Old 10-17-2005   #1 (permalink)
bjones
Turtle Wax Taster
bjones's Avatar
Default Ethanol mandated in fuel now what?
The genuises in The Wisconsin Assembly have introduced a bill would require almost all gasoline to be blended with 10 percent ethanol.
My manual says avoid these types of fuel. will that void the warranty or worst cause me engine problems? what to do.....
http://vista.powerblogs.com/posts/1110526753.shtml
02 Drifter
Thunder Air Kit
PCM III
78 KZ 650
79 KZ 650
bjones is offline   Reply With Quote
Old 10-17-2005   #2 (permalink)
Xlr8n
Living on the dark side
Xlr8n's Avatar
Double check your manual. Most manufacturers approve of ethanol blends up to 10%, but discourage the use of any methanol blend and warn against fuel system damage with any methanol blend over 5%.
'03 1200 Sporty
Xlr8n is offline   Reply With Quote
Old 10-17-2005   #3 (permalink)
Norm
Loves to ride big V-twins
Norm's Avatar
My dealer says that some of the older models don't run well with ethanol. He said they have had to drain the tank on several. Maybe there is something you can add to make it run better. But, I think you may want to check it out. Contact your dealer and see if he has any new info on running ethanol.
RIP My good Friend Deron I'll miss you.
Norm is offline   Reply With Quote
Old 10-17-2005   #4 (permalink)
Xlr8n
Xlr8n's Avatar
I couldn't find any info for an '02, but here is a list of '03 requirements. You'll see Kawasaki approves of the use of 10% ethanol blends. : http://64.233.167.104/search?q=cache...ation s&hl=en
'03 1200 Sporty
Old 10-17-2005   #5 (permalink)
bjones
Turtle Wax Taster
bjones's Avatar
WHEW Thanks I start getting nervous ya know.... I feel A little better now
02 Drifter
Thunder Air Kit
PCM III
78 KZ 650
79 KZ 650
Old 10-17-2005   #6 (permalink)
Frankt07
Ridden like a Ford!
Frankt07's Avatar
i have heard and read the same xlr8n. no more than 10%. i think its for cleaner burning.
hey maybe we get a little HP as a bonus?
Frankt07 is offline   Reply With Quote
Old 10-17-2005   #7 (permalink)
BigJohn
Power Hungry V2K Rider
BigJohn's Avatar
Don't count in it. Figure that your milage may drop slighlty as well...
'00 Nomad
'06 V2K LT
Because RED is the fastest color...
BigJohn is offline   Reply With Quote
Old 10-17-2005   #8 (permalink)
1400pilot
UBER CLUB MEMBER #2
1400pilot's Avatar
yep.....how true........I could go on and on about ethanol and what is does to auto and trucks, but wont, just one word of advise.....avoid it at all costs!!!!!
Click for a map of the states I've ridden in
08 ZG1400 Concours
06 KDX200
04KX65
1400pilot is offline   Reply With Quote
Old 10-17-2005   #9 (permalink)
Frankt07
Ridden like a Ford!
Frankt07's Avatar
well there goes that out my tailpipes....LOL
Old 10-18-2005   #10 (permalink)
Scruffy
Scooter Trash!
Scruffy's Avatar
Blame California and Chicago...west coast fuel has been cut with up to 10% ethanol for at least 15 years. When I moved from Memphis to the Seattle area in late 2001, the fuels in upper Missouri, Iowa, South Dakota and eastern Montana all contained ethanol, some stations up to 15%. Western Montana, the Idaho panhandle, and eastern Washington had real gas, no alcohol except at BP/Arco stations. Western Washington, at least the "putrid sound" (Puget Sound) big 3 counties, you can't get decent fuel except at the race track or airport. My bike is down to about 41 mpg as of this evening's fill up...if it was a horse, I'd shoot it. Has dropped 11 mpg in a month and a half. And I just changed the plugs (properly gapped), so, it's the winter fuel blends... Get used to it, that pseudo-fuel is becoming ever more common.
-Scruffy
Eagle Scout. Veteran. Patriot Guard Rider.
1950s style Savage barhopper
1950s style VN800B bagger
Scruffy is offline   Reply With Quote
Old 10-18-2005   #11 (permalink)
tcobar
Can't find time to ride
tcobar's Avatar
Wow! I wasn't aware of this... I live in California.. does that mean that the "Premium V-Power" gas that I put on my Mean Streak is 10-15% ethanol? All this time I was thinking I was puttin in the good S**t. I'm assuming they are all the same %'s, no mater what brand I buy...? ... and nothing I can do about it... or is there?
tcobar is offline   Reply With Quote
Old 10-18-2005   #12 (permalink)
Scruffy
Scooter Trash!
Scruffy's Avatar
If the pump says "oxygenated", the fuel contains alcohol. Alcohol blends run cooler than straight gasoline. Do a "plug chop". If they look alright, you're okay. If they look "off" go up or down one heat range as indicated. Tuning and jetting to meet local conditions is just a normal part of owning a motorcycle. The occasional splash of ATF, 2 stroke oil, Seafoam or such will help. Couple caps once or twice a month is sufficient.
-Scruffy
I grew up on the west coast. I have yet to lose a bike motor to alcohol blend fuels. You just have to adapt the operating parameters a bit to compensate.
Old 10-18-2005   #13 (permalink)
Xlr8n
Xlr8n's Avatar
10% ethanol blended fuel has been used in the midwest for at least 25 years, and a good portion of the drivers in this region use it regularly with no issues, so I'm not sure what problems you're referring to???? Are you sure you're not confusing it with methanol gas?
'03 1200 Sporty
Old 10-18-2005   #14 (permalink)
MikeVanceinWI
I have been using 10% ethanol in all my vehicles for the last 15 years, with no side effects (Living between Milwaukee & Chicago you have no choice or drive over an hour to get non-ethanol gas) Even at a higher octane methanol has less energy then REAL gas but my 95 Nissan Pathfinder has had over 210,000 miles of ethanol eating and rund fine, bikes and atv's only have between 5K & 40K miles with no mechanical issues.
I do run a bottle of sea foam thru my vehicles every couple months to de-corn my carbs and injectors.
MikeVanceinWI is offline   Reply With Quote
Old 10-18-2005   #15 (permalink)
Hawkeye 1500
Riding keeps you young
Hawkeye 1500's Avatar
I've used ethanol since it came out. The only problem I've experienced was in a old garden tractor that the fuel line ran too close to an exhaust pipe. When it got real hot the ethanol would vapor lock quicker. But that was a design flaw of that tractor. Support our farmers use ETHANOL!
Hawkeye 1500 is offline   Reply With Quote
Old 10-18-2005   #16 (permalink)
1400pilot
UBER CLUB MEMBER #2
1400pilot's Avatar
we already are with our tax money in subsidies, now it will be mandated that we have to have only one choice of fuel............and besides it takes more energy to make 1 gallon of ethanol than it saves us.
and we also farm, used to raise corn too, but now with the surplus of grain it isnt worth the time/ cost to raise it , so we converted all of our acres to alfalfa.
08 ZG1400 Concours
06 KDX200
04KX65
Old 10-19-2005   #17 (permalink)
bud8fan
Wants better weather!
e85( ethanol) is bad on some of the rubber o rings and things in a fuel system...my '05 avalanche is flex fuel ready which means that it has a bigger fuel pump and all the rubber products have been changed out so to use e85.
Ethanol has a lower stoich ratio then gas. something like 6 or 7 to 1, where gas is 14.7 to 1. So even with an 85% mix, you still need 10-11 to 1 for complete combustion, so you use more fuel for the power it makes. (BTW these are guess on the figures, I didn't actually run the numbers )
I know in race cars, strait ethanol is good for about 10% more power over gas, plus it runs cooler, but you burn twice as much.
see you in the funny papers!!!
'04 1500 vulcan classic.
'05 avalanche z-66 blown
bud8fan is offline   Reply With Quote
Old 10-19-2005   #18 (permalink)
bross
Let's Ride!
Been running it here for years with no problems.
Originally Posted by team ftb
I believe we let the research get in the way of good times far too often.
bross is online now   Reply With Quote
Old 10-19-2005   #19 (permalink)
Xlr8n
Xlr8n's Avatar
e85 is 85% ethanol. I was referring to 10% ethanol. Quite a difference there. No problems with fuel system components with a 10% blend. Not sure what the quote to my statement was referring to???
'03 1200 Sporty
