Old 08-01-2006   #1 (permalink)
mxz600
Finally Got Into First Gear
Default Tire pressure Classic 1500
What tire pressure are mosting of you running with? I know the book says 28 for the front and 36 for the back. Going on my first long trip and was wondering if running at a little higher pressure and if so what. Thanks
mxz600 is offline   Reply With Quote
Old 08-01-2006   #2 (permalink)
jukief
I miss you, Deron
jukief's Avatar
I run both of mine at 40psi. I used that pressure with my stock tires and, now, with my Metzlers.
In memory of my friend Deron Harden. Life isn't going to be the same without him.
jukief is offline   Reply With Quote
Old 08-01-2006   #3 (permalink)
mxz600
Does the bike seem to handle better at 40psi
Old 08-01-2006   #4 (permalink)
jukief
I miss you, Deron
jukief's Avatar
It handles WAY better, and your tires will last longer, too. A lot of the 1500 owners on this forum use the same pressure (that's where I learned about it!).
Old 08-01-2006   #5 (permalink)
Spok
RIP Deron - 1400Pilot
Spok's Avatar
yep, count me in on the 40 psi gang. i find that pressures as low as the book calls for make for a slippery slidy ride, too much flex in the tires to give a good line
Spok is offline   Reply With Quote
Old 08-01-2006   #6 (permalink)
uechi kid
uechi kid's Avatar
I run m mine at 36psi, both front and back.
"Carpe Diem"
uechi kid is offline   Reply With Quote
Old 08-01-2006   #7 (permalink)
ppark
Way Too Much Free Time
Whatever you do, don't exceed the max pressure stated on the tire.
Also, when you are checking the pressure in the morning and planning on riding in the afternoon, account for the tempreature increase which will increade the tire pressure.
1600 Mean Streak
ZRX1200
ppark is offline   Reply With Quote
Old 08-01-2006   #8 (permalink)
anrfknm
humble pie consumer
anrfknm's Avatar
40 front, 41 rear. lower presures don't handle the loads.
vroc #13815 - rolling blunder #182 AMA member
http://www.cruisercustomizing.com/anrfknm
anrfknm is offline   Reply With Quote
Old 08-01-2006   #9 (permalink)
Frankt07
Ridden like a Ford!
Frankt07's Avatar
im running 40 psi on both my tires
2001 Black Mustang GT
2005 Phantom Silver 1500 Classic
Royal Purple synthetic oil in both
Frankt07 is offline   Reply With Quote
Old 08-01-2006   #10 (permalink)
BigJohn
Power Hungry V2K Rider
BigJohn's Avatar
40 psi in both ends. Handles much better than factory recommendations.
'00 Nomad
'06 V2K LT
Because RED is the fastest color...
BigJohn is offline   Reply With Quote
Old 08-01-2006   #11 (permalink)
kaw4me
Ok, we're all talking about tubed tires/spoked wheels on a 1500 Classic, right? I've been running 28F/36R on my '99 1500 Classic w Dunlop Cruisemax's with tubes. So jacking up the pressure to 40+, but not exceeding tire mfr's maximum is ok? Never thought about increasing the pressure, but if it's working for you guys, I'll give it a try. Even though I've got no problems with handling (I'm a very conservative rider), mpg should increase, and if tire wear is reduced, I'm all for the idea.This should be a real test for my fork oil and springs. BTW, not meaning to hijack this, but any recommendations for maintaining/changing fork oil and possible spring replacement...I've got 11k on the clock, and I don't know if the prev owner had this done. Is this stuff a dyi job, or should I let a dealer wrench do it?
1999 Vulcan 1500 Classic
Blue/Silver
kaw4me is offline   Reply With Quote
Old 08-01-2006   #12 (permalink)
Spok
Spok's Avatar
Originally Posted by kaw4me
Ok, we're all talking about tubed tires/spoked wheels on a 1500 Classic, right? I've been running 28F/36R on my '99 1500 Classic w Dunlop Cruisemax's with tubes, and jacking up the pressure to 40+, but not exceeding tire mfr's maximum is ok? Never thought about increasing the pressure, but if it's working for you guys, I'll give it a try. Even though I've got no problems with handling (I'm a very conservative rider), mpg should increase, and if tire wear is reduced, I'm all for the idea.
when i was running low pressures in my tires the sidewalls had so much slack in them it felt like the tire was a bit rolley or rolling over as it flexed, made for a very squishy ride thru the turn.
when I went to higher pressures the line feels more steady and rail like. Now like everyone here, i sometimes go longer between pressure checks and they fall off after time and i know when its time to get the gauge and the air hose and pump em up. It starts to getting squishy at around 36 or so...for me anyway.
Old 08-01-2006   #13 (permalink)
NY_Guy
In Search of Perfect Tune
NY_Guy's Avatar
I'd look on the side of the tires. The owner's book recommends less pressure than stated on most mfg sidewalls. Don't know why-- these are not Ford Explorers. With Nomads, low front tire pressure is asking for trouble and serious tire wobble, esp cornering. Classics use a 130/90, so it might not be as bad, but there's no logical reason to underinflate (from mfg recommendation on sidewall). Pressure should be measured cold (not literally).
Re: fork oil change: check Gadget's web site.
2006 Black Nomad w/ TFI
O2 Sensor Roadhouse 2/1
If you can't dance
it's too late to plow.
NY_Guy is offline   Reply With Quote
Old 08-01-2006   #14 (permalink)
kaw4me
I'll check the sidewalls on my Dunlops, and I'll also check for Gadget's info on the fork oil change. Thanks for the info.
Blue/Silver
Old 08-01-2006   #15 (permalink)
kaw4me
I've got to try upping the pressures. Maybe what I always thought was a "plush" ride was just what you're describing. That's partly why I ride so conservatively in the turns...just not much suspension response.
Blue/Silver
Old 08-01-2006   #16 (permalink)
bluestringer
Rebel Rider
bluestringer's Avatar
You may not notice much in the ride itself, but the handling will be much better. Gas mileage and tire life will increase also.
bluestringer
2005 Vulcan 1500 Classic FI
V&H Longshots
VROC #13910
GAVROC #159
bluestringer is offline   Reply With Quote
Old 08-01-2006   #17 (permalink)
Dukey
I want mine Diesel!
Dukey's Avatar
Send a message via AIM to Dukey Send a message via MSN to Dukey Send a message via Yahoo to Dukey
stock tires on my '05 1500 40 psi in both!
2005 -1500 CLASSIC
Kawasaki Windshield
Dukey is offline   Reply With Quote
Vulcan Classic 1500 bigger rear tire! Kenny Kawasaki Cruisers 14 07-23-2008 03:47 PM
1500 Classic Tire size upgrade Spiff Kawasaki Cruisers 10 07-26-2006 08:03 AM
COBRA Freeway Bars for 1500 Vulcan Classic kaw4me Accessory Swap Meet 0 10-27-2005 03:57 PM
1500 Classic Tire help dhdaniel Kawasaki Cruisers 11 10-19-2004 07:38 PM
Handling differences between 1500 Classic Fi and Carb models Mark Williams Kawasaki Cruisers 1 04-29-2004 11:13 AM
