Battery issues - Kawasaki Motorcycle Forums
 1Likes
post #1 of 15 (permalink) Old 03-19-2017, 11:02 AM Thread Starter
Junior Member
Question Battery issues
I just replaced the battery on my 2006 Vulcan Nomad. After I replaced it the bike cranked and ran fine. Turned it off for a little while and tried it again and it cranked up just fine. Three days later I wanted to go for a ride and it wouldn't crank. When I turn the key on no lights come on Nothing!!! HELP?!?! Any suggestions?
Thanks in advance
Paige H Bell is offline
Sponsored Links
Advertisement
post #2 of 15 (permalink) Old 03-19-2017, 12:27 PM
Politicians' Nightmare
Hot Cruiser's Avatar
Welcome, Paige! Even though the battery was just replaced, suggest checking it with a multimeter to make certain that it is OK - voltage should be at least 12.7. Also check the battery terminals for tightness and the cable terminals for corrosion. If the voltage is OK, then suggest checking the fuses, especially the main fuse to make certain that they are OK - use a meter set to check continuity. If all is OK so far, have the battery load tested (many auto stores will do so at no cost) - it is possible for a battery, even a new one, to have good voltage but when subjected to a load to have no electrical output. Good luck!
Jim
'07 Vulcan 900 Classic LT
Jesus is Lord
Hot Cruiser is offline
post #3 of 15 (permalink) Old 03-19-2017, 01:05 PM
Member
Thanks in advance
I would also check for some kind of draw. You may have something that is staying on. Which will also drain your battery. If you can't find something. Hook up quick disconnects and keep it on a trickle charger. Especially if you aren't going to ride every day.
Sent from my iPhone using Tapatalk
bullcrapallday is offline
post #4 of 15 (permalink) Old 03-19-2017, 02:40 PM
Senior Member
Ole Yeller's Avatar
If the battery check reveals that it is fully charged then, I would check the clutch safety switch for corrosion or bad connection.
bullcrapallday likes this.
4 cylinders are better than 2
1985 ZL900 ELIMINATOR
Ole Yeller is offline
post #5 of 15 (permalink) Old 03-20-2017, 11:18 PM
Senior Member
Jimray23's Avatar
I havent heard of the vulcans doin this but, i have to keep my kickstand insulated from touching the ground or it will drain my battery in a couple days. I just put a rubber mud flap under my kickstand.
Jimmy
1979 kz1000 ltd mkii
dyna s ignition, dyna 3 ohm coils, solid copper core plugs, full rewire.
Jimray23 is offline
post #6 of 15 (permalink) Old 03-21-2017, 11:07 AM
Senior Member
Jimmy
Something wrong with your bike.
sfair is offline
post #7 of 15 (permalink) Old 03-21-2017, 12:06 PM
Senior Member
Jimray23's Avatar
Probably but ive had a few of these kz's and they were all the same.
Jimmy
Jimray23 is offline
post #8 of 15 (permalink) Old 03-21-2017, 01:10 PM
Grade "A" Poser
Hilts's Avatar
Garage
Jimmy
Must be a kz thing. I've ridden with a lot of Vulcan riders and not once heard of a Vulcan's battery draining because the kickstand is in contact with the ground.
[SIGPIC][/SIGPIC]
2003 Vulcan 800 Classic - Metallic Ruby Red
2010 Harley Davidson Electra Glide Ultra Limited
Hilts is offline
post #9 of 15 (permalink) Old 03-21-2017, 03:15 PM
Senior Member
Not a KZ thing....something wrong there....
sfair is offline
post #10 of 15 (permalink) Old 03-21-2017, 06:57 PM
Senior Member
Here's how to check a battery on a Load Test
1. Adjust voltmeter to DC volts (20 volt range).
2. Place voltmeter leads to the battery terminals. ( positive to positive and negative to negative)
3. Watch the voltmeter as you start your motorcycle.
4. If the voltage drops below 9.5 volts, the battery has very low capacity and should be replaced.
wsim is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
