LinkBack | Thread Tools |
Finally Got Into First Gear
Just finished the return leg of a 400-mile trip (Fresno-San Fran from Fresno). Pulled over for gas about 10 minutes from being home (why try my luck when the orange light is screaming at me?) There I found engine oil all sprayed over the right side of the bike.
Rode straight to the dealer instead of my home. Guy asked me right away who changed my oil last. Me: "Me." Guy: "You put way too much oil in it." Me: Gulp. He said to drain & replace the oil, but (obviously) don't overfill next time. Also said that there's so much oil in the system that it's back flowing around/into the air filter. Told me to remove and clean the filter really good with something like gasoline. My questions: 1) Did I potentially do damage to the bike? 2) Is there any sense replacing the stock air-filter with a K&N? Everything else is stock on the bike for now. But I'm thinking, if I wrecked the stock filter, why not? 3) Is there something else/better to use to clean the filter than gasoline? 4)Probably already know the answer to this one, but is there anything else I need to do when replacing the air filter, or does the EFI computer "figure out" there's a K&N (better filter) in there and compensate the mixture? I humbly await your replies. |
Sit speling cheker
If it's the stock Filter you have I definitely wouldn't be cleaning it with gas. Either get a new one or a K&N. I go for the K&N it's definitely worth the money. You can do the caddman mod on Gadjets website also if funds are low.
Way Too Much Free Time
Check your oil cap and gasket. I was getting a light mist of oil on my rear cylinder exhaust pipe and side cover. No leaks to be found on oil line or air filter. It ended up being a too compressed oil cap gasket that wasn't sealing my cap threads. Make sure also that your cap is tight.. Troop
Summer is hear !! "Road construction next 15 miles" www.cruisercustomizing.com/troop |
#4 (permalink) |
In Search of Perfect Tune
![]() Join Date: Jun 2005
Aerosol carburetor cleaner works well. You should probably add injector cleaner into the gas or maybe Sea Foam to clean out the fuel injectors. But I'm confused re: oil in the air filter-- do you have a Caddman mod on the right side? I'm just trying to figure out how oil could get into the filter on the left side???
I overfilled the oil once and was revving the engine when oil came out the crankcase vent hose (I had a Thunder air kit on my 2000 Nad). You likely didn't do any damage, just a little extra oil in the combustion chamber. Might want to check/clean/replace the plugs though and clean the injectors. BTW: I used to live in Old Fig Garden!
2006 Black Nomad w/ TFI O2 Sensor Roadhouse 2/1 If you can't dance it's too late to plow. |
#7 (permalink) |
[quote=I go for the K&N it's definitely worth the money. You can do the caddman mod on Gadjets website also if funds are low.[/QUOTE]
I have a totally stock setup right now. Am I mistaken thinking that I can just get a K&N filter to replace the stock filter? |
#8 (permalink) | ||
I don't have first-hand knowledge of the air and oil plumbing in the bike, and took the mechanic's word for it that oil was backing up in the system and finding its way to the filter element. I was delirious with heat stroke when he was looking at the bike. I figured I'd get home and take the filter cover off and have a look-see. But first I wanted to get on here and ask the Experts. Any recommendations for injector cleaner for a motorcycle? Quote:
#9 (permalink) |
With a stock system, IF the filter needs replacement (which I doubt unless Mean Streaks have the crankcase vent on the left side), you can get a K&N free flow filter. But if it's like the Nads, the vent's on the right side, bottom. You can pull off the right side cover and clean everything with the carb cleaner (but I'd suggest taking off the rubbber seal on the cover first). Get a lint-free cloth (not paper towels) and clean the inside of the throttle bodies too. Add the injector cleaner (any should be okay) to gas.
Then pull off the left side (air cleaner cover) and inspect. I don't see how oil could get from the right side to the left, since the air flow is from left to right. I think you should be okay on the left side (maybe the mechanic thought the filter is on the right). I've ridden to SF and back from Fresno (and Monterey) many times, but it sounds like you've got some HEAT out there now. Hope you're feeling better!
#10 (permalink) | |
I would imagine the MS is the same set-up as the Nomad. In which case, I'm now guessing that my point about a replacement air filter is now moot. I'll take it apart in a little bit once the temp dips to the low-100's. I did the ride to SFO up the 99-5-580-Bay Bridge going, and the 101-152-99 coming home. I think I liked the first way better. But today's ride home was so much hotter (late start) than the cooler AM ride up that the scenery was secondary to the the heat. I got a set of Baron's Customs highway bars today that I'm sort of anxious to put on. Not sure if I'm going to like them or not. I will definitely post pics, as I know the Highway Bars or Not question is an ongoing topic here. |
#11 (permalink) |
![]() Join Date: Mar 2005
You didn't hurt anything,you just got too much in there and it puked some out.Long high speed runs can do that,especially if too full. 21/2 quarts is usually plenty. use the sight glass.
04 MS 1640 Thunder 100 in kit/cams Race ported heads by "dynoray" Thunder air V&H Propipe PC3 |
#12 (permalink) | |
Live. Learn. Trust the sight glass. I took off the THROTTLE VALVE cover (duh--NOT the air filter cover). About 1/4 cup of oil poured out onto the garage floor, by way of the side of the engine and pipes. I mopped up most of the oil inside the throttle valve housing, but it's still pretty oily in there. I'll clean it up some more once I get some more shop rags, but is this going to be a worry? The barrels in the upper half of the housing looked and felt kinda dirty.
How do I get it off the kickstand? |
#13 (permalink) |
Ridden like a Ford!
you should be ok as far as not hurting anything in the throttle body side. but if you want to clean up, go to the auto parts and get you a can of carburator cleaner spray and spray the inside of both covers and into the crossover tube. any residual oil should come out and the carb cleaner will do a nice job of cleaning up.
then get you some seafoam and run a couple tanks to make sure shes all clean
2001 Black Mustang GT 2005 Phantom Silver 1500 Classic Royal Purple synthetic oil in both |
#14 (permalink) |
Turtle Wax Taster
I would clean it with the k&n cleaner and soapy water.
I think I still have the stock air filters off the 2002 1500 drifter I think they would fit they don't have many miles on them still pretty clean as I remember. if you pay to ship you can have them. get me at bobby.jones@meadhunt.com out till July 5th now. good luck
02 Drifter Thunder Air Kit PCM III 78 KZ 650 79 KZ 650 |
#15 (permalink) | |
Living on the dark side
![]() Join Date: Aug 2005
'03 1200 Sporty |
#17 (permalink) | |
It goes in this way...
![]() Join Date: Sep 2005
http://www.CruiserCustomizing.com/Illus USAF Veteran GM Electrician 2005 Mean Streak www.meanriders.com |
#18 (permalink) | |
1600 Mean Streak ZRX1200 |
#19 (permalink) | |
The bike calls for 2.9 if you don't change filter,..or 3.1 if you do. 2 1/2 -2 3/4 is usually plenty if you use the sight glass. If I put the 3.1 like they say with mine big bored,it will puke it out...it will not if I keep it right on the sight glass.(just below half)
| Replacing Stock Air filter with K&N | joecruiser | Kawasaki Cruisers | 4 | 12-28-2005 11:48 AM |
| Substitute for air filter oil? | webnetxpress | The Mechanics Corner | 7 | 09-07-2005 11:12 PM |
| K&N Oil Filter | dickwol | Kawasaki Cruisers | 1 | 10-01-2004 10:25 AM |
| Kawasaki ZN1100 K&N air filter retro help | dynapl | The Mechanics Corner | 3 | 06-18-2004 03:51 PM |
| How to change oil on 99 ninja 500R | mixery2k | The Mechanics Corner | 8 | 01-22-2004 07:49 PM |
