Old 03-04-2006   #1 (permalink)
Constrictor
Way Too Much Free Time
Constrictor's Avatar
Send a message via AIM to Constrictor
Default New Parts to Install
Today I got my second order of parts to install on the bike this spring. I'm pretty excited about everything since I am replacing everything with LEDs (except the headlight obviously), but I really think things will look pretty cool!
Here is what I got starting in the upper left corner going clockwise:
1. Custom LED install kit
2. 11 orange LED pods from Custom Dynamics - I have four 5 LED pods, four 4 LED pods, and three 3 LED pods...should look cool when installed
3. Tirewise 38 PSI valve stem covers...these have a green line when theyre above 38 PSI, and turn red if they go below that. I normally keep my tires around 40, but I wanted a little bit of threshold for temp reasons.
4. Chrome wire loom and zip ties...should make the LED install cleaner.
5. Kuryakyn Red (for the rear) and Amber (for the front) turn signal bezels - I didnt want to get totally aftermarket turn signals, but I didnt like the look of the stockers. These wont be a 100% straight fit, so I'll have to modify my existing turn signals to make them work, but I am confident I'll be able to figure it out. I'll definitely post some pix when its done.
6. Mustang leather fender bib for my seat. Just something to cover the rear fender when I am riding solor.
7. Clear Alternatives LED tailight cluster....this should just look cool.
8. TMI 18 LED turn signal amber and 18 LED turn signal red turn signals - I did a lot of research on various LED turn signal solutions and these seem like the ones that will work the best for what I want to do. I dont want to sacrifice brightness of the stock bulbs, but want the coolness of LEDs. I'll keep everyone posted on how these turn out...for now, here are some pix:
9. Radiantz LED illuminated license plate frame - These used to be over $100 at some places, but recently a new chrome version has come out that I picked up for $30 at Custom Dynamics. I already have my plate mounted on the side, but have no illumination. This will keep me legal and look cool! Here is a pic:
I'm pretty excited about everything and look forward to the install. I will definitely take a lot of before, during, and after pix to share with you as well. I am guessing I should have this done by the end of March!
2005 Magma Red Kawasaki Mean Streak 1600
1998 Bright Red Pontiac Trans Am 405.5 RWHP 385.1 RWTQ
2004 Nighthawk Black Honda Accord EX 6-speed
Constrictor is offline   Reply With Quote
Old 03-04-2006   #2 (permalink)
kc6wfs
Plasma Blue
kc6wfs's Avatar
Thats slick. I have been thinking of doing the same to my bike.
Where did you order from??
Dave
2007 Vulcan 900 Custom Plasma Blue --
www.myspace.com/nitrophotos
kc6wfs is offline   Reply With Quote
Old 03-04-2006   #3 (permalink)
Phatboy
Rides a lazyboy on wheels
Phatboy's Avatar
Right on. I think you'll be impressed with those deep dish bezels. Based on your posting history, I'll just sit back and wait for the 'after' pics
Phatboy
04 1600 Classic Black
02 Dodge Cummins
Phatboy is offline   Reply With Quote
Old 03-04-2006   #4 (permalink)
jollyrogr
you didnt mention a load equalizer...you will need one for use with those LED turn signals.
One other thing, if you replace all the lights on your bike with LED's that means less draw on your electrical system. Your regulator will run hotter then wont it?
BLACK 2K6 MEANSTREAK
R.I.P. 2K4 MEANSTREAK
jollyrogr is offline   Reply With Quote
Old 03-04-2006   #5 (permalink)
Xlr8n
Living on the dark side
Xlr8n's Avatar
Constrictor- I was under the assumption that the Kuryakyn lenses were a direct swap for 1600 classics and MS's. Let me know how the install goes as I was getting ready to order these for the front. I was just about to ask for some pics of the lights when your done, but then I came to my senses! Constrictor + mods = tons of pics!
'03 1200 Sporty
Xlr8n is offline   Reply With Quote
Old 03-04-2006   #6 (permalink)
Spok
RIP Deron - 1400Pilot
Spok's Avatar
dang, talk about filling up a dance card. thats a tonne of stuff to add.
i wanna see pictures pictures and more pictures
AUGUST 2006 MOM
Spok is offline   Reply With Quote
Old 03-04-2006   #7 (permalink)
1400pilot
UBER CLUB MEMBER #2
1400pilot's Avatar
those deep dish bezels look awesome, I put them on my bike a couple weeks ago!!!! really helped with the look of the bike
Click for a map of the states I've ridden in
08 ZG1400 Concours
06 KDX200
04KX65
1400pilot is offline   Reply With Quote
Old 03-04-2006   #8 (permalink)
Constrictor
The Kury deep dish bezels are not a direct replacement for the Mean Streak. They might work on the Classics or other Kaw bikes, but they are designed only for turn signals whose bezel is mounted via a single screw on the bottom of the signal housing.
The Mean Streak uses two screws that goes directly through the face of the bezel to secure. If you look at the Kury bezels and then look at the stock Mean Streak bezels, you'll see two screws going through the face on the stockers, but there is no place on the Kury's to mount like that.
Looking at the Kury bezels and the stock Mean Streak ones, I am confident that with some careful grinding with my Dremel, I can modify the stock housing to make it work. I'll just need to use a glue gun to hold it all together. Since I am using LED bulbs which generate very little heat, and last significantly longer than bulbs, I shoudln't ever have to replace anything, and if I do, all I need to do is heat up the glue and pull it apart.
Worst case scenario, I can just replace my stockers with new ones. I looked up the price online and its about $75 for all 4 of them. Or I can just go totally aftermarket.
Either way, I am excited about this whole project. As you all have come to expect, I will take many pictures of everything.
Oh, and someone asked where I got everything. I got the Mustang fender bib, the Kury bezels, and the LED tailight from cruisercustomizing.com. I got the 18 LED turn signals (front and rear) off ebay from a place called http://usaled.com/. Lastly, I got all the accent LEDs, install kid, tire stem caps, and license plate frame from Custom Dynamics.
Old 03-04-2006   #9 (permalink)
2WheelFun
2WheelFun's Avatar
Get out the tools and camera and make us proud! LOL
***KING KAHUNA***
***2007 V2K LT***
******PICS******
2007 Brute Force 650i
******PICS******
*I love the smell of SeaFoam in the morning*
2WheelFun is offline   Reply With Quote
Old 03-04-2006   #10 (permalink)
tingboy
Too hot to ride
tingboy's Avatar
Send a message via MSN to tingboy Send a message via Yahoo to tingboy
can't wait! hurry back with them pics!
ting
My three babies.
'90 Vulcan 500
'97 Supra
'07 ZX-6R
http://www.angelfire.com/la3/tingboy/
tingboy is offline   Reply With Quote
Old 03-04-2006   #11 (permalink)
Frankt07
Ridden like a Ford!
Frankt07's Avatar
you are a sick man...lol
2001 Black Mustang GT
2005 Phantom Silver 1500 Classic
Royal Purple synthetic oil in both
Frankt07 is offline   Reply With Quote
Old 03-04-2006   #12 (permalink)
Redbeard
Redbeard's Avatar
man I thought I was doing good when I bought new risers. I can see I'm way behind.
Redbeard
2006 1600 classic
Patriot Guard Rider #5776
Life ain't easy when your Fat and Greasy
Redbeard is offline   Reply With Quote
narrowing the search for parts destarr Accessory Swap Meet 8 11-26-2007 10:25 AM
FS: 1996 ZX9r plus additional ZX9 parts bike Inten_Z Streetbikes Buy/Sell/Trade 0 11-25-2005 12:36 AM
aftermarket parts for 2004 ninja 500R? chimera Kawasaki Streetbikes/Sportbikes 2 08-13-2005 12:04 AM
what parts fit my bike? ctdubbin Kawasaki Streetbikes/Sportbikes 0 11-16-2004 12:04 AM
parts for 04 ninja 500r jmanning2003 The Mechanics Corner 1 06-04-2004 03:24 AM
