Installing accessory power plug
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 21 to 39 of 39
Thread: Installing accessory power plug
  1. #21
    Sick Puppy BTK Expert ricksza's Avatar
    Join Date
    Apr 2010
    Location
    Bensalem, PA
    Posts
    2,948
    Default Re: Installing accessory power plug
    Quote Originally Posted by Jcurfew View Post
    My husband Shorttail just installed one on his bike. He ran the power source from the headlight and followed the wiring down the tank. Installed it on the side panel. Made just a small hole to insert it. It looks great and is protected from weather.
    That's exactly what I wanted to do. Looks great.
    Rick
    Darkside 2009 900 Custom 'Candy Burnt Orange'
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #22
    Fast20 BTK Intermediate fast20's Avatar
    Join Date
    Aug 2004
    Location
    Bardstown, Kentucky
    Posts
    273
    i like that.. nice and clean and basically hidden... sorta what i did with my garage door opener button...
    Picasa Web Albums - randy - RELOCATION OF...
    2008 Vulcan Classic 1500
    VROC #13792
    http://randysmc.bravehost.com/
  4. #23
    Join Date
    Apr 2011
    Posts
    1
    Can you tell me what the lock is on your handle bar?
  5. #24
    900 LT BTK Expert Ride4Life's Avatar
    Join Date
    Oct 2007
    Location
    Forked River NJ
    Posts
    1,134
    on the 900 the power tap under the sat and the power tap in the headlight bucket are the same feed, both hot all the time and both feed off of the accessory fuse
    Everyday I beat my own previous record for number of consecutive days I have stayed alive!
  6. #25
    Join Date
    Aug 2004
    Location
    Bardstown, Kentucky
    Posts
    273
    Quote Originally Posted by BMWbabe View Post
    that looks like a helmet lock...
    VROC #13792
  7. #26
    Guilty By Association BTK Expert Redneckryder's Avatar
    Join Date
    Apr 2008
    Location
    Ionia, MI
    Posts
    650
    That is a steering lock....locks the bars all the way to the left, if I remember right.
    2008 vn900custom
    Those who dance are considered insane by those who don't hear the music
  8. #27
    Join Date
    Apr 2008
    Location
    Ionia, MI
    Posts
    650
    btw, the white/blue wire in the headlight bucket is the hot wire.....just put an accessory outlet on my bike. Now I gotta wait for the wife to return with the Jeep so I can try it out.
    2008 vn900custom
  9. #28
    Live, Laugh, Ride BTK Expert GregsVulcan's Avatar
    Join Date
    Feb 2008
    Location
    Maryland
    Posts
    650
    This site has units that will also charge your battery without seat removal.
    Powerlet Products - Rugged power outlets, cables and electronics
  10. #29
    Highway Child BTK Expert Uncle Wulf's Avatar
    Join Date
    Jul 2010
    Location
    Cold Hole, Vermont
    Posts
    2,461
    Quote Originally Posted by Redneckryder View Post
    Why?
    www.assistancelist.com
    Help your fellow bikers, and they'll help you.
  11. #30
    Join Date
    Apr 2008
    Location
    Ionia, MI
    Posts
    650
    Quote Originally Posted by Uncle Wulf View Post
    Why?
    Because my gps and cell phone charger was in the jeep, and I dont have anything else that uses a cig lighter plug.....
    2008 vn900custom
  12. #31
    Patriot Guard Rider Extreme Forum Supporter Aifwikir's Avatar
    Join Date
    Jun 2007
    Location
    Magazine, Arkansas
    Posts
    1,694
    I got a Kury cigarette light/accessory plug and mounted it to the handle bars.
    Little expensive but I've had it for 4 years on two different bikes, never a problem. I direct wired it to the battery.
    Aif
    Retired US Army & Proud Marine Corps Dad!
    '08 Red/White VN 1500 Classic
    http://www.patriotguard.org
  13. #32
    Join Date
    Aug 2011
    Posts
    2
    I have a 2009 900LT as well. I installed the 12V accessory plug on mine and it works great. I'm having a problem with the batter though. Along with the accessory plug, I also installed amplified speakers, battery charge indicator and boogey lights, all directly wired to the battery. When I turn off the bike, I always make sure that everything is powered off (speakers are turned off, lights are turned off and nothing is plugged into the accessory plug). I've noticed that since installing these accessories 3 months ago, my battery seems to be dying quickly. For instance, I ride for 70+ miles one day, when I get home, the battery is fully charged and everything is turned off. I come out 3 days later and the battery is low (not quite dead, but not enough to start the bike). Then, I fully charge the battery with a battery tender, ride for 70+ miles, come home, turn everything off, let the bike sit for a week and the battery is totally dead.
    Do the accessories (amplified speakers, accessory plug, lights and battery indicator) still draw juice from the battery, even when they're powered off? That's the only thing I can think of as to why the battery is dying so quickly. If so, what should I do? I found an extra lead that is only "live" when the bike is on, but when I put the meter on it, it's only a 10Amp circuit and I'm afraid that if I run the accessories off this 1 lead, I'll burn out that circuit.
    Any help would be greatly appreciated, thanks.
  14. #33
    Clutch Cadet Forum Supporter 18wheelfixer's Avatar
    Join Date
    May 2011
    Location
    West Carrollton, Ohio (moved here in September 2011 from Oshkosh, WI)
    Posts
    367
    Quote Originally Posted by adamscrnr View Post
    It would be impossible to tell if any of your components are drawing power (when they're turned off) unless you disconnect them and run a multimeter in series in AMP mode to test for current flow. Another way would be to disconnect them from the battery negative terminal and then touch the lead to a chassis ground and look for a spark. Both methods would be a decisive way to know if they are drawing power. The best way to isolate these components from constant power is with a relay. You could have the relay turn off with the ignition so they have no current flowing to them when the bike is not running. It's a cheap any easy way to protect your battery.
  15. #34
    Join Date
    Aug 2011
    Posts
    2
    Thanks for the help. What would be the recommended solution for the relay? Should I install a fuse block to run all the accessories to and then from the fuse block, to a relay, to an in-line fuse and then to the battery? What kind of relay should I get? Do you have any sources or pictures for installation steps?
  16. #35
    Join Date
    Apr 2010
    Location
    Bensalem, PA
    Posts
    2,948
    You could use Gadget's Driving Lights as a guide for relay wiring.
    Rick
  17. #36
    Join Date
    May 2011
    Location
    Posts
    367
    I would also suggest using a circuit breaker over a fuse.
    Buy Bussmann Circuit Breaker BP/CBC-30HB-RP at Advance Auto Parts
    Here is an inexpensive generic 40 amp relay.
    Buy Optronics 12VDC 40A Relay A-715 at Advance Auto Parts
    As most relay's logic are similar... 30 and 87 are the high current path, 85 is ground and 86 is the trigger on the signal line. Of course follow the schematic that is included in the relays package, but for the most part this will be correct.
  18. #37
    No Significant Other BTK Expert MFolks's Avatar
    Join Date
    Jul 2008
    Location
    Springfield Mo
    Posts
    10,116
    Mike Folks
  19. #38
    Join Date
    Sep 2011
    Posts
    3
    That is the neatest installation I've seen, thanks for the idea
  20. #39
    Join Date
    Aug 2012
    Posts
    2
    Quote Originally Posted by Bear1 View Post
    I have a 2009 900LT and would like to install a 12 volt power plug to power various accessories; eg, GPS, phone charger, etc. Has anyone had exprience doing this and, if so, how did you tap into electrical system and where and how did you mount the plug?
    Check out Index
    I think they have exactly what you're looking for without any additional wiring needed.
    see the attached.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Accessory power outlets (need pictures)
    By SilverBullet in forum Kawasaki Cruisers
    Last Post: 07-26-2009, 08:54 AM
  2. 04 prairie 360 4x4 fan and accessory plug prob
    By edemi1 in forum Kawasaki ATV and Mule
    Last Post: 07-12-2009, 09:36 PM
  3. Accessory Plug Wiring on 1600?
    By DanL in forum Kawasaki Cruisers
    Last Post: 06-05-2009, 07:46 PM
  4. 2009 concours accessory plug
    By oldmanrides in forum Kawasaki Touring and Sport Touring
    Last Post: 05-10-2009, 11:41 AM
  5. Accessory plug in on 900
    By tomslusher in forum Kawasaki Cruisers
    Last Post: 06-23-2008, 08:48 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
