Got a V2K and needed a second foot position for long hauls. There's been a lot of complaints about the stock seat on the 2K, but I don't think it's so much the padding, but that the setup of the bike itself places you in a position where you're weight is directly over your tailbone. Needed to be able to stretch out my legs.
The dilemma: I'm 5'9". Even if I could reach highway pegs that were mounted to crash bars (which I'm not sure I could - at least lock my heels anyway) the tank and sheer gerth of this bike would make it impossible to wrap my legs around the tank/motor. I would have to set the pegs out way to far which, in my humble opinion, would look stooopid. So, I remember reading a tread where someone wished a man. would produce a peg that swings out from the floorboards. Hmmmm... I went to work...
Fig. A
Fabbed a bracket out of 1/8" hardened angle that mounts under the floorboards to the threaded holes opposite/forward of where the skid pads are located. Painted it flat black and it disappeared. Mounted round pegs to the brackets. Since it swings horizontally instead of vertically, they needed to be round. Incidently, these pegs cost $15.00 in any of the parts catalogs. Can't remember who manufactures them, but they come with O-rings in the grooves. Because of your foot position, down and out, it tended to shuffle the rings so I cut them off. No real reason for them.
Fig. B
Fig. C
Finally, you can see that my legs are fully stretched and the pressure is off my tailbone. I've used these for about 1000 miles, now and let me tell you it makes a big difference in comfort. Could only go about 50 miles before my butt was screamin', but rode 200 and with the option of stretching out, had no problems whatsoever. The stock seat is just fine!
Fig. D
All in all, cost me about $20 for the mod. The result... priceless!
I'm sure the one question you have is clearance. The difference in negligable with the pegs tucked in. I scraped the skid pads twice before, scraped the pegs twice since. But who cares!!!! Only cost me $15.00 for replacement pegs should I need it, but truth is... couldn't even see where I touched down. Never hit with the pegs out, but I only use them for cruising and when I do take turns, I'm aware of them. I'm not going to carve twisties with my legs stretched.
Anyway - thought you V2K'ers (with slight height issues <Spok>) might be interested.![]()
LinkBack URL
About LinkBacks
