VULCAN COOLANT LEAK KNOWLEDGE BASE - Page 5 - Kawasaki Motorcycle Forums
post #41 of 50 (permalink) Old 05-28-2014, 07:16 AM
Senior Member
SteelCityVROC's Avatar
Send a message via AIM to SteelCityVROC Send a message via Yahoo to SteelCityVROC
Re: VULCAN COOLANT LEAK KNOWLEDGE BASE
Originally Posted by Cynjut View Post
That might well be a design issue, but there's definitely a dent in that tank near that tear. I'm pretty sure the factory didn't do that.
And you're exactly right. This was the first time the radiator was ever removed since I bought it as a 2008 leftover in 2009. The bike has never been in any sort of accident whatsoever. That was concerning and probably one of the reasons this happened over the years. I'd consider an aftermarket radiator if something like that exists. I just can't afford a $450 brand new one.
08 Vulcan 1600 Classic
Lancaster, PA
Enjoy the ride
SteelCityVROC is offline
Sponsored Links
Advertisement
post #42 of 50 (permalink) Old 07-29-2014, 04:07 PM
Junior Member
So, I've been through a couple of hose tightening cycles and I thought I had the leak resolved but I was out for about a 1000 Km's of riding over last week's hot (for this local) weekend and the coolant is dropping again. The coolant is defiantly not disappearing as much as it was so I guess the hose tightening is working but I'm not sure how much more tightening the clamps will take before bursting.
This is very frustrating, no obvious leaks or signs of leaks, no coolant smell or any odd exhaust smell, no coolant in oil (just changed it on the weekend). I'm stumped!
VulcanDrifter is offline
post #43 of 50 (permalink) Old 02-15-2015, 08:25 PM
Junior Member
lowe's sells a hose clamp torck wrench i think it tightens to 15 foot pounds works great its about 6 bucks
bud dakota is offline
post #44 of 50 (permalink) Old 06-08-2015, 03:00 PM
Junior Member
I'm having some what same issue. Bought a 05 kawasaki vulcan 800. With 4000 miles. Guy had it way to rich. After some adjustments and 10 mpg more it's smoking white more out of tailpipe at idle. After it has been running for good bit I turn it off to stop and when I start it it smoke something fierce but goes away when I drive. It's only the front engine I took the exhaust off and got a light smell of sweet coolant. But the plug looks good. Has the burn that it needs. Coolant hasn't dropped much if any. I did take off valve cover then and reseal ed around the reeth. I cleaned pipes and exhaust port and so far on 25 miles nothing. But I know it will be back. Hoping not head gasket but want some ideas. Thanks guys.
diesal3287 is offline
post #45 of 50 (permalink) Old 08-08-2015, 09:44 AM
Junior Member
Guys got a problem.... i went for a 60 ,ile ride yesterday and checked the header and the res and no water.... there is nothing comming out of the tail pipe and the oil look good so what do you think... like to sort it before the engine goes kaput... it only has 29k on the clock and its a 99 1500 Nomad... please help im at a loss to what it is..
Mousedaddy is offline
post #46 of 50 (permalink) Old 05-14-2016, 11:13 PM
Member
Cowboy Bob 11's Avatar
Hello Fellow Bikers,
My wife and I came back from a short ride and decided to clean our 2007 Kawasaki Vulcan 1600 Nomad because it was a dusty road trip...While in the process I discovered dried coolant on the left hand side of the engine and down into the frame... It wasn't there when we left... I immediately removed the side cover to check fluid level and the level was midway between the high and low marks which I concluded was reasonable... It was still early afternnoon so I decided to take it to my local dealer and have Sam the head mechanic check to see where it was coming from, somewhere from atop of the engine...He was unable to determine where the leak came from wiothout removing the tank and being the busiest time of the year asked me to leave it with him and if he had some spare time he would jump right on it...That was Thursday April 28th, 2016... He called several days later and explained that the small rad hoses were both leaking and in need of replacement, however the one hose was back ordered and had no idea when it would arrive...I hoped it would be ready for friday May 13th, becaused that is one of the biggest bike gatherings in southern Ontario and both my wife and I were looking forward to the trip...Well life is full of disappointments... Anyway it was scheduled to be in the shop this coming week for a full rad flush and new anti-freeze because I had purchased the bike used and over the course of the winter I had cleaned the breather, changed the plugs, oil and filter and cleaned the other oil screen so as to have a baseline for a maintenace preventative maintenance schedule... Hoping all the other minor fluid changes go smoothly this season... Just needed an ear or two to rag on... Thanks for listening...
Bob
Cowboy Bob 11 is offline
post #47 of 50 (permalink) Old 05-22-2016, 07:17 AM
Stoopit Moderator
ULTIMATE Forum Supporter
rbentnail's Avatar
Bob
Yeah Bob, it happens. As careful as I am with maintenance seemsas things get older things fail. My bike too is an '07 and with 87,000 miles she's beginning to show some age: a drip here, a weep there. Nothing major yet but that comes from diligence and quick reaction like yours.
Words aren't children and there's nothing wrong with killing them to clarify a point or keep the peace.
rbentnail is offline
post #48 of 50 (permalink) Old 08-08-2016, 01:18 PM
Senior Member
T Gibbs's Avatar
I was on my 2012 Voyager last weekend. I got a whiff of coolant smell a couple of times. I guess I need to check the hose clamps.
2012 Vulcan 1700 Voyager
Cobra pipes
Kuraykyn grips
Mustang seat
T Gibbs is offline
post #49 of 50 (permalink) Old 10-31-2016, 01:21 PM
Member
My 2013 Vulcan 900 Custom that was purchased new from a dealer has < 7000 miles on the odometer.
I noticed that coolant is seeping out of the coolant drainage outlet beneath the impeller on the right side of the crankcase so coolant must be leaking past the mechanical seal.
I am going to replace the mechanical seal and the impeller seal which can be done without removing the engine from the frame.
While I have the clutch cover off I am also going to replace the oil seal for the clutch release lever shaft.
It is not leaking but I want to replace it while the clutch cover is removed.
kawvul is offline
post #50 of 50 (permalink) Old 10-31-2016, 01:41 PM
Member
My 2013 Vulcan 900 Custom has < 7000 on the odometer.
A little bit of coolant is leaking out of the drainage outlet (not the tapped M6 X 1 coolant drainage hole) beneath the impeller on the right side of the crankcase.
The leak is caused by coolant leaking past the mechanical seal and out through the drainage outlet
So I am going to replace the water pump's mechanical seal and impeller seal.
And although it is not leaking I am also going to replace the oil seal for the clutch release lever shaft while the clutch cover is removed.
Have you experienced or do you know of premature failure of the water pump's mechanical seal or impeller seal?
kawvul is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
