Old 12-27-2005   #1 (permalink)
joecruiser
Foil Inspector
Default Replacing Stock Air filter with K&N
Hello Everyone,
My name is Luis Dominguez and I'm new to the group. I started riding again two months ago after a 15-year hiatus and enjoying every bit of it.
I did have a question regarding the use of a K&N filter on a stock VN1600. Do I need to install a Power Commander or TFI when swapping out the stock air filter with a K&N air filter. From what I know, this particular model comes lean from the factory. If after market intake air kit or pipes are added, owners must also install a FI management device such as Power Commander or TFI. However, I don't know if this would apply to just a plain air filter swap. I've already swapped out the stock filter with a K&N filter and the bike feels and rides better through all the gears. The biggest concern I have is with damaging the bike due to the increased airflow (as slight as it may be). The consensus from different people I've corresponded with is that it is not required due to the already restricted plumbing with the stock intake and any additional air flow from the K&N is negligible. I'm trying to get as many opinions as possible. Ideally, from someone who currently runs just a plain ole K&N with a stock intake. Thanks in advance.
joecruiser is offline   Reply With Quote
Old 12-27-2005   #2 (permalink)
troop
Way Too Much Free Time
troop's Avatar
Nope, you won't need a PCIII/TFI/etc just by swapping out the stock filter with a K&N. I ran a K&N in stock housing on my 1500 FI w/o any probs. Troop
Summer is hear !! "Road construction next 15 miles"
www.cruisercustomizing.com/troop
troop is offline   Reply With Quote
Old 12-27-2005   #3 (permalink)
Frankt07
Ridden like a Ford!
Frankt07's Avatar
i am running a K&N and pipes and i installed a PCIII and had it dyno tuned too.
i dont think just a K&N will do anything, but you should really look into freeing up the exhaust.
2001 Black Mustang GT
2005 Phantom Silver 1500 Classic
Royal Purple synthetic oil in both
Frankt07 is offline   Reply With Quote
Old 12-27-2005   #4 (permalink)
Cabo
Can't find time to ride
Cabo's Avatar
I had the dealer tell me to disconnect the battery for 30 minutes when switching over. Suppose to reset computer when you crank it up...
Cabo is offline   Reply With Quote
Old 12-28-2005   #5 (permalink)
joecruiser
Foil Inspector
Thx for the info guys
Constrictor's Caddman Air Mod Tutorial (56k Warning) Constrictor Projects and "How To" Write Ups 265 10-09-2009 09:22 AM
K&N Air Filter Change Future The Mechanics Corner 4 08-31-2005 12:33 PM
K&N Air filter Trans101am Kawasaki Cruisers 0 12-20-2004 05:00 PM
K&N Air Filter/Wagner LazerBlue H4 Bulb - 04 Nomad FI dfgpilot Kawasaki Cruisers 8 09-12-2004 05:44 AM
Kawasaki ZN1100 K&N air filter retro help dynapl The Mechanics Corner 3 06-18-2004 03:51 PM
