Old 03-27-2006   #1 (permalink)
deniska
Aspiring slowpoke
deniska's Avatar
Default Grease in right side air box... ?!
I am just a bit worried. While I am waiting for my tank to be repainted, I decided to get started on the Caddman mod. As a first step, I thought I'd open the right-side airbox and think through the steps. Well, before I opened it, I noticed that the bottom of the cover, right along where it connects with the plastic backplate, was a bit oily or greasy. So I took the cover off, and noticed there was grease on the bottom. It seemed to have come out of the little hole on the bottom (there is a sort of a divider about 1/3 of the way from bottom up, and a small hole between the bottom and the divider.
This stuff didn't look like oil -- more like grease, gray with a bit of a whitish streak. Not too much, but more than a couple of little specs. There were actually a couple of specs further up -- on the rear solenoid, for example. I wiped everything off, but this has me really worried, as this is in the airbox, close to the air intake valves. Is this unusual? What the heck could this be?
Thanks.
2005 Kawasaki Mean Streak 1600
www.CruiserCustomizing.com/deniska
deniska is offline   Reply With Quote
Old 03-27-2006   #2 (permalink)
trikebubble
Slow Guy on a Fast Bike
trikebubble's Avatar
Could it be filter oil?
08 Midnite Sapphire Blue ZX-14
trikebubble is offline   Reply With Quote
Old 03-27-2006   #3 (permalink)
deniska
Aspiring slowpoke
deniska's Avatar
Don't know... didn't have any brown tint to it. How would filter oil get there?
Old 03-27-2006   #4 (permalink)
ppark
Way Too Much Free Time
Crankcase vent is routed to the air box so any oil that comes out gets burned in the engine. If you fill up the oil too high, you could have more oil coming from the vent. Check out discussion on Krankvent.
1600 Mean Streak
ZRX1200
ppark is offline   Reply With Quote
Old 03-27-2006   #5 (permalink)
trikebubble
Like air filter oil maybe.
Old 03-27-2006   #6 (permalink)
Frankt07
Ridden like a Ford!
Frankt07's Avatar
i seem to think the same. and the whitishness to it may be from time and condensation turning the oil milky.
check your oil level, keep an eye on it, but i wouldnt worry about it too much
2001 Black Mustang GT
2005 Phantom Silver 1500 Classic
Royal Purple synthetic oil in both
Frankt07 is offline   Reply With Quote
Old 03-27-2006   #7 (permalink)
deniska
Aspiring slowpoke
deniska's Avatar
Thanks guys. I guess I'll just watch it for now.
Old 03-27-2006   #8 (permalink)
NY_Guy
In Search of Perfect Tune
NY_Guy's Avatar
This stuff didn't look like oil -- more like grease, gray with a bit of a whitish streak. Not too much, but more than a couple of little specs. There were actually a couple of specs further up -- on the rear solenoid, for example. I wiped everything off, but this has me really worried, as this is in the airbox, close to the air intake valves. Is this unusual? What the heck could this be? Thanks.
Blowback from the crank (esp if overfilled and revving engine). Solved by using a crankcase vent. KrankVent is one option, but mine was pretty noisy (so didn't install one on the new bike). Gadget has some options on his web site.
2006 Black Nomad w/ TFI
O2 Sensor Roadhouse 2/1
If you can't dance
it's too late to plow.
NY_Guy is offline   Reply With Quote
Old 03-28-2006   #9 (permalink)
Billy D.
Loves Burning Rice!
Billy D.'s Avatar
I don't know this for fact, I was told that the greese was put there to help catch the fine particles of sand and other junk, I don't know, but it sounded lodgical.
Billy D. is offline   Reply With Quote
Constrictor's Caddman Air Mod Tutorial (56k Warning) Constrictor Projects and "How To" Write Ups 265 10-09-2009 09:22 AM
Air Box vetch Vintage Motorcyle Info 4 01-28-2006 05:44 PM
Gas in the air box DeathTrap The Mechanics Corner 3 01-27-2005 09:02 PM
Pipes, air box, jets done... dyno? PickYourPockets Kawasaki Cruisers 2 11-18-2004 06:00 PM
oil leaks from air box bahamaspete The Mechanics Corner 3 05-03-2004 06:48 AM
