
    1986 CJ7
    1911A1
  12. #12
    Wants better weather! BTK Expert meanie's Avatar
    Join Date
    Dec 2004
    Location
    Northern Detroit Subs, Michigan
    Posts
    869
    I mounted mine on the inside windshield support bracket, which is mostly hidden, then ran the quick disconnect wire directly to my fuse box next to the battery. Therefore, when I remove my shield, I unplug the adapter as it's now part of the shield, then plug in when I put the shield back on.
    One way to make sure crime doesn't pay would be to let the government run it.
  13. #13
    Join Date
    May 2009
    Location
    Papillion, NE
    Posts
    80
    Quote Originally Posted by SteelCityVROC View Post
    i got mine on ebay for $9 or something...
    Baron's BAK
    Cobra fi2000r
    SW Front Pulley
  14. #14
    SHARPS BIG FIFTY RULES
    Join Date
    Oct 2009
    Location
    Colorado Springs, Colo
    Posts
    19
    my lighter unit is mounted on the triple fork top cover on left hand side and wired thru the ignition switch, so when bike is off so is power to oulet.
    __________________________________________________ _______________
    '96 1500 Classic
    When Diplomacy fails use superior firepower
  15. #15
    Join Date
    Aug 2006
    Location
    Lancaster, PA
    Posts
    236
    Well, I followed instructions from another thread, purchased a waterproof lighter from Pep Boys, got an inline fuse, and ran it from the wire under the seat to the front and mounted on the side near the windshield. Looks very professional now. I know it's "hot" all the time so I have to remember to unplug anything I might be using before leaving the bike for long periods of time.
    This forum has been a great help to me and this was no exception. Thanks to everyone for helpful hints and recommendations.
    Enjoy the ride
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. your advice on GPS features needed
    By Ruh Roh in forum Riding Gear
    Last Post: 11-10-2008, 12:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Search Engine Optimization by vBSEO 3.5.0 ©2010, Crawlability, Inc.
