LinkBack | Thread Tools |
Turtle Wax Taster
I’ll be finishing up the intake, exhaust and power commander install on my 2005 Mean Streak this weekend. I live in Jacksonville, Florida and found someone who will tune the bike. They list two alternatives: (1) a regular dyno tuning with custom map for $250 or (2) an advanced tuning with custom map for $300. They said with the advanced tuning they would tune each cylinder where the regular tuning just tunes the engine overall. Which one should I choose?
Also, it’s colder than normal here in Florida. Ok it’s not snowing, but it’s not your typical 90 degree weather either. Should I wait until the summer to tune the engine? Will there be much difference in the warmer months if I have the engine tuned now? Will I need two maps one for winter and one for summer or can I have the bike tuned now and make adjustments myself for the summer months if needed? Thanks MC |
Deerslayer &
Depends what you want...a)know you did the best you could do and squeeze out every last HP and in-lb of torque, or b) know you got 99% of what is available at the current environmental conditions and current conditions of your engine (sensors, etc.) and won't likely tell the diff, unless you are planning to go to the track.
As far as when to do it, your FI bike senses air temp BUT makes alterations as air temp changes based on what is stored in the ECU and THAT is based on the stock machine, different than what you now have. If the dyno is located outside and you have runs with 50 degree ambient temps, I would not do it now. But if the dyno is inside and air temps are 70+, I would think it good 'nuff for the typical range of biking temps. Oh, I also would watch humidity at the inlet; don't do it on a rainy day. Again, to each his own, the diffs are small, IMHO, and doubtful you will 'feel' the diff when you run the bike.
T-man VROC #12333 2005 V2K Ltd 2001 1500 Classic FI http://www.geocities.com/tensman_99/mcpics.html |
#4 (permalink) |
Posting Slacker
![]() Join Date: Nov 2004
I have paid for 2 custom maps/dyno runs and I don't use the maps I got from the dealer. I use a map from the internet. I have run literally dozens of VERY different maps and have found only minor differences in performance. I've been using the "Bub Jug Huggers exhaust and Thunder Manufacturing Tornado air intake" map off the Powercommander.com site all season and love it. It's and advanced map in 250 RPM increments, I think the guy knew what he was doing. Can't hurt to try it.....
R.I.P. Deron |
#5 (permalink) |
Ridden like a Ford!
uf-engineer
is this shop a dynojet authorized tuner? if so, go for the advanced tuning. i learned the hard way ($700) that i should've gone to the dynojet shop the first time my suggestion is go for the advanced
2001 Black Mustang GT 2005 Phantom Silver 1500 Classic Royal Purple synthetic oil in both |
#6 (permalink) | |
RIP Brother Deron
Frank, can you send me a link to where you found that map? Sounds like I may want to try it in the spring. Thanks man.
2005 V2K Ltd "I'll ride the wave where it takes me, I'll hold the pain release me" |
#7 (permalink) |
Can't find time to ride
I have the map and want to upload it, but the attachement system tells me that I don't have room and will not allow me to upload?
#8 (permalink) |
Here are some of the previous posts with some of the maps ready to download... Also, some good information to read on ...
http://www.kawasakimotorcycle.org/fo...ommander+M ap http://www.kawasakimotorcycle.org/fo...ommander+M ap http://www.kawasakimotorcycle.org/fo...ommander+Ma p However, there is a better Map. Has two fuel tables, one per cylinder. After trying them all, I stuck with this one. I wanted to post it here, but the attachement system won't let me .... |
#9 (permalink) |
Rides a lazyboy on wheels
If you look at the advanced maps you'll see that the two cylinders are mapped quite differently. I picked JohnnyCheese's brain a while back and he recommended advanced maps for 2-2 pipes such as the HK's. I just have a basic map
Phatboy 04 1600 Classic Black 02 Dodge Cummins |
#10 (permalink) |
Posting Slacker
Here is the link to the map I'm talking about... I think it's also the one Tony is refering to:
http://www.powercommander.com/maps/0...S/m215-005.exe It's an advanced map... one for each cylinder. Runs great on my bike. Tornado kit, PCIII and Cobra Speedsters (also 2-2).
R.I.P. Deron |
#11 (permalink) |
Red Lodge Approved
Using a shared map is better than nothing... BUT... that map was made for a different bike, elevation (?), exact mods (?), riding style (?).. I would get a custom map, but ONLY if the person doing it is reputable.. nothing better than a bike with a custom map..
Ian 2005 Kawasaki V2K - Black I wouldnt trust a man that didnt try to steal a little... |
#12 (permalink) |
Way Too Much Free Time
Depends on how much 300 dollars is to you. Personally around Christmas the money would have a different function for me. I would try the download maps first. If I did take it to get it tuned though, I would go all out and get the best.
87 vn1500b 88se Jardine pipes stage 1 jet 87 Gl1200I Goldwing load up, head out. |
#13 (permalink) |
Turtle Wax Taster
Yes they are an authorized dyno'er. They are the only authorized dyno'er who have the TL tuning function. I'm not sure what TL tuning does. Power Commander said that it make tuning the bike easier. If an internet map works, I'll probably wait for the summer to do it.
Thanks All |
#14 (permalink) |
RIP Brother Deron
I am currently running a map that Frank (kingofwings) genorously shot my way last spring. The gains over stock are very noticeable. I don't really have a concerns about having my bike personally dyno'd (not that their is any authorized shop within 250 miles anyway) and will likely swap over to another map next springthat Frank mentioned above.
#16 (permalink) | |
Red Lodge Approved
Plugs also...
#17 (permalink) |
I saw a device on the internet that was supposed to let you tune it by the color of the flame in the chamber. I will see if I can still find that. Seemed interesting. Plugs will do the same you just have to wait longer to see the results.
#19 (permalink) |
I know what you mean. I felt the same way the first few times I turned a wrench on it but I am getting more comfortable with it not being as fragile as we think.
#20 (permalink) | |
RIP Brother Deron
The map I am currently running, the one from Frank, has 15000km on it and hasn't missed a beat. I have run my bike at speeds of 75-80 mph for the better part of an hour without any negative effects. i have run it at great altitude, packed with gear, extreme heat, cold, rain etc. and never have i had a problem. I geuss it depends on where you get a map from, but again i have been happy with what I am running so far.
