It goes in this way...
![]() Join Date: Sep 2005
It finally warmed up enough for me to lay on the garage floor, so I started installing my Clear Alternatives Integrated LED taillight/turn signal. I got the smoke lens, and it looks sweet. I ran out of time and had to go to work before I got the new flasher installed.
Where the heck is the stock flasher? I got the MS in September, so I never really had a chance or reason to take it apart and get familiar with it. The Loving Wife also pointed out that she would like me to have a second set of rear turn signals on the bike, so I may be mounting a set of bullet LEDs where the passenger pegs are... I do know that the rear of the bike looks alot better with the plate and turn signals gone. Now I just have to get or make a plate bracket. |
Third Gear And Gaining
How has the install so far? I am waiting till I take my bike out of storage before I mount my LED tail light. I am going to make my own bracket because my plate is a little larger than the normal plate size. I am just going to cut a peice of stainless steal dimond checkerd plate and bend a little tab on it to mount, Just try cutting a couple peices out of cardboard first till you get the right template. OH I am not 100% sure but I thik the flasher is next to the junction box some where. that is behind the right side cover.
best of luck! |
It's pretty easy, I probably could have been done, but I hate the connectors they send with the light, so I am going to use something else. I may remove the pins from the stock connectors and use them. The only mod you have to do is drill 2 holes in the backplane for the turn signal wires to run thru. I am still unsure of how I am going to cover all the wires under the fender, cause the stock cover is too long, I may modify that, or I might put new, smaller connectors on everything and heat shrink them. But I don't want to leave them exposed.
I'm not concerned with a light on my plate, but I may get a set of the LED plate bolts to see how they work. Thanks for the flasher answer, I am going to finish the job in the morning. I can't find the plate bracket I want, so I may be making a trip to see the tinsmiths shop. I want a bracket that turns IN, not out, and has a radius, so the plate hugs the final drive. So the bracket tab is going to have to be longer than most... |
#4 (permalink) | |
Way Too Much Free Time
http://www.cruisercustomizing.com/de...oduct_ID=19107 For $26.96, you cant go wrong. I have one and its a nice piece.
2005 Magma Red Kawasaki Mean Streak 1600 1998 Bright Red Pontiac Trans Am 405.5 RWHP 385.1 RWTQ 2004 Nighthawk Black Honda Accord EX 6-speed |
#5 (permalink) |
!cixelsyD toN m'I
![]() Join Date: Feb 2005
Here's a pic of mine. The sidemount bracket is made from 1/8" thick polished aluminum diamond plate. The turn signals & tag light are stock, just moved to new locations. Total cost was about $30 including the license plate frame & chrome bolts.
07 HD Fat Boy If you want a clean drink of water go to the head of the stream Last edited by grandpawmoses : 07-28-2006 at 02:20 PM. |
#6 (permalink) | |
2002 Mean streak Barons big air kit,V&H straight shots, PCIII, Progressive 440's and fork springs |
| LED turn signal, HELP! | muddler | Kawasaki Cruisers | 2 | 02-04-2006 02:11 PM |
| LED tail with the signal lights!! | blue meanie | Kawasaki Cruisers | 5 | 01-13-2006 12:29 AM |
| Corroded Turn Signal? | kobender | Kawasaki Streetbikes/Sportbikes | 0 | 10-11-2005 03:08 PM |
| LED running lights in turn signal, on 05' ZZR???? | WilbersUSA | Kawasaki Streetbikes/Sportbikes | 0 | 09-20-2005 12:21 AM |
| Meanie LED Turn Signal Array | flynsouth | Kawasaki Cruisers | 1 | 09-28-2004 06:31 PM |
