91' vulcan 500 exhaust question
+ Reply to Thread
Results 1 to 8 of 8
Thread: 91' vulcan 500 exhaust question
  1. #1
    Join Date
    Jan 2006
    Location
    NC
    Posts
    11
    Default 91' vulcan 500 exhaust question
    I managed to get a pair of new old stock cobra mufflers for my newly acquired en500a. Unfortunately, to install, I have to cut the original pipes just in front of the crossover which I won't do until I get a spare set of pipes to screw up instead. At least then I'll be able to go back to stock.
    My question is: if I install the cobra mufflers, is rejetting the carb necessary?
    I tried the cobra website for info but these pipes are legacy items that aren't made/supported anymore.
    Any help/suggestions would be appreciated.
    Thanks
    Storch
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Official BTK Forum Pot Stirrer Extreme Forum Supporter Spok's Avatar
    Join Date
    Mar 2004
    Location
    Mount Vernon, Washington
    Posts
    37,377
    if your just adding pipes, no jetting is necessary.
    good luck on your project
    AUGUST 2006 MOM
  4. #3
    Join Date
    Jan 2006
    Location
    NC
    Posts
    11
    Great news! Just picked up a good used exhaust system on ebay for $65. Had a crack in the crossover but that's going to be cut off anyway.
    Thanks Spok.
  5. #4
    Rebel Rider BTK Expert bluestringer's Avatar
    Join Date
    Jul 2004
    Location
    Albany, Georgia
    Posts
    3,644
    Quote Originally Posted by storch
    Thanks
    Storch
    Must have changed them after the 90's. The ones I've seen have mufflers that clamp on. On the one I had I just removed the stock mufflers and clamped on the aftermarket ones.
    And no, you don't need to rejet the carbs.
    bluestringer
    2005 Vulcan 1500 Classic FI
    V&H Longshots
    VROC #13910
    GAVROC #159
  6. #5
    Join Date
    Jan 2006
    Location
    NC
    Posts
    11
    Default exhaust gasket question
    does anyone know the size of the exhaust gaskets (ring gasket between header pipe and head)?
    it's a principle thing...not an expensive part...but the dealer near me is way to high
    I can get a good deal on these from a 3rd party but need to know the diameter of the stock gasket.
  7. #6
    Join Date
    Jul 2004
    Location
    Albany, Georgia
    Posts
    3,644
    www.ronayers.com
    bluestringer
    V&H Longshots
    VROC #13910
    GAVROC #159
  8. #7
    Join Date
    Jan 2006
    Location
    NC
    Posts
    11
    Quote Originally Posted by spok
    Ok, got this on another listserve. Now I don't know what to do.
    http://www.wrench-wench.com/maint/maint-kaw-baffles.htm
    Seems like a lower restriction exhaust might affect backpressure and lean out the mixture, making things heat up too much. The last thing I want is the new exhaust blueing.
    Hmmm....what do you guys think about this posting?
  9. #8
    Join Date
    Jul 2004
    Location
    Albany, Georgia
    Posts
    3,644
    Go to JC Whitney and get a set of generic clamp on mufflers. They come with adpaters to fit different size headpipes, and they have baffles. There will not be enough difference in back pressure to tell any difference. Open up the air/mixture screw a quarter turn or so to richen up the mixture. Worked fine on my 500, but remember it's not a v-twin and will sound like a 4 banger on steroids with low restriction exhaust (can you say fart can). The stock pipes sound much better.
    bluestringer
    V&H Longshots
    VROC #13910
    GAVROC #159
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Kawasaki Vulcan 500 Exhaust
    By samarnold55 in forum Kawasaki Cruisers
    Last Post: 01-03-2010, 02:51 AM
  2. Exhaust for 500 Vulcan
    By Polo Marco in forum Kawasaki Cruisers
    Last Post: 08-06-2005, 09:15 PM
  3. Question about the 500 Vulcan Roadster
    By cboutfit in forum Kawasaki Cruisers
    Last Post: 01-18-2005, 05:48 PM
  4. 94 Vulcan 500 speedo cable routing question
    By mikeyc222 in forum The Mechanics Corner
    Last Post: 09-04-2004, 11:41 AM
  5. 95 Vulcan 500 Exhaust
    By High Voltage in forum Accessory Swap Meet
    Last Post: 05-31-2004, 09:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
