1999 kz1000p - Kawasaki Motorcycle Forums
post #1 of 4 (permalink) Old 05-12-2017, 09:43 PM Thread Starter
Junior Member
1999 kz1000p
So I have a '99 KZ1000P former police bike that I'm fixing up. I haven't done a lot of work on bikes, just cars. I have a new replacement switch assembly (start, siren, headlight etc). In order to replace this switch assembly I clearly have to disconnect the throttle cable brackets that screw in to the bottom of the assembly. What is the proper way to go about this?? Am I supposed to completely disconnect the cables at the carbs in order to do this? Thanks for any help.
bloodhound is offline
Sponsored Links
Advertisement
post #2 of 4 (permalink) Old 05-14-2017, 08:28 PM Thread Starter
Junior Member
Anyone? Here's a pic of the throttle cable brackets I'm referring to.
post #3 of 4 (permalink) Old 05-15-2017, 09:09 AM
Senior Member
martin-csr's Avatar
Howdy. The barrel adjusters are already turned in all the way, so there may not be any available slack at the throttle. So you're probably going to have to disconnect the cables at the carburetors. You could try removing the handlebar control screws, then try to separate the 2 halves to see if it will come apart. More than likely, though, you'll probably have to disconnect the cables at the other end. On my KZ650 I can turn in the adjusters at the carbs & at the throttle to get some slack. from the diagrams at Partzilla for the 1000P, there doesn't appear to be much adjustment available at the carb ends.
martin-csr is offline
post #4 of 4 (permalink) Old 05-15-2017, 05:41 PM Thread Starter
Junior Member
Ok thanks for the reply, I will give it a shot!
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
You may post new threads
You may post replies
BB code is On
