Old 05-08-2006   #1 (permalink)
uf-engineer
Turtle Wax Taster
uf-engineer's Avatar
Default Hard Krome Equalizer Straights Exhaust Replacement Advice
I have a set of Hard Krome Equalizer Straights on my 1600 Mean Streak,
2005. If I rev the engine up to about 3000 rpm the exhaust shield from the front cylinder exhaust shakes badly. For those who aren’t familiar with a DG exhaust, the shields are welded to the pipe. The manufacturer, DG, has been great in saying that they will replace the exhaust with any DG exhaust for the MS 1600. The problem is that they have discontinued the Equalizer Straights I have.
I've examined the welds and think the shield welds may have a hairline crack in them. I can’t move the shields with my hand but they resonate or vibrate at about 3000 rpm.
I’m wondering if this isn’t just inherent to this type of exhaust. If I get the 3” Big Straights, will I encounter the same shield shaking? How far do the straights extend out? Do they stop at the back of rim like the long pipe of the Equalizer Straights?
How do the DG Side Burner exhaust sound compare to the 3” duals? Does the side burner have a welded shield like the straights?
Am I making a mountain out of a mole hill? Should I just keep the exhaust I have?
Thanks for your help
uf-engineer is offline   Reply With Quote
Old 05-08-2006   #2 (permalink)
Frankt07
Ridden like a Ford!
Frankt07's Avatar
if you think they have a crack, over time it will get worse. if the noise bothers you, it wont go away. i dont know what other pipes sound like, but look around and get what catches your eye from the manufacturer
2001 Black Mustang GT
2005 Phantom Silver 1500 Classic
Royal Purple synthetic oil in both
Frankt07 is offline   Reply With Quote
Old 05-08-2006   #3 (permalink)
OldStreak
Transplanted Newfie!
My stock exhaust did that...I doubt that helps but just so you know.
Some of them can!
You can of course try wedging something between the pipe and the shield.
Or maybe using a hose clamp in some way.To stop the vibration!
If it's cracked on the pipe side you may be able to have it welded and painted with hitemp paint so it won't rust.
Welding the shield side may not work!
Living life one day at a time!
02 Nomad
OldStreak is offline   Reply With Quote
Old 05-08-2006   #4 (permalink)
Lattimer
Giant Biker
Lattimer's Avatar
I have the 3" big straights, and I haven't had any issues in 10,000 miles. No noises (except for the rattling baffles, but some packing fixed that!) No cracks (polished the pipes this weekend, so I would have seen them if they were obvious.)
If the crack is against the pipe, I would just weld it. If you were close to Southern NJ, you could stop by and I would fix you right up. A small MIG or TIG would work perfect on that.
I think the engine vibration cracks some of the welds on the HK pipes. Maybe they had a run of bad welds, poor wire or something.
All I can say is mine have been fine.
My pipes extend past the rim and are almost even with the edge of the tire, which is the look I wanted and the reason I bought these pipes. I think there is a shorter version that is right at the back end of the rim.
Shawn Lattimer
'06 Silver V2K Classic VROC #22980 ROG #464
http://www.shawnlattimer.com
Lattimer is offline   Reply With Quote
Old 05-09-2006   #5 (permalink)
uf-engineer
Turtle Wax Taster
How did you remove the baffles and what did you pack them with?
Old 05-09-2006   #6 (permalink)
uf-engineer
Turtle Wax Taster
Also, can someone post a pic of the 3" big straights on a MS side view.
Thanks
Old 05-09-2006   #7 (permalink)
Xlr8n
Living on the dark side
Xlr8n's Avatar
Not a direct side view, but between the two pics, you can get the idea. Also, I had the pipes replaced once under warranty due to a crack. http://www.kawasakimotorcycle.org/fo...owered-ms.html
'03 1200 Sporty
Xlr8n is offline   Reply With Quote
Old 05-09-2006   #8 (permalink)
Lattimer
Giant Biker
Lattimer's Avatar
There is a screw at the end of the pipe that holds the baffle in. I removed it and wrapped it in fiberglass muffler packing used for dirt bikes. It didn't change the sound any, but it certainly stopped the rattle.
On these pipes, the front of the baffle just sits against the res tof the pipe, and it isn't a tight fit. So the baffle was vibrating inside the pipe at certain RPM ranges. Drove me nuts.
Shawn Lattimer
Old 05-09-2006   #9 (permalink)
Lattimer
Giant Biker
Lattimer's Avatar
Thanks
I'll try to get a pic for you tonight
Shawn Lattimer
Old 05-09-2006   #10 (permalink)
uf-engineer
Turtle Wax Taster
I took the screw out but couldn’t get the baffle out. I tried pulling the baffle out with a coat hanger and couldn’t. The hanger kept bending. Where did you get the fiberglass wrap?
Old 05-09-2006   #11 (permalink)
Lattimer
Giant Biker
Lattimer's Avatar
Did you remove the tips first? You have to pull that off, then pull out the baffle. I used a long screwdriver and forced it into one of the holes in the side of the baffle, then used it as a handle. It wasn't easy, took some fighting both in and out.
I got the fiberglass at the dealer, it was supposed to be for repacking and FMF pipe for a dirt bike.
Shawn Lattimer
Old 05-09-2006   #12 (permalink)
Lattimer
Giant Biker
Lattimer's Avatar
Thanks
Here you go:
Shawn Lattimer
Old 05-10-2006   #13 (permalink)
SA_Meanstreak
Cruising In Fourth Gear
SA_Meanstreak's Avatar
Also run a pair of 3" Straights (about 7000 miles) and had some problems with the baffles as well, easy to remove but not so easy to put back again, you have to line-up the the holes, etc.
Mine cracked on the front exhaust at the top where the bracket is welded, the actual exhaust cracked 2/3 of the pipe and to fix it you have to remove the shield completely - well I only welded the parts you can get to, obviously the sections behind the shield and exhaust is now sort of open - hair line crack. I am still thinking how to repair this without having to re-chrome, etc.
I include a pic for you of the crack and the extent at the back.
Life is short, have dessert first
2003 Meanstreak 1500
Mods: Many, but never enough!!
SA_Meanstreak is offline   Reply With Quote
Old 05-10-2006   #14 (permalink)
Lattimer
Giant Biker
Lattimer's Avatar
Well, here is how I would fix it. Grind the weld off the mount for the shield. Then use a cut off wheel to remove the mount from the shield. I can't tell for sure from the picture, but then you may be able to get in there and weld up the pipe. I would open the crack up a little with a die grinder to get good surface area, then run a bead of weld over the crack. Weld a little at a time so you don't overheat the steel, you don't want to make this stuff any more brittle than it already is.
Then you can reassemble by welding the bracket back to the shield and to the pipe.
If you can't reach it still, you may have to cut all of the brackets off and remove the shield completely. Not easy, but at least it keeps you from buying new pipes or needing to re-chrome.
Shawn Lattimer
Old 05-10-2006   #15 (permalink)
Lattimer
Giant Biker
Lattimer's Avatar
By the way, I'm a mechanical engineer, not a welder. I taught myself to weld a few years ago, and I supervise a lot of weld repair and construction jobs, mostly on pipe and tanks. So I know a little about this stuff, but a professional welder might have better answers and an idea how to make that repair easier.
Shawn Lattimer
Old 05-10-2006   #16 (permalink)
Xlr8n
Xlr8n's Avatar
SA- my first set cracked at the same place. Replaced under warranty. Hope this set holds up better. HK told me they were probably tightened from back to front which caused the crack, but they replaced them anyway. (they were installed by the dealership on the new bike before I bought it.)
'03 1200 Sporty
Old 05-10-2006   #17 (permalink)
2WheelFun
2WheelFun's Avatar
Thanks Lattimer for this tip as mine were doing the same thing and I followed your advice and the noise went away.
***KING KAHUNA***
***2007 V2K LT***
******PICS******
2007 Brute Force 650i
******PICS******
*I love the smell of SeaFoam in the morning*
2WheelFun is offline   Reply With Quote
Old 05-10-2006   #18 (permalink)
Lattimer
Giant Biker
Lattimer's Avatar
Glad I could help!
Shawn Lattimer
Old 05-10-2006   #19 (permalink)
Xlr8n
Xlr8n's Avatar
Shawn- Was checkin' out your webpage and by my calculations you should just about be able to press my Meanie with me sittin on top! Pretty impressive records you have there! You should be proud of yourself for keeping it clean.
'03 1200 Sporty
Old 05-10-2006   #20 (permalink)
Lattimer
Giant Biker
Lattimer's Avatar
Thanks! Much appreciated.
Shawn Lattimer
Hard Krome American Classic Straights Question drifterguy2004 Kawasaki Cruisers 2 01-24-2006 04:05 PM
Hard Krome American Classic Straights Question drifterguy2004 The Mechanics Corner 0 01-23-2006 03:22 PM
Seen on Ebay Hard Krome 3" Exhaust Kawasaki Vulcan Mean Streak 1600 Tbakko Kawasaki Cruisers 12 10-04-2005 07:29 AM
hard krome xccelerator exhaust yeti1 Kawasaki Cruisers 5 01-27-2005 01:48 PM
Hard Krome 3" Big Straights,.... OMG! Phatboy Kawasaki Cruisers 8 08-12-2004 01:09 AM
