tubeless wire wheels?
+ Reply to Thread
Results 1 to 19 of 19
Thread: tubeless wire wheels?
  1. #1
    Can't find time to ride BTK Expert Pooker's Avatar
    Join Date
    Sep 2005
    Location
    Limoges, Ontario, Canada
    Posts
    605
    Default tubeless wire wheels?
    I love the looks of spoked wheels however I hate tubes!!!
    Is there a way to convert your spoked rims to run tubeless tires?
    Thanks
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    I miss you, Deron Extreme Forum Supporter jukief's Avatar
    Join Date
    Sep 2004
    Location
    Manchester, NH
    Posts
    19,783
    Good question!
    In memory of my friend Deron Harden. Life isn't going to be the same without him.
  4. #3
    Way Too Much Free Time BTK Expert texrider's Avatar
    Join Date
    Jun 2006
    Location
    Arlington, Texas
    Posts
    1,037
    What you'll need are some tubeless type tires, fill stems, and a can of "Liquid Vinyl", commonly used to seal the cut ends of marine rope or dip a pliers in it to get a handle coating.... Use a small paint brush to apply the liquid vinyl to the area of the rim formerly covered by the tube saver band after cleaning the area with brake kleen, or similar degreaser. This will cure up and make the spoke ends and rim airtight. Worst case scenario is if you have to true the wheel or adjust any spokes, you'll have to dig for it and re seal...
  5. #4
    No Significant Other BTK Expert woodchucks800's Avatar
    Join Date
    May 2004
    Location
    Garfield,Arkansas
    Posts
    5,200
    Quote Originally Posted by Pooker
    Thanks
    More tham likely your tires are already tubeless type( most are ,they just are able to run a tube in them if needed) there's aslo a place in Califronia that can make your spoke rim into a tubeless rim by sealing the spokes on the inside of the rim. They probably do it along the way that Texrider described.
  6. #5
    Join Date
    Sep 2005
    Location
    Posts
    605
    Quote Originally Posted by woodchucks800
    No, I'm sure the new Vulcan 900 rims are not air tight and have to use tubes.
  7. #6
    Needs A Real Job BTK Expert relli's Avatar
    Join Date
    May 2006
    Location
    central florida hurricane central
    Posts
    2,481
    being in the tire business i would be skeptical of ripping down the road at hiway speeds even if a pro did it let alone a DIY project. i also would think there would be a vibration issue to deal with for sure
    07 FLHTC EGClassic
    everyone dies.not everyone lives
  8. #7
    Join Date
    May 2004
    Location
    Garfield,Arkansas
    Posts
    5,200
    I know the 900 spoke rims need tubes. I'm saying that most TIRES that are on spoke rims are the tubeless type tires. Take a look at any stock tire on a spoke rim and more than likely it will say tubeless on it.
  9. #8
    Join Date
    May 2004
    Location
    Garfield,Arkansas
    Posts
    5,200
    Quote Originally Posted by relli
    I don't know what the big deal with tubes is anyway. It seems most people that complain about it think there going to have a blow out and crash going down the road . How many times do you or anyone else actually know someone thats happened too, not just a I heard so and so had a blow out and crash? I've logged to many miles over the last 20 yrs on tubes with out so much as a flat let alone talk to anyone that has had a blow out ( I know people that have had a flat ,just not a blow out an crash)
  10. #9
    Eddie Lawson is God! BTK Expert elr658's Avatar
    Join Date
    Nov 2004
    Location
    Seymour,CT
    Posts
    5,361
    There is a way, it's called a BMW G/S
  11. #10
    Got my bigger bike Forum Supporter r3dninja's Avatar
    Join Date
    Sep 2005
    Location
    Georgia
    Posts
    309
    I don't care too much for tubes either, but my Dad brought up a good point. If you get a nail in a fairly new tire then all you need to do is buy a new tube and not a new tire.
  12. #11
    Join Date
    May 2006
    Location
    Posts
    2,481
    now this brings up a question that i keep forgetting to ask: i see air canisters and plug kits for bikes (emergency of course) can you use the fix-a-flat in a tube type tire to limp in???or are you just screwed ?
    07 FLHTC EGClassic
  13. #12
    Join Date
    Nov 2004
    Location
    Seymour,CT
    Posts
    5,361
    Screwed with a capital F.
  14. #13
    Third Gear And Gaining BTK Intermediate
    Join Date
    Apr 2006
    Posts
    125
    Any tire you spray a canister into is junk from that point on. Great scam $10 can makes the tire vendors $100 plush richer.
    I'm sure they invented inflate a tire spray product in the first place..
  15. #14
    Join Date
    Nov 2004
    Location
    Seymour,CT
    Posts
    5,361
    The propellant in many fix a flat cans is Propane. Just like your grill. BOOM!
  16. #15
    Beast Master BTK Expert msa1956's Avatar
    Join Date
    Jun 2006
    Location
    Hubert, NC
    Posts
    966
    I had a Flat tire on my C50 and it was a tube, I didnt use fix a flat I used slime. I pulled the nail and then put in the slime, aired the tire took it to the shop and had the tube replaced. so you can run on it, just get it fixed first chance you get.
    09 Concours Black ABS
    Accessories, Risers, Grip Puppies & Peg Lowering Kit. K&N filter
  17. #16
    Vulcan Ninja BTK Expert Aquaman95's Avatar
    Join Date
    Feb 2006
    Location
    Houston, TX
    Posts
    409
    Wheel Works in California used to seal spoke rims, but they stopped because the EPA banned a chemical in their formula. They were supposed to have a new formula a couple months ago but I don't know if it ever happened.
    Gadget has DIY instructions on his website. I personally wouldn't even consider doing DIY.
    I run Ride On as a preventative sealant and it has worked for me. I just had new tires put on because of a nail inthe back one and discovered that the front tube was shredded in the tire but the Ride On had worked well enough that I didn't even have an air leak. The back one got the nail in it and I didn't even know it was there until the next morning when it was flat.
    I too have alwasy heard people say that you will go down if you get a nail/flat on a tube tire because they supposedly deflate faster that a tubeless btu I'm not sure I believe it. It almost seems like it would be the opposite because although the spoked rims will leak air, they will slow it down enough so it won't pop like a balloon.
    BMW does malke tubeless spoke rims. The spokes go to the lip of the rim rather than the center.
    Finally, you can't look at a tire and assume it's not running a tune because it says tubeless. Most motrcycles these days are labelled as tubeless but when put on most spoke rims you do have to use a tube.
    1998 Vulcan 1500 Classic
    All the mods.
    1997 Vulcan 800B
    Sold
    2000 Nomad
    Under Construction
  18. #17
    Join Date
    Feb 2006
    Location
    Houston, TX
    Posts
    409
    Wow. I really need to learn to type or at least proofread.
    All the mods.
    1997 Vulcan 800B
    Sold
    2000 Nomad
    Under Construction
  19. #18
    Join Date
    May 2006
    Location
    Posts
    2,481
    what is this Ride On??????????please
    07 FLHTC EGClassic
  20. #19
    Join Date
    Feb 2006
    Location
    Houston, TX
    Posts
    409
    http://www.ride-on.com/prod_mot.asp
    All the mods.
    1997 Vulcan 800B
    Sold
    2000 Nomad
    Under Construction
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Aftermarket wheels for a ZX-6R
    By wrx2k4blue in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 10-04-2005, 09:33 AM
  2. Ground wire electrical problem/question?
    By webnetxpress in forum The Mechanics Corner
    Last Post: 09-07-2005, 11:12 AM
  3. Replies: 9
    Last Post: 06-26-2005, 09:55 PM
  4. Will ZXR wheels fit the 250?
    By makenzie71 in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 02-07-2005, 05:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
