LinkBack | Thread Tools |
I am all of the sudden having trouble with my 1500 Classic FI (2002) misfiring after warming up. Due to the increased electric demand of the FI. I am wondering if a week battery could be the culprit. It's a 2002 1500 Classic FI and still has the origional factory battery in it. (4 years old) and the bike still starts fine. If I am dreaming don't hesitate to tell me. And if anyone has an idea as to what the problem could be could you guide me in the right direction? Would hate to take it to the dealer, for something simple. $$$
In Search of Perfect Tune
![]() Join Date: Jun 2005
Unless there's a problem with the ECU, I don't think its current is the issue (driving lights or air horn consumes more amps/volts). Have you pulled the plugs to see if there's carbon build-up? You might also try some Sea Foam-- people on this forum have had good results with it. If electrical, more likely the rectifier or possibly a coil.
2006 Black Nomad w/ TFI O2 Sensor Roadhouse 2/1 If you can't dance it's too late to plow. |
#3 (permalink) | |
#4 (permalink) |
Top Gear Full Throttle
I think you are right that the problem is electrical in nature. Check all your connections to the battery and if you did not solder your connections on your ECU it would be a good idea to do so now. I had a short under the seat in my wiring harness that caused all kinds of problems for me until it was finally diagnosed and the whole harness was replaced. It was strange because it did'nt do it all the time. Have you blown any fuse's? Mine kept blowing the ignition fuse. Pull the seat and look very carefully at thunderside of the harness for any spot where it may be worn through and touching the frame.
Good Luck! Lonestar
2002 VULCAN CLASSIC FI |
#5 (permalink) | |
Just installled a new set of plugs, and rode the bike for about 10 miles and no miss!!!! With the bad plug the bike would start missing within about 1-2 miles of riding. Looks like the mating process (ceramic to steel) failed on this particular plug. I have never in 30 years of riding seen a plug do this. And I have owned 2 harleys (older models) and have seen some ugly spark plugs come out of them often. But nothing like this, The brown ring looked like baked on oil and could be scraped off with a finger nail. Would be intrested in knowing if any one else has seen or heard of this? This problem has been pestering me for about 3 weeks now. Thought it was a wire shorting or possibly a spark plug wire breaking down. Isn't it amaizing how it's the simplest things that we over look when there is a problem. Lyle 2002 1500 Classic FI. Mods VH Longshots. (open) |
#7 (permalink) |
03 Nomad 1500Fi
I too have this issue but with an 03 nomad. Not the misfire but a definite stalling. ECU shows no faults, plugs changed, air filter changed, seafoam ran through it. premium gas only. problem arises sporatically. This morning, no issues, yesterday, like riding a bronc, hard to keep running.
#8 (permalink) |
Rock-n-Rollin Rider
My bike just started this the other day. when it gets up to operating temp. it dosent want to idle. If you stop in traffic, you have to keep it revved to keep it running. it will also misfire occasionally going down the highway. Either time, the FI light comes on.
I have changed plugs, tried Seafoam, tried Heet, removed the ECU and checked the wiring, checked the wires at the battery, checked the ground wire on the engine, checked every wire I can see for chaffing etc... I noticed today, it was running fine, and after about a 20 mile ride I stopped to get a drink. When I started to leave I had to really rev the engine and slip the clutch to get it on the highway. Once up to speed it ran fine. About 50 miles later I stopped for lunch, same problem. I went on with my trip for about another hundred miles, got mad at the bike and started heading back home. Ya know those cartoons with the cloud over the guys head raining on him? That was me, literally ! ! I rode all the way back home in the rain with a misfiring bike. (you can eliminate the rain as a factor because it was running bad before he rain started ) LOL Any ideas? |
#9 (permalink) |
03 Nomad 1500Fi
[quote=Madsdad;724820]My bike just started this the other day. when it gets up to operating temp. it dosent want to idle. If you stop in traffic, you have to keep it revved to keep it running. it will also misfire occasionally going down the highway. Either time, the FI light comes on.
I have changed plugs, tried Seafoam, tried Heet, removed the ECU and checked the wiring, checked the wires at the battery, checked the ground wire on the engine, checked every wire I can see for chaffing etc...QUOTE] Sounds like a a similar issue I had. I finally put mine into the shop and told them what I was epxeriencing. Took many hours of diagnosing, but they claim to have found a wire that was busted and fixed it. NOw it runs great. I added the Techlusion TFI and a Hyperthruster air ram to my machine and will put on vance and hines exhaust this winter. Get less mileage now but boy do I have power. Get your shop to run a full diagnostic on your bike. I too couldnt find any loose wires etc. |
| FS: 96-06 Vulcan 1500 Classic Vance and Hines Straightshots | VulcanWV | Accessory Swap Meet | 9 | 05-31-2006 09:51 AM |
| 03' Vulcan 1500 Classic Exhaust 4 Sale | WyomingVulcan | Accessory Swap Meet | 0 | 12-01-2005 07:36 PM |
| FS: OEM Exhaust for '02 Kawasaki Vulcan Classic 1500 FI | Ladykiller | Accessory Swap Meet | 1 | 07-24-2005 03:43 PM |
| 1500 fi vulcan classic | kaw800 | Kawasaki Cruisers | 13 | 12-23-2004 07:52 AM |
| Handling differences between 1500 Classic Fi and Carb models | Mark Williams | Kawasaki Cruisers | 1 | 04-29-2004 11:13 AM |
