Old 04-10-2006   #1 (permalink)
PA Jim
Default backfiring through carb
I recently scooterized my 800 classic (sort of) I made my own backplate, I did not modify existing one. I used a .165 main jet, .050 pilot jet with the misture screw out 2 1/2 turns. I am getting a backfire through the carb when giving it just a little gas. It runs fine during harder acceleration. Any help would be appreciated.
Thanks,
Jim
PA Jim is offline   Reply With Quote
Old 04-10-2006   #2 (permalink)
1400pilot
UBER CLUB MEMBER #2
1400pilot's Avatar
maybe caused by an exhaust leak at the header gasket
Click for a map of the states I've ridden in
08 ZG1400 Concours
06 KDX200
04KX65
1400pilot is offline   Reply With Quote
Old 04-10-2006   #3 (permalink)
PA Jim
The exhaust was not altered it is the same exhaust that was on the bike from before. Hard Krome slash cuts
Old 04-10-2006   #4 (permalink)
1400pilot
UBER CLUB MEMBER #2
1400pilot's Avatar
a backfire can be caused by a lean condition, have you checked for small vacuum leaks, if not try and richen the mixture up a bit...............I see our resident 800 expert is looking at this thread now, so your troubles will soon be over.................Hi ya woody!!!!!!!
08 ZG1400 Concours
06 KDX200
04KX65
Old 04-10-2006   #5 (permalink)
woodchucks800
08 FatBob
woodchucks800's Avatar
Thanks,
Jim
I'm betting it's an air leak either between the carb and air filter or between the carb and the intake boot. the rubber boot is known for causing problems just like this. Have you already removed the epa crap( i'm assuming you have)I'd probably turn the mixture screw in a half a turn also.Set your idle up a bit as well.
woodchucks800 is offline   Reply With Quote
Old 04-11-2006   #6 (permalink)
mumbles
Sit speling cheker
mumbles's Avatar
Send a message via ICQ to mumbles
Like mentioned before, make sure the rubber boot from the carb to the intake is well seated.
This question is for everyone: Can the rubber boot be damaged easy?
Woody, if this is caused by a lean condition wouldn't turning in the mixture screw make it more lean?
mumbles is offline   Reply With Quote
Old 04-11-2006   #7 (permalink)
woodchucks800
08 FatBob
I don't think it can be damamged to easy buy anythings possible making sure the carb is seated in the boot properly and the clamps are tighten just right(not to tight or too loose) .
Old 04-11-2006   #8 (permalink)
2WheelFun
2WheelFun's Avatar
What setting is the carb needle set at now?
***KING KAHUNA***
***2007 V2K LT***
******PICS******
2007 Brute Force 650i
******PICS******
*I love the smell of SeaFoam in the morning*
2WheelFun is offline   Reply With Quote
Old 04-11-2006   #9 (permalink)
woodchucks800
08 FatBob
I don't think the jetting is causing his problem. He's more than likley got an air leak between the carb and the modded stock air filter case or from the manifold boot. The only reason I suggested turning the A/F screw in is because he's still using the stock needle which won't seat into the new 50 pilot as far as the aftermarket needles do. For the most part after changing the jets and needle everyone tends to turn the A?F screw ina 1/4 to 1/2 a turn before there playing with the set up . I know I'm running at 2 turns out and not running lean, but his could be different( they all are) and without an adjustable needle there isn't much he can adjust other than the A?F screw ( He might be able to add a shim under the needle but I don't think this is where the problem lies)
Old 04-11-2006   #10 (permalink)
PA Jim
Thanks for all the input guys I appreciate it. I am running a dynojet needle out of a 1500 on the 3rd notch from top as is stated on Russian Wolf website. Anyway, I took the tank back off and checked the seal between the manifold and the carb, seemed ok. Turned the mixture screw all the way back in then out 2 1/2 turn, reinstalled filter backing plate and filter. Started up went for a ride, lo and behold no more problem. Thanks again, you guys are a wealth of knowledge.
Old 04-11-2006   #11 (permalink)
bluestringer
Rebel Rider
bluestringer's Avatar
Like Woody said, it was an air leak. I'm still getting a pop through the carb when cold. I think I'm running a little lean, because I still need the enricher quite a bit. Running the air mixture at 2 and a half. Just installed a 40t rear sprocket, now running 18/40, and I really like the long legs.
bluestringer
2005 Vulcan 1500 Classic FI
V&H Longshots
VROC #13910
GAVROC #159
bluestringer is offline   Reply With Quote
Old 05-09-2006   #12 (permalink)
PA Jim
Hello Again, thought I had this taken care of, but I still get the sneezing through the carb when I ride in cold weather, does not do it when it is warm. Any suggestions?? Thanks in advance for the help
Carb cleaning surprise gpz_rider Vintage Motorcyle Info 11 04-25-2009 08:56 AM
KZ440 carb help babee_huey The Mechanics Corner 7 04-23-2009 11:31 PM
92 ninja 600R carb won't stay connected? ctdubbin Kawasaki Streetbikes/Sportbikes 7 08-09-2008 11:00 PM
Installed cruise, rejetted carb semo rider Kawasaki Cruisers 1 03-13-2005 09:31 PM
Newbie question re 2004 Classic Carb versus 03/05 Classic FI scharfg Kawasaki Cruisers 14 11-22-2004 10:15 PM
