MS Engine sputters after new tank of gas
+ Reply to Thread
Results 1 to 6 of 6
Thread: MS Engine sputters after new tank of gas
  1. #1
    Turtle Wax Taster BTK Intermediate uf-engineer's Avatar
    Join Date
    Sep 2005
    Posts
    162
    Default MS Engine sputters after new tank of gas
    2005 MS sputters when I give it roll on the throttle. It doesn’t die at idle but when I try to give her gas she sputters. Could I have possible put to much gas in the tank or did I get some bad gas. It the gas is bad, should I siphon it out or just add something to remove water and such. I noticed that the more I rode it the smother it got. By the time I got back home the engine was running smooth again.
    Could I have overfilled the tank?? What should I do?
    It was Cheveron gas 93% Octane
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    the "fun" guy Extreme Forum Supporter 2WheelFun's Avatar
    Join Date
    Nov 2004
    Location
    Albion, Washington "Pacific Northwest"
    Posts
    32,859
    Maybe overfilled it? It's probably ok. Pick up some SeaFoam gas treatment at Napa Auto Parts. Good stuff!!!
    ***KING KAHUNA***
    ***2007 V2K LT***
    2007 Brute Force 650i
    *I love the smell of SeaFoam in the morning*
  4. #3
    It goes in this way... Forum Supporter Illus's Avatar
    Join Date
    Sep 2005
    Location
    Wyandotte, Mi
    Posts
    943
    I haven't had a problem with overfilling, but it sounds like you got some bad gas. Try the gas treatment, and hit the road and run that gas out. Fill it back up after 60 miles or so, to thin out the bad stuff. Don't go back to that station.
    http://www.CruiserCustomizing.com/Illus
    USAF Veteran
    GM Electrician
    2005 Mean Streak
    www.meanriders.com
  5. #4
    Guitar nerd BTK Expert cudaosix's Avatar
    Join Date
    Apr 2005
    Location
    Miami, Florida
    Posts
    3,542
    If its running smooth again then your fine. If that happens again just drain whats left and feed it to the lawn mower. Fill up at another station. Take it from there.
    Over 40 MegaFonzies and rising
    1980 KZ1000
  6. #5
    Way Too Much Free Time BTK Expert troop's Avatar
    Join Date
    Oct 2005
    Location
    Stoughton, Wi
    Posts
    1,161
    Over filling doesn't sound like a culprit and more likely bad gas. Wonder if the 93 oct has been sitting in the ground awhile due to low sales ? If it has a 10%ethanol mix, it could collect moisture at a faster rate. Strange thing is I have never gotten bad gas, um, uh, in my bike . But I always go to the busy stations where turn over of gas isn't an issue... Troop
    Summer is hear !! "Road construction next 15 miles"
    www.cruisercustomizing.com/troop
  7. #6
    Newbie Bruce Oudekerk's Avatar
    Join Date
    Jul 2006
    Location
    Saratoga, NY
    Posts
    9
    Very strange but the same thing happened to me last week. My new MS (1500 mi) normally runs smoothly, even when cold but after a fill, and when I was leaving the library (no I didn’t get the gas at the library, it was sputtering or more precisely acting with a surging/nearly cutting out swing. I’m talking about the engine and not drive train lash. It sort of smoothed out in the large parking lot but at the road edge I had a very tight right hand turn, a large lip and very slow speed and of course in the middle of the turn as I was going over the lip, the engine sputters big time. All a prescription for disaster and embarrassment. The bike went down so slowly it rested on the foot peg. No harm except to my ego. The long and short of this is that it quickly smoothed out and no problems since and I’ve had a couple tanks of new gas. I only use high volume gas stations and in this case Mobil gas. I’m wondering if a full tank and sitting out in the sun for a few hours had anything to do with it. There should be vents for vapor and liquid but…??? Bruce
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Gas leak from the gas cap left brownish stuff on the tank
    By sqldosa in forum Kawasaki Cruisers
    Last Post: 06-19-2007, 09:30 PM
  2. Gas Tank Question
    By OldDog in forum The Mechanics Corner
    Last Post: 07-01-2006, 08:20 PM
  3. New rider, first bike, lookin' for a gas tank
    By storm16 in forum The Mechanics Corner
    Last Post: 06-08-2006, 09:17 AM
  4. Stranded Gas in the 2005 1600 Nomad Tank + Misc.
    By dhg in forum Kawasaki Cruisers
    Last Post: 08-27-2005, 05:14 PM
  5. Can I use a different gas tank (non CA spec) on my 500
    By danielboland in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 11-01-2004, 03:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
