+ Reply to Thread
Results 1 to 18 of 18
Thread: Passenger Footboards for 1600 classic
  1. #1
    Newbie djaykdxr's Avatar
    Join Date
    Apr 2006
    Location
    Central, IL
    Posts
    19
    Default Passenger Footboards for 1600 classic
    I have seen that Kawasaki sells passenger footboards for the 1500 classic. My questions is... does anyone know if these footboards will fit the '05 1600 classic? I do realize that Cobra sells passenger footboards for the 1600, however they say Cobra on them. I would rather not advertise for Cobra. Does anyone know if there are any other manufacturers that make passenger footboards specifically for the 1600 classic.
    Thanks
    djay
  2. #2
    Made It To Second Gear BTK Beginner Shendo57's Avatar
    Join Date
    Oct 2004
    Location
    Shenandoah, Pa
    Posts
    82
    I did purchase the 1500 passanger floor boards and put them on my 1600 classic. They worked just fine. The wife has no complaints. It seems the bracket part # for the 1600 is the same as the 1500. It does seem that the floor boards do tile down very slightly at the front but they should be no problem for the passanger. I did look at the Cobras but like you I just wanted to keep as much of the bike original equipment. Good Luck.
    2004 Vulcan 1600 Classic
    Pearl White
    F&S Large Windshield
    F&S Lowers
    F&S Sissy bar
    F&S Engine Guards
    F&S Studded Saddle Bads
    "Clear Alternative" Lenses
    Kuryakyn Oval Convex Mirrors
    MC Enterprises Fender Rail with "V"
    MC Enterprised rear tail luggage rack
    Kuryakyn ISO Grips
    F&S Inner Engine Cover
  3. #3
    Join Date
    Apr 2006
    Location
    Central, IL
    Posts
    19
    I appreciate the reply. So you have these on your classic?
    I dont see them listed in your accessories. I just want to make sure that I am not misunderstanding. Thanks....
  4. #4
    Inactive Bheckel169's Avatar
    Join Date
    Feb 2006
    Location
    Huntsville, Utah
    Posts
    33
    Default Floorboards for the 1600
    I purchased the chrome and rubber floorboards from Kuryakyn for my 1600. Very nice, easy to install. I also added the toe and heel shifter pegs and the passenger pegs as well as the Kuryakyn brake pad. All of it works nicely together and all are very easy to install.
    2005 1600 Vulcan Classic
    lotsa chrome and Mustang seat
  5. #5
    Try Ex tri ca tion BTK Expert jiffyjam's Avatar
    Join Date
    Mar 2006
    Location
    NC
    Posts
    413
    Quote Originally Posted by djaykdxr
    Thanks
    djay
    I looked at quite a few and decided on the Cobra. Direct bolt on item amd very high quality. I understand what you say, but its hard to customize the 1600 and use only OEM parts. I have also added chrome brake caliper trim to match the floorboards. Good luck.
    http://www.cruisercustomizing.com/Jiffyjam
    Slow Down
  6. #6
    Refrigerator Magnet Test Engineer BTK Expert wvKawBoy's Avatar
    Join Date
    Nov 2005
    Location
    Lewisburg, W.Va.
    Posts
    477
    I went with the 1500 Classic Fire & Steel Passenger Floorboards on my 1600 Classic & they work great, the wife loves them! I mainly wanted the winged vulcan symbol to match my sissy bar.
    Tha KAW: 2003 Vulcan 1600 Classic
    2003 800A KAWAZY CHOPPER
    www.cruisercustomizing.com/wvKawBoy
  7. #7
    Join Date
    Apr 2006
    Location
    Central, IL
    Posts
    19
    wvKawBoy...
    Did you have to do any modifications to get them to fit? Do they bolt on with the same brackets that the 1600 footpegs use? I just want to make sure that they dont need any modifications. I talked to my local kaw dealer today, they were telling me that they do not fit. I dont particularly trust what they are telling me...
    Any feedback would be appreciated! Thanks
  8. #8
    Join Date
    Nov 2005
    Location
    Lewisburg, W.Va.
    Posts
    477
    You've got a PM.
  9. #9
    Join Date
    Oct 2004
    Location
    Shenandoah, Pa
    Posts
    82
    Would I steer you wrong??? Here is a photo I took in early May way after I last updated my accessory list. Don't be afraid, take the plunge.
    Attached Thumbnails Attached Thumbnails Passenger Footboards for 1600 classic-my-1600-classic-1.jpg
    Pearl White
    F&S Lowers
    F&S Sissy bar
    F&S Engine Guards
    Kuryakyn ISO Grips
  10. #10
    Join Date
    Oct 2004
    Location
    Shenandoah, Pa
    Posts
    82
    This should be a larger pic
    Attached Thumbnails Attached Thumbnails Passenger Footboards for 1600 classic-my-1600-classic-2.jpg
    Pearl White
    F&S Lowers
    F&S Sissy bar
    F&S Engine Guards
    Kuryakyn ISO Grips
  11. #11
    Join Date
    Mar 2006
    Location
    NC
    Posts
    413
    Quote Originally Posted by Shendo57
    It looks like they tilt down in the front, does this interfere with function?
    ( Rear floorboards )
    Slow Down
  12. #12
    Join Date
    Nov 2005
    Location
    Lewisburg, W.Va.
    Posts
    477
    Quote Originally Posted by jiffyjam
    I've got the exact same boards on my 1600 Classic & they work great, excellent quality & finish.
  13. #13
    Join Date
    Mar 2006
    Location
    NC
    Posts
    413
    Quote Originally Posted by wvKawBoy
    I'm sure they function ok, but it looks like your feet would angle down and maybe strain the ankles a bit on a long ride. Ok, now I see an earlier post about the tilt, guess its ok..
    Slow Down
  14. #14
    Join Date
    Oct 2004
    Location
    Shenandoah, Pa
    Posts
    82
    They do tilt down a bit but the Queen says they are great. Way better than the pegs she says. Good luck.
    Pearl White
    F&S Lowers
    F&S Sissy bar
    F&S Engine Guards
    Kuryakyn ISO Grips
  15. #15
    Join Date
    Nov 2005
    Location
    Lewisburg, W.Va.
    Posts
    477
    Got to keep the Queen happy, for the King to be happy! My wife says the same thing, WAY better than the pegs.
  16. #16
    Join Date
    Apr 2008
    Posts
    8
    Default Footboards for 1600 classic
    Some of the places like JC Whitney and Dennis Kirk sell universal fit footboards that are easily adapted to fit. They are also much cheaper than the Cobra's.
  17. #17
    Forum Supporter Forum Supporter S.D.Willie's Avatar
    Join Date
    Jul 2006
    Location
    Long Island, NY
    Posts
    1,417
    Quote Originally Posted by brentniel View Post
    2 years too late to the table.
    2006 Vulcan 1600 Classic
    2009 Yamaha FZ6
  18. #18
    '06 1600 Classic
    Join Date
    Apr 2008
    Location
    Nova Scotia, Canada
    Posts
    6
    I have Custom World floorboards on my 1600. They look great (I think), however they are not vibration isolated like the OEM front boards. I do not know if the OEM rear boards are vibration isolated, that is a big plus. For what it's worth I'm not a Cobra anything fan, I had cobra driver and passanger boards on my 800 (and other Cobra stuff) their quality is hit and miss sometimes the parts fit sometimes they don't.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Kaw VN2000 vs HD Electra Glide Classic
    By T-man in forum Kawasaki Cruisers
    Last Post: 01-25-2007, 06:19 PM
  2. Passenger comfort: Classic vs. Nomad
    By Vulcanrider in forum Kawasaki Cruisers
    Last Post: 04-30-2006, 01:18 AM
  3. MUSTANG Studded Seat for Vulcan 1500 Classic
    By kaw4me in forum Accessory Swap Meet
    Last Post: 10-27-2005, 02:43 PM
  4. 2004 Vulcan 1600 Classic for sale
    By Jack Dotson in forum Streetbikes Buy/Sell/Trade
    Last Post: 08-04-2005, 11:47 PM
  5. Handling differences between 1500 Classic Fi and Carb models
    By Mark Williams in forum Kawasaki Cruisers
    Last Post: 04-29-2004, 10:13 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
Search Engine Optimization by vBSEO 3.5.0 ©2010, Crawlability, Inc.
