VULCAN COOLANT LEAK KNOWLEDGE BASE
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 36
Thread: VULCAN COOLANT LEAK KNOWLEDGE BASE
  1. #1
    Slow Guy on a Fast Bike Extreme Forum Supporter trikebubble's Avatar
    Join Date
    Nov 2004
    Location
    Okanagan Falls, BC
    Posts
    25,217
    Exclamation VULCAN COOLANT LEAK KNOWLEDGE BASE
    This thread was created to consolidate and share information on this seemingly common issue. Please feel free to add any pertinant information, or pictures and schematics that may help other Vulcan riders find and repair these coolant leaks.
    It seems apparant that many Vulcan cruisers have issues with small coolant leaks. Both of my previous Vulcans (Mean Streak 1600 and vulcan 2000) had this problem.
    In my case, and as it seems in the majority of other cases noted here, the coolant leak is coming from loose coolant hose clamps. Again, from my experiance and the information gathered from others, the loose hose clamps are the smaller ones (around 3/4" diameter or slighlty larger) and are attached to coolant hoses that lead to or from the cylinders.
    So you want to buy a sportbike as your first bike and have questions?
    Please Read First:
    http://tinyurl.com/Clickie-the-linkie
    08 Midnite Sapphire Blue ZX-14
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Join Date
    Nov 2004
    Location
    Okanagan Falls, BC
    Posts
    25,217
    Default Re: VULCAN COOLANT LEAK KNOWLEDGE BASE
    The areas circled in red note the location of the loose hose clamps on my old Vulcan 2000, as well as my old Mean Streak 1600. I had to physically remove the tank and upper frame section on the V2K to access the clamps. I had to remove the rear tank bolt and prop it up to access the clamps on the Mean Streak.
    I tightened the clamps and all signs of drips and/or leaks went away.
    Please Read First:
  4. #3
    Every dog has it's day... BTK Expert 9511234's Avatar
    Join Date
    Sep 2008
    Location
    Lubbock, TX
    Posts
    1,102
    Are these the ones on the 1500? Are you talking about the clamps on the cylinders themselves or other clamps leading to the cylinder.
    Here's how they look on my 1500.
    Michael
    2007 Vulcan 1500 Classic
    More Harleys wave to me now that I have a fairing.
  5. #4
    Stoopit Moderator ULTIMATE Forum Supporter rbentnail's Avatar
    Join Date
    Jan 2005
    Location
    Asheboro, NC
    Posts
    8,425
    Yeah, those are the ones. Trike mentions specifically his Mean Streak and V2K but I had the same weepers on an '04 1500 Classic.
    Words aren't children and there's nothing wrong with killing them to clarify a point or keep the peace.
  6. #5
    Join Date
    Sep 2008
    Location
    Lubbock, TX
    Posts
    1,102
    So- just making sure before I put the tank back on-
    If I tighten those two hose clamps and the problem persists, I have bigger problems.
    I was hoping to see a lot more weeping from it- but it just seems dry.
    Before I put the tank on are there any other hose clamps for the coolant I should tighten, or is that it?
    Michael
  7. #6
    Join Date
    Jan 2005
    Location
    Asheboro, NC
    Posts
    8,425
    Ooh, it's been a while. Lessee, clamps between the cylinders, front of the rear and rear of the front were the weepers. Couldn't really see a leak just smell it. Took some talcum powder to find the traces of coolant. Clamps on the carb (n/a if you're FI I think). And just look around down in there, if there's a hose clamp then tighten it up.
  8. #7
    Join Date
    Nov 2004
    Location
    Okanagan Falls, BC
    Posts
    25,217
    I systematically went around and checked all the coolant hose clamps on the bike(s). The majority of the smaller diameter ones seemed loose and I tightened them. The larger diameter clamps (to/from radiator) seemed ok, though I checked them anyways.
    Please Read First:
  9. #8
    Forum Supporter Forum Supporter
    Join Date
    Oct 2006
    Location
    Albuquerque
    Posts
    4,724
    I had a problem with the pressure cap. Got it in cocked once and had to replace it. It would not re-seat after that.
    "Certainty of death. Small chance of success. What are we waiting for?" - Gimli
  10. #9
    Made It To Second Gear BTK Beginner sunshineNomad's Avatar
    Join Date
    Dec 2007
    Location
    Sunny Ft. Lauderdale
    Posts
    97
    Had the same trouble with my '05 Nomad. I used a blacklight/coolant dye and most of the clamp areas lit up. I tightened the clamps on my V2K at 5000 miles and all is ok. Seems like a factory defect situation.
    06 V2K Bagger
  11. #10
    Test Pilot BTK Expert Dudester's Avatar
    Join Date
    Sep 2006
    Location
    L'Orignal Ontario Canada (east of Ottawa)
    Posts
    2,913
    This is something I just have to do. I've been smelling rad fluid for a couple of years now, yet I see no evidence of any leaks anywhere. I've never removed the gas tank before, which is why I haven't tightened all the hose clamps underneath the tank.....yah, I know, I'm a big chicken. However, if someone could send me a link, with visual step by step explanation on how to remove the gas tank I just might give it a try once it warms up here. I'm tired of getting that smell, and something must be done. I keep checking my rad overflow bottle, which at times is a tad low, but hardly worth mentioning.
    Great thread, and I look forward to reading more about this Kaw problem. BTW way, I ride a 2003 Vuclan 1500 Carbed.
    2003 Vulcan Classic 1500
    195/60/16 Hankook Optimo H426 Darksider
  12. #11
    Forum Supporter Forum Supporter S.D.Willie's Avatar
    Join Date
    Jul 2006
    Location
    Long Island, NY
    Posts
    1,460
    same issue on my 06 1600 classic. Not visible but you sure can smell it. Will take the tank off when the weather gets nicer and have at this b*tch.
  13. #12
    Join Date
    Sep 2006
    Location
    Posts
    2,913
    Bump
  14. #13
    Join Date
    May 2011
    Location
    Mesa,Arizona
    Posts
    14
    I just did the 6,000 mile service on my 2004 Vulcan 500 yesterday. Though the reservoir never got low at all I've been smelling coolant since I bought it last month and could see a very small white trail down by the hose running from the bottom of the radiator to the water pump. I planned to replace that hose during the service. When I pulled the fuel tank off it was easy to see that the problem was actually at the hose to the coolant pipe in the top of #2 cylinder. The clamp just wasn't tight enough and the coolant was seeping out there. The spark plug area drain hole is right over the water pump so that's why the coolant was ending up down there. I went around and tightened all the clamps including the ones "hidden" by the fuel tank. After several test rides there is no more smell and everything is bone dry.
    Joe
    2004 Vulcan 500
  15. #14
    Join Date
    Sep 2006
    Location
    Posts
    2,913
    Quote Originally Posted by Turbojoe View Post
    Joe
    Hey way to go Joe, you beat me to it. I will be doing mine as soon as I have a free moment to concentrate on getting the task done. I have bee procrastinating enough, so this week, I'll try and git er' done. I know the problem is just a few loose clamps, but I've been a little scared of removing the gas tank, but I'm now determined, it's gotta get done, and I must stop putting it off. I'll report back once it's fixed, and I'll try and post some play by play pictures as I do it, to help some other poor procrastinating sap with hope that it will help them out and give them the confidence to do it.
    I'm also on the verge of replacing my motorcycle rear tire for a car tire, but that's another thread and discussion.
    Thanks for posting the results you got. Welcome to the forum and safe roads.
  16. #15
    Join Date
    May 2011
    Location
    Mesa,Arizona
    Posts
    14
    It took me less than 5 minutes to remove my tank for the very first time. One 8mm bolt on the instrument panel. Lift it up and disconnect the speedo and two electrical connectors and the panel is off. One 8mm bolt to remove the seat. Two vent hoses on the right side of the tank, one vacuum hose and the fuel supply hose on the left side, two 12mm bolts and off comes the tank. Easy as that. At least on my 500.
    Joe
    2004 Vulcan 500
  17. #16
    Join Date
    Sep 2006
    Location
    Posts
    2,913
    Thanks Joe, I know once I do it, I'll be kicking myself for having waited so long....DOH !
    On my 1500. the procedure is a little different than your 500, but basically the same.
  18. #17
    Join Date
    Jun 2011
    Posts
    5
    Help I too have a coolant leak but not from a hose, I wish it was that simple. I have a 95 vulcan 800 and I just noticed that I am leaking coolant from the pipe going from the top of the Right Engine Cover to the Crankcase. It's leaking from where it goes into the crankcase. It appears to be a seal issue but I am leary of taking off the cover (only way I can see to remove pipe) as I do not know what all I will need to replace if I do. I have the service manual but it is useless. It shows an exploded view, but no part numbers or descriptions or what needs sealant and so forth. Please help.
  19. #18
    Join Date
    Sep 2006
    Location
    Posts
    2,913
    Sorry Chaz, can't help you with your question, but I'm sure some of the more mechanical guru's here will chime in soon.
    In the mean time, here is a thread that I added some pictures on how to tighten the rad hose clamps, and removing the gas tank.
    http://www.kawasakimotorcycle.org/fo...se-clamps.html
  20. #19
    Join Date
    Sep 2011
    Location
    Las Vegas, NV
    Posts
    31
    I have the same issue with My Vulcan 900. I am noticing leakage from around the clamps. I have to find a way to loosen the tank, so that I can get in there and tighten the clamps. The owners manual is no real help. If any one knows how, please do share.
  21. #20
    Join Date
    Nov 2004
    Location
    Okanagan Falls, BC
    Posts
    25,217
    Quote Originally Posted by BlkSteele View Post
    I'm not sure how to loosen and/or remove the tank on the 900. Post a question in the cruiser thread about "900 tank removal" or something like that, and I'll bet you get the help you need.
    Please Read First:
+ Reply to Thread
Thread Information
Users Browsing this Thread
There are currently 2 users browsing this thread. (0 members and 2 guests)
  1. Coolant Leak on '04 Vulcan 500 LTD
    By tgd2007 in forum The Mechanics Corner
    Last Post: 11-13-2007, 05:59 AM
  2. Coolant Leak 96 Vulcan 800B Classic
    By firetec05 in forum Kawasaki Cruisers
    Last Post: 06-11-2007, 09:07 PM
  3. 04 vulcan coolant leak
    By lurch_chaos in forum The Mechanics Corner
    Last Post: 10-12-2006, 12:22 PM
  4. Vulcan 2000 Coolant Leak
    By dacvulcan in forum Kawasaki Cruisers
    Last Post: 01-15-2005, 02:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
