Problem with Ignition Blowing fuses
A few weeks ago I was riding my bike and it just died. I pulled into a parking lot and found that the ignition fuse had blown. I put in the spare and it blew. I took off the seat and traced wires from the power commander and looked for shorts-nothing looks wrong. Called a friend and he came with his trailer and we took the bike home. In the garage I tightened-up the battery cables(they really were not loose maybe 1/4 turn) changed the fuse again and she started right up. I rode maybe 75 miles with no problems then it started blowing fuses again , not with the bike running but when I would push the starter button bam! no power. I know it sounds like a short but the wiring all looks good. I still have not removed the gas tank to look under it and I guess that will be my next attempt at finding what is wrong. I wonder if it could be the fuel pump, it is also on this fuse but is in the tank. Any suggestions would be appreciated as this is extremley frustrating,
Lonestar
2002 VULCAN CLASSIC FI
