LinkBack | Thread Tools |
Big Al
Hello folks!
I'm in trouble. Here is the story: I had my bike (02 MS) stored in winter with regular mineral oil in. We started to have a nice weather and I decided to have my bike ready for upcoming riding season. I started it, warmed it up and had couple of circles around my neighborhood. Everything was so promising. Then I drained used oil and put in Rotella-T Synthetic (5W-40), that many of you mentioned in the forum. But after that switch (mineral to synthetic) I have started to have a problem with the clutch. It doesn't completely disengaged. I have a problem even to put the first gear in with an idle run engine regime. I tried to have my bike moved with engine off, first gear in and clutch disengaged, but I couldn't. I know everything worked OK before I put this synthetic oil in. Now, I have no idea what happened. I'm about to buy mineral oil to put it in and try my clutch, but I don't think there is a problem with a clutch in my case. Is it oil? Please, your thoughts! Thanks in advance everyone! Last edited by Piterski : 04-03-2006 at 10:31 AM. |
#4 (permalink) | |
Wants better weather!
1999 Vulcan Classic 1500 V&H Longshots w/quiet baffles Stage 1 jet and K&N Progressive springs F&S Lightbar and Memphis shades Slim Rigid bags w/Easy Bracket mounting system Last edited by dickwol : 04-03-2006 at 10:54 AM. |
#5 (permalink) | |
the "fun old" guy
Maybe some bikes clutch parts are manufactured elsewhere? |
#6 (permalink) |
Living on the dark side
![]() Join Date: Aug 2005
Sounds like your clutch may need adjustment. Usually the only problem you'd have with the wet clutch pertaining to oil is excessive slippage if you had used the wrong type of oil, which you didn't.
'03 1200 Sporty |
#7 (permalink) | |
1999 Vulcan Classic 1500 V&H Longshots w/quiet baffles Stage 1 jet and K&N Progressive springs F&S Lightbar and Memphis shades Slim Rigid bags w/Easy Bracket mounting system |
#8 (permalink) | |
Big Al
I definitely will go with mineral shortly to see if the problem disappears. If it does, then there is something different with canadian models or at least with mine! I let you know. Thanks for responses I got so far! Great to be here with you guys |
#9 (permalink) | |
Let's Ride!
![]() Join Date: Oct 2004
#10 (permalink) |
In Search of Perfect Tune
![]() Join Date: Jun 2005
When you guys say "mineral oil," do you mean the clear stuff people give cats with fur balls? Be careful, I've got 5 cats!
2006 Black Nomad w/ TFI O2 Sensor Roadhouse 2/1 If you can't dance it's too late to plow. |
#11 (permalink) | |
Let's Ride!
#12 (permalink) |
Cruising In Fourth Gear
How many miles do you have on the scoot? It has been reported over on VROC with users with the same problems. It could be that your clutch spring is wearing out. Many people don't see a problem with worn clutch springs until they go to synthetic oil.......myself being one of them. I would bet that if you have more than 15,000 miles on your bike......it is the spring. I replaced mine and added "judges" washers and everything is right as rain. Now before I get flamed.......I am not saying that all bikes that have more than 15,000 miles have worn out clutch springs.......I am just saying that it is a real distinct possibility. Just ask around and check out VROC for another opinion.
Kebo
2003 Vulcan Nomad, V&H Baggers, Harley Trunk, Xenon HID Headlight, Edmunds Lowers |
#13 (permalink) | |
As far as the bad clutch spring goes, don't alot of guys replace their spring with the MS spring which is supposed to be heavier and not as prone to failure??
'03 1200 Sporty |
#14 (permalink) | |
Big Al
Well. It has just 12,000km (~8,000mi). I bought it from one owner and he had semi synthetic in. I put dyno oil for the winter and then you know Rotella. Spoke with mechanic. He suggested: - warm up the engine and turn it off - put front wheel against the wall - put third gear in - start the engine - let clutch lever slowly OUT and IN for 2-3 seconds, which he believes should disengage the clutch plates. I thought again what happend and have some conclusion that I ask for your opinion: After I drained the old oil I let the bike sit for 30-40min (for some family reason - kids) then I put new Rotella oil in. Is it possible that rapid temperature change caused clutch plates stack in? |
#15 (permalink) | |
Transplanted Newfie!
I just switched to Synthetic yesterday...no issues.
Living life one day at a time! 02 Nomad |
#16 (permalink) | |
Big Al
Drained the oil. Checked master and slave cylinders. When squeezing clutch lever feeling the pressure. Everything looks OK on "left side". Still, the clutch doesn't disengaged. Started to take a part "right side". But I'm not sure what I'm looking for to check. Is it the spring or .. ? Please, if anyone dealt with the clutch let me know what should I check in my case? Thanks in advance!!!!!!!! P.S. Oh, other mechanic said that synthetic oil may caused clutch friction plates to swallow, which leaded to my clutch disengagement problem. ????? |
#17 (permalink) | |
Let's Ride!
Clutch spring replacement http://www.gadgetjq.com/clutch_spring_replacement.htm |
#18 (permalink) |
Master Doityourselfer
Keep us posted about your progress. I personally feel the clutch in the MS could be a bit heavier but I have had no real "problems" with using synthetic oil. Although I could see how decreased friction in the setup could cause probs. Hope you get it fixed soon.
Black '06 V2K Classic '76 KZ900 LTD |
#19 (permalink) | |
the "fun old" guy
Here kitty...kitty...kitty... |
#20 (permalink) | |
