'81 KZ550 LTD leaky petcock bolts - Page 2 - Kawasaki Motorcycle Forums
 2Likes
post #11 of 43 (permalink) Old 05-13-2017, 06:44 AM Thread Starter
Junior Member
Garage
Finally got around to putting in the factory washers and reinstalling the petcock again yesterday. Nogo!! ))8 sheeesh.
After bolting the petcock back on, I poured a cup of gas into the tank and held it up then tilted back to check for leaks.
It still leaks a little from the bolts and it appears a little from the oval o-ring. The underside of the tank isn't perfect but it's not that bad and didn't leak when I got it. Other than unbolting the petcock for paint and cleaning with thinner.
Am wondering if anyone has done anything to make sure that area is smooth and flat. Am thinking about spraying a really
thin coat of primer on that area then sand it flat with a block and #320 thru #600 paper. If that doesn't work will try some Seal All then finally, use it for drop kick practice. (8
bille6 is offline
Sponsored Links
Advertisement
post #12 of 43 (permalink) Old 05-13-2017, 03:11 PM
Member
Try plumbers tape on your screws War there has to be some type of sealer you can put on your screws
Sent from my SM-J327P using Tapatalk
2013masterchef is offline
post #13 of 43 (permalink) Old 05-13-2017, 03:11 PM
Member
Or the bolts
post #14 of 43 (permalink) Old 05-13-2017, 03:15 PM Thread Starter
Junior Member
Garage
Originally Posted by 2013masterchef View Post
Or the bolts
Yup there are a few types. A commonly available one is called "Seal All" and you can get it at Home Depot, Walmart, Advance Auto Parts... the thing that worries me is the threads shouldn't need to be sealed if everything else is right but I can't find anything wrong. Starting to wonder if the petcock base has a hairline crack or something.
thanks for replying!
bill
bille6 is offline
post #15 of 43 (permalink) Old 05-13-2017, 03:20 PM
Member
Do you have a modifying glass in your toolbox they're good look for hairline fractures and cracks
post #16 of 43 (permalink) Old 05-13-2017, 03:24 PM Thread Starter
Junior Member
Garage
I'm afraid you have me at a disadvantage. What's a modifying glass?
bille6 is offline
post #17 of 43 (permalink) Old 05-13-2017, 03:33 PM
Member
Lol magnifying glass
post #18 of 43 (permalink) Old 05-13-2017, 03:39 PM Thread Starter
Junior Member
Garage
Apologies I should have realized that!! The answer is "ehyep". I looked but didn't see anything. The reason I now suspect something like that is because of those times when I reinstall the petcock and it doesn't leak until I push the rear tank post back into the frame grommet, at which time it begins to leak. Sometimes drip drip and others it just pours out....
bille6 is offline
post #19 of 43 (permalink) Old 05-13-2017, 03:43 PM
Member
Funny u got a sexy kiwi next to the Suzuki lol
post #20 of 43 (permalink) Old 05-13-2017, 03:47 PM Thread Starter
Junior Member
Garage
thank! Am also making a huge mess...too many things going on at once. I thought this one would be behind me weeks ago!
)8
cheers,
b
bille6 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
