The rear shock on my 800a is hidden and very hard to adjust. The only method I know of to adjust the preload on the shock (short of taking the rear end of the bike apart) is to use a steel rod and sledge hammer to knock the adjusting collar around to the desired setting. I was considering installing an air shock so I could adjust it externally. Has anyone done this on an 800a? Where did you get the shock? Are air shocks really any good? Is there another solution?
Thanks, Derek |
I have the 800B and I bought a progressive 1" shorter shock for it from cruisercustomizing.com It was $377 altogether, and it has 5 settings that are (very easily) externally adjustable using an allen wrench. It is awesome. If you want to adjust your stock shock, you almost have to lift the bike's rear-end off the ground and then you still have to REALLY knock it (with the sledge hammer and maybe a crow bar) to adjust it. Before doing that, you have to remove the side cover and compartment to even get to it. The progessive is a better suspension, and WAY easier to adjust.
Born to Be Wild!!! :) |
| Rear Tire Size 800a ??? | rebeldog0085 | Kawasaki Cruisers | 6 | 10-01-2005 01:02 AM |
| Vulcan 800a rear fender | midwest_matt | Kawasaki Cruisers | 5 | 05-01-2005 04:10 PM |
| Rear shock options | Cap'nTeabag | Kawasaki Streetbikes/Sportbikes | 11 | 02-19-2005 05:59 AM |
| Help, need Rear Mojave 250 Shock | Cycle-Parts | Kawasaki ATV and Mule | 0 | 11-01-2004 09:48 PM |
| WTB: ZX6 rear shock | jcb3 | Streetbikes Buy/Sell/Trade | 0 | 05-17-2004 01:43 PM |
