LinkBack | Thread Tools |
Made It To Second Gear
Hi.
Recently went to the 06 International Bike Show in NYC to check out the new bikes,gear, and tires. It was a great 180 mile round trip run with Sun and 30 degree temps. Got to park the bikes on the Grounds of the NYC Javitz Center about 50 feet from the entrance for "Free"!!(definate added plus) I've been looking to change from the Bridgestone Exedra Tires and try something new. The Bridgestones have given me great service. I now have 20,000 on the original front tire. I got 11,700 on my original rear tire and 8,300 on my 2nd rear Exedra tire. Got to talk with the tire reps from Avon, Pirelli, Dunlop, and Metzler. Decided to go with Metzler Tires - Marathon 880 Will be getting them from American Motorcycle Tire http://www.americanmototire.com/ Not sure about doing this. The rep talked about a doing what they called a "Stage 1" for the Rear Tire Putting on a 165/80/16 75H Marathon 880 What the Stage 1 does: 1) Offers a tire that fits properly on the factory rim. 2) Still provides plenty of clearance under the fender and frame area. 3) Provides a 91lb increase in carrying weight compared to the stock tire. 4) Has only a 2mm increase in overall tire diameter with a slight increase in width. Nice appearance. 5) H Speed Rated 6) Considered no noticeable change to bike ride. Sounds good!! Any thoughts or coments on this shall be appreciated Dfgpilot
2004 Nomad FI Vance & Hines Dyno Jet PCIII/usb K&N Air Filter |
#4 (permalink) | |
![]() Join Date: May 2004
However, I was struck by your milage comments on the Bridgestones But my milage on my rear 05 Nomad tire was 5500 miles and down to .025", which is pretty darn low for a motorcycle tire IMO. Sure I run the tires on my old Ford Explorer down to bald, but never on a motorcycle (its kinda like ignoring an engine noise in an airplane -if it dies is use you are screeeewed My front tire is worn about 1/2 way down to the safe limit, so it looks like the standard 2:1 ratio on back tires wear vs front tire wear. But how did you manage to to 11700 miles on a Nomad OEM back tire -amazing ! ![]() OH wait, your not one of those Canadians are ya ? Didn't consider these numbers might be some funky kilolitermillynanograd type thingies
05 Nomad/V&H Baggers/PCIII/Caddman Risers/Lights/Lowers/Chaps www.home.earthlink.net/~mthompson61 Last edited by Plato : 02-06-2006 at 05:03 PM. |
#5 (permalink) |
Hey guys Thanks for the input. Knew I could count on the forum.
Plato, No not from Canada. But I stayed at a Holiday Inn once which made me smarter? LOL Anyway.... In regards to how I got that kind of mileage out of the rear tire. I pushed it Most is from Bridgestone & Goodyear Tire Sales Training and thru personal experience ( I serviced and sold tires for 25+ years) This may be more imput than you wanted to know - 1) Maintain proper air pressure for your type of riding. The manufacturer recommends a tire pressure as a guide line. (Its not the bible.) Example - If you do alot of 2 up riding you need to keep the pressure up. Riding solo you might wish to drop the air pressure a couple of pounds 2) Trips riding more than a couple of hrs you should increase the air pressure about 2 lbs(never more than the max cold tire pressure rating). This makes up for the tire expansion. It keeps the tire cooler by reducing the flex action of the side wall and maintaining the round shape of the tire.( Too much side wall flex from too low of an air pressure creates alot of heat which in extreme conditions can produce a tire failure) 3) Tire Balancing - About 10% of tire wear comes from out of balance tires. You may not notice any major shimmy or vibration while riding since alot is absorbed through the much improved bike suspensions, however, the small amount of vibration reduces treadlife by causes a scuffing action on the tread surface. Fact is that as a tire wears the balance of the tire changes. The rim stays the same weight but the tire doesn't as the tread is worn down. 4) Road Surface - The type of road surface makes a difference in tread life longevity. Asphalt is best,next concreate, and dirt roads the worst. Bottom line you'll go through 2 rear tires for every front tire So guys keep the Shiney Side UP
2004 Nomad FI Vance & Hines Dyno Jet PCIII/usb K&N Air Filter Last edited by dfgpilot : 02-07-2006 at 08:15 PM. |
#6 (permalink) |
Power Hungry V2K Rider
![]() Join Date: Apr 2005
DF - Thanks for the post. I'm running 880s, but in stock sizes. I'll make note of the Stage 1 size for later. 91 pound increase? Excellent! I can use that...The margen of safety is slim right now.
'00 Nomad '06 V2K LT Because RED is the fastest color... |
#8 (permalink) |
I have Michelin Commanders on my 1500 and they have done very well. I have over 11,000 miles on them now. I'm looking to replace the back tire soon as it's ready to change out. I've always kept the tire pressure at 38 front and 40 rear.
#9 (permalink) |
Thought I would post the links on the Metzler Tire Upgrades
Nice to know stuff. Hope you riders can use the info: http://www.us.metzelermoto.com/metze...c_upgrades.htm http://www.us.metzelermoto.com/media/metric_upgrade.pdf
#11 (permalink) | |
Slow Guy on a Fast Bike
That's a movie right? Michelin & Commander, with the Aussie guy and the ships?
08 Midnite Sapphire Blue ZX-14 |
#12 (permalink) |
In Search of Perfect Tune
![]() Join Date: Jun 2005
The rear rim on my 2000 Nomad was/is 3.5" and can therefore accomdate up to a 160 size tire (acccording to Avon specs at www.avonmotorcycle.com); the front rim is 3.0" and can only go up to 150 (otherwise you get "cupping"). Don't know what the rear rim width is for the 2004 Nomad. My two favorite touring tires are Metzler Marathon and Avon Venom X.
2006 Black Nomad w/ TFI O2 Sensor Roadhouse 2/1 If you can't dance it's too late to plow. |
#13 (permalink) |
UBER CLUB MEMBER #2
![]() Join Date: Jan 2005
I have been very happy with the factory bridgestones on my 1600, I got over 10,000 on the factory rear before I replaced it with the same tire, and 17.000 now on the factory front, and I will be replacing it this spring
#14 (permalink) |
NY Guy is right the largest rear tire that works for that bike is the 165/80/16
The 1600 Nomad has a wider rim on the rear to accomodate a 175/70/16 tire I've just got both tires in a few days ago. Plan on seeing my dealer in the next couple of weeks for install. I'll post the expenses for the maintenance and give a first impression on the tires overall performance.
#18 (permalink) | |
I do not know if there is a recommended upgrade for the stock rim on the 06 Nad. However, here is the tel #s for Metzeler Tire tech support Customer Support -- Tollfree: 1-800-747-3554, option 4 (followed by #) Direct: 1.706.368.5826 Fax: 1.706.368.5879
#19 (permalink) |
Results after 5,000 miles on the Metzeler Stage 1 Rear Tire Upgrade for the 04Nomad.
Installed Metzeler Marathon 880's Front tire-150/80H16 Rear tire Stage 1 Upgrade - 160/80H16 Quite pleased with the tire. No unusual tire wear. No cupping Great traction, wet & dry. Quiet tires. Conclusion: Worth the change. An increase of 92lbs on rear tire load carrying capacity(nice plus). Looks great!
| Rear tire max size?? | blue meanie | Kawasaki Cruisers | 14 | 01-13-2006 05:32 PM |
| Prarie 650 New Rear Tire Size? | NovaPwr | Kawasaki ATV and Mule | 2 | 01-06-2006 10:00 AM |
| Prarie 650 New Rear Tire Size? | NovaPwr | Kawasaki Motocross and Offroad | 4 | 12-20-2005 02:55 PM |
| Rear Tire Size 800a ??? | rebeldog0085 | Kawasaki Cruisers | 6 | 10-01-2005 01:02 AM |
| New Rear Tire Size | brancher | Kawasaki Cruisers | 9 | 06-26-2005 02:44 AM |
