VULCAN COOLANT LEAK KNOWLEDGE BASE - Page 2 - Kawasaki Motorcycle Forums
post #11 of 50 (permalink) Old 04-06-2011, 08:44 AM
S.D.Willie's Avatar
Re: VULCAN COOLANT LEAK KNOWLEDGE BASE
same issue on my 06 1600 classic. Not visible but you sure can smell it. Will take the tank off when the weather gets nicer and have at this b*tch.
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
S.D.Willie is offline
Sponsored Links
Advertisement
post #12 of 50 (permalink) Old 04-26-2011, 11:41 AM
Test Pilot
Dudester's Avatar
Send a message via MSN to Dudester
Bump
2003 Vulcan Classic 1500
195/60/16 Hankook Optimo H426 Darksider
Dudester is offline
post #13 of 50 (permalink) Old 05-22-2011, 02:39 PM
Junior Member
I just did the 6,000 mile service on my 2004 Vulcan 500 yesterday. Though the reservoir never got low at all I've been smelling coolant since I bought it last month and could see a very small white trail down by the hose running from the bottom of the radiator to the water pump. I planned to replace that hose during the service. When I pulled the fuel tank off it was easy to see that the problem was actually at the hose to the coolant pipe in the top of #2 cylinder. The clamp just wasn't tight enough and the coolant was seeping out there. The spark plug area drain hole is right over the water pump so that's why the coolant was ending up down there. I went around and tightened all the clamps including the ones "hidden" by the fuel tank. After several test rides there is no more smell and everything is bone dry.
Joe
2004 Vulcan 500
Turbojoe is offline
post #14 of 50 (permalink) Old 05-22-2011, 06:10 PM
Test Pilot
Dudester's Avatar
Joe
Hey way to go Joe, you beat me to it. I will be doing mine as soon as I have a free moment to concentrate on getting the task done. I have bee procrastinating enough, so this week, I'll try and git er' done. I know the problem is just a few loose clamps, but I've been a little scared of removing the gas tank, but I'm now determined, it's gotta get done, and I must stop putting it off. I'll report back once it's fixed, and I'll try and post some play by play pictures as I do it, to help some other poor procrastinating sap with hope that it will help them out and give them the confidence to do it.
I'm also on the verge of replacing my motorcycle rear tire for a car tire, but that's another thread and discussion.
Thanks for posting the results you got. Welcome to the forum and safe roads.
Dudester is offline
post #15 of 50 (permalink) Old 05-22-2011, 09:47 PM
Junior Member
It took me less than 5 minutes to remove my tank for the very first time. One 8mm bolt on the instrument panel. Lift it up and disconnect the speedo and two electrical connectors and the panel is off. One 8mm bolt to remove the seat. Two vent hoses on the right side of the tank, one vacuum hose and the fuel supply hose on the left side, two 12mm bolts and off comes the tank. Easy as that. At least on my 500.
Joe
2004 Vulcan 500
Turbojoe is offline
post #16 of 50 (permalink) Old 05-22-2011, 11:08 PM
Test Pilot
Dudester's Avatar
Thanks Joe, I know once I do it, I'll be kicking myself for having waited so long....DOH !
On my 1500. the procedure is a little different than your 500, but basically the same.
Dudester is offline
post #17 of 50 (permalink) Old 06-12-2011, 10:46 AM
Junior Member
Help I too have a coolant leak but not from a hose, I wish it was that simple. I have a 95 vulcan 800 and I just noticed that I am leaking coolant from the pipe going from the top of the Right Engine Cover to the Crankcase. It's leaking from where it goes into the crankcase. It appears to be a seal issue but I am leary of taking off the cover (only way I can see to remove pipe) as I do not know what all I will need to replace if I do. I have the service manual but it is useless. It shows an exploded view, but no part numbers or descriptions or what needs sealant and so forth. Please help.
thechaz05 is offline
post #18 of 50 (permalink) Old 06-12-2011, 01:40 PM
Test Pilot
Dudester's Avatar
Sorry Chaz, can't help you with your question, but I'm sure some of the more mechanical guru's here will chime in soon.
In the mean time, here is a thread that I added some pictures on how to tighten the rad hose clamps, and removing the gas tank.
http://www.kawasakimotorcycle.org/fo...se-clamps.html
Dudester is offline
post #19 of 50 (permalink) Old 09-22-2011, 04:09 PM
Member
I have the same issue with My Vulcan 900. I am noticing leakage from around the clamps. I have to find a way to loosen the tank, so that I can get in there and tighten the clamps. The owners manual is no real help. If any one knows how, please do share.
BlkSteele is offline
post #20 of 50 (permalink) Old 09-22-2011, 05:16 PM Thread Starter
Slow Guy on a Fast Bike
trikebubble's Avatar
I'm not sure how to loosen and/or remove the tank on the 900. Post a question in the cruiser thread about "900 tank removal" or something like that, and I'll bet you get the help you need.
So you want to buy a sportbike as your first bike and have questions?
Please Read First:
08 Midnite Sapphire Blue ZX-14
trikebubble is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
