Old 08-02-2006   #1 (permalink)
bluestringer
Rebel Rider
bluestringer's Avatar
Default Another 1500 Classic question
I don't know much about the 1500 or fuel injected bikes since I ride the 800 carbed, so I'm going to throw out another question or two.
Lets say someone is going to install V&H Longshots on the 1500 FI. I'm assuming if there is no air mod done, then there is no need to do anything to the fuel management system, is that correct?
While we're talking about pipes, has anyone installed the Longshots on a 1500, if so is it an easy install?
bluestringer
2005 Vulcan 1500 Classic FI
V&H Longshots
VROC #13910
GAVROC #159
bluestringer is offline   Reply With Quote
Old 08-02-2006   #2 (permalink)
DHACK666
Back in the saddle
DHACK666's Avatar
I have Straight shots but a buddy from work has the long shots on his 1600 classic. No FMS such as PCIII or TFI. His plugs are good in color his bikes runs great and in the last 1 1/2 has put quite a few miles on it. I have also disconnect my PCIII and everything is fine. In my opinion I would install the pipes and drive it easy for a week or two and if you have no back firring then check the plugs every 2 or 3 days. If they are not running hot then I would say save the money for another mod or beer for the summer.
2005 1500 Classic
2008 Concours 14
http://www.daksplace.com/
DHACK666 is offline   Reply With Quote
Old 08-03-2006   #3 (permalink)
anrfknm
humble pie consumer
anrfknm's Avatar
are these what you want to install?
the only place they don't match the 1500 is in the rear footpeg mount. you can modify the bracket (i did) or buy a 1600 footpeg mount.
vroc #13815 - rolling blunder #182 AMA member
http://www.cruisercustomizing.com/anrfknm
anrfknm is offline   Reply With Quote
Old 08-03-2006   #4 (permalink)
VNgeezer
Third Gear And Gaining
VNgeezer's Avatar
I have long shots on my 1500. I installed a TFI when I put the pipes on. I was able to fine tune the pots on the TFI and get better performance. The pipes were pretty easy to put on. I ran it for a few months and then added a Thunder air intake, that's when the bike turned into a beast, really brought it to life.
2001 VN1500 Classic FI
1953 Ford F100
http://www.vngeezer.com
VNgeezer is offline   Reply With Quote
Old 08-03-2006   #5 (permalink)
Classic
Ahhh Crap
Classic's Avatar
> I'm assuming if there is no air mod done, then there is no need to do anything > to the fuel management system, is that correct?
Yes. You may want to check into marbleing the reed valves. Check here, it's a great resource:
http://www.gadgetjq.com/gadgetsfixitpage.htm
In the "Bolt On Harder" section you'll find the instructions for disabling the reed valves though there is absolutely nothing "hard" about it.
Steve
2003 1500 Classic
VROC 11660
RB 139
Classic is offline   Reply With Quote
Old 08-03-2006   #6 (permalink)
Frankt07
Ridden like a Ford!
Frankt07's Avatar
you dont have to install a FMU if you are only doing pipes.
i added a PCIII to mine for peace of mind that i wasnt running lean. the bonus was a couple extra ponies
2001 Black Mustang GT
2005 Phantom Silver 1500 Classic
Royal Purple synthetic oil in both
Frankt07 is offline   Reply With Quote
Old 08-03-2006   #7 (permalink)
jukief
I miss you, Deron
jukief's Avatar
I put aftermarket pipes on my 1500 FI last summer, and I didn't do any other mods until this summer, when I did the Caddman mod and added the PC. The bike ran fine with just the pipes.
In memory of my friend Deron Harden. Life isn't going to be the same without him.
jukief is online now   Reply With Quote
Old 08-03-2006   #8 (permalink)
Billy D.
Loves Burning Rice!
Billy D.'s Avatar
I had my longshots put on about 3 months ago and did the pc later.
Billy D. is offline   Reply With Quote
Old 08-03-2006   #9 (permalink)
bluestringer
Rebel Rider
No, those are not the V&H Longshots.
bluestringer
V&H Longshots
VROC #13910
GAVROC #159
Vulcan Classic 1500 bigger rear tire! Kenny Kawasaki Cruisers 14 07-23-2008 03:47 PM
2000 Vulcan 1500 Classic Differential Question rancidcoolaid Kawasaki Cruisers 2 07-16-2006 08:23 PM
Question about pipes for the 1500 classic CurraheeDuck Kawasaki Cruisers 2 05-30-2005 05:58 AM
Vulcan classic 1500 Question dhdaniel Kawasaki Cruisers 1 10-24-2004 10:14 PM
Handling differences between 1500 Classic Fi and Carb models Mark Williams Kawasaki Cruisers 1 04-29-2004 11:13 AM
