Needs A Real Job
Oil hot.
Bike parked as level as possible. Proper amount of oil and a new filter. Remove drain plug, might have a gasket, allow oil to drain. Once it stops replace plug/gasket and torque to spec. Remove oil filter, make sure original gasket is removed if its a spin-on. Allow oil to drain if any. Install new filter, lube gasket with some freh oil to ease installation. Top up oil to spec. Double check drain bolt and filter. Start bike, make sure the oil light goes out. Idle for 2-3 mins, stop engine and recheck oil level. Recycle old oil, enjoy a ride. Check your manual for oil viscosity and drain bolt torque specs.
1984 Ninja 900 (A1) To make it go faster I need to add more lightness! |
#4 (permalink) |
Also look down near the kickstand and remove the large nut there ( I think it's 17mm ) and then remove the screen and clean it out. Observe the way it came out and return it once it's cleaned.
#5 (permalink) |
Economic Plankton
![]() Join Date: Jan 2005
wc covered it pretty well tho I thought he was gonna forget about the oil screen
And welcome to the Forum! Here in central NC I use 10w-40 in the spring (Mar-Apr) and fall (Sept on), but now is about the time to change over to 15 or 20w-50 for the heat of the summer. Also- use the owners manual for the maximum miles between changes, but if you find the the bike jumps from 2nd to neutral during engine braking or rattles a little when downshifting from 3rd to 2rd, it's time to change it again. You'll see what I mean..... |
#8 (permalink) | |
Ridden like a Ford!
2001 Black Mustang GT 2005 Phantom Silver 1500 Classic Royal Purple synthetic oil in both |
| men's rules for women - wouldn't let the wife see | Freakinout | Off Topic | 48 | 02-26-2008 10:59 AM |
| Winterizing...change oil before storage? | luvda6R | Main Lobby | 7 | 10-06-2005 10:42 PM |
| Meanie 2500 mi Oil Change - Need To Change Oil Filter Too? | TMac | Kawasaki Cruisers | 6 | 05-31-2005 07:23 AM |
| Oil change. Now Oil light on, HELP!!! | DaveinNM | Kawasaki Cruisers | 3 | 09-28-2004 11:50 PM |
| Kawasaki Vulcan leaking oil after oil change | J-Alan | Kawasaki Cruisers | 0 | 09-15-2004 05:36 PM |
