Old 09-14-2006   #1 (permalink)
triple360
Default Meanie pcIII map: v&h bigshots/tornado air kit
well i just finished installing my tornado air kit and pcIII. i put the thunder mfg map for their air kit and vance and hines straight shots. i havent got to ride it that much but it seem to back fire quite a bit more then it did with just the pipes. Im pretty new at this. is there another map you guys would recommend to start with or does anyone have a custom map? and how do i go about altering a map? how do i know if i need to richin or lean it?
triple360 is offline   Reply With Quote
Old 09-15-2006   #2 (permalink)
kingofwings
R.I.P. Deron Harden
kingofwings's Avatar
Make sure your zero throttle setting is right on.... if that is a little off, it will throw off everything. You can use the buttons to go leaner or richer must faster then using the map to make testing adjustments, then tweak the map when you get home. We are posting some users custom maps here, you might want to try one of them or submit yours when you are done.
I may not have gone where I intended to go, but I think I have ended up where I needed to be.
kingofwings is offline   Reply With Quote
Old 09-15-2006   #3 (permalink)
triple360
is back firing normal? if i get my bike over 3,000 rpms and let off the throttle it pops several times. is this just what this bike does or does that mean my map needs adjusting?
Old 09-15-2006   #4 (permalink)
Jimmy40741
Bridal Boutique Manager
Jimmy40741's Avatar
When you put on the Tornado did you mable it or use reed block off plates?
2005 Mean Streak - "The Reaper"
www.geocities.com/jimmy40741
*New Addition* 2001 1500 FI Nomad
Jimmy40741 is offline   Reply With Quote
Old 09-15-2006   #5 (permalink)
kingofwings
R.I.P. Deron Harden
There is the light pop-pop-pop that is normal from higher RPMs to zero throttle.
Back-firing is not normal.
Old 09-15-2006   #6 (permalink)
triple360
are you talking about the red cap the you put in the air tube. yes i did.
Old 09-15-2006   #7 (permalink)
triple360
i road around a little bit today. i guess the best way to explain it is that if im under 3,000 rpms it hardly ever pops unless im shifting down and it sounds like its more within the pipe. when im over 3,000 just letting go of the throttle its more of a bang...bang...bang and is sound like its coming from the end of the pipe instead of within.
Old 09-15-2006   #8 (permalink)
flyingdgn
Can't find time to ride
flyingdgn's Avatar
Mine backfires once in a while too but never more than one bang. It so loud that it scares the crap out of anybody on my right side.
I suspect that mine will get better with a better map.
Try another map off frank's site.
05 MeanStrek
I'm not Satan!!
flyingdgn is offline   Reply With Quote
Old 09-15-2006   #9 (permalink)
triple360
yeah i tried the thunder mfg w/ straight shots and i have also tried the
Dynoed custom map. Tornado airkit and Cobra Speedster Shorts. the dynoed one did help a little bit but not tons
Meanie PCIII and Tornado Air Kit Users stop here SleekStreak Kawasaki Cruisers 40 01-30-2007 03:19 PM
Installed Baron's Big Air Kit AlphaSteve Kawasaki Cruisers 32 01-28-2006 08:33 PM
PCIII Map for Big Shots on 1600 Meanie? khollister Kawasaki Cruisers 6 10-26-2005 09:21 AM
I'm a Meanie PCIII map junkie... help! kingofwings Kawasaki Cruisers 14 06-25-2005 12:06 PM
Which first, PCIII and Pipes or PCIII and Thunder Air Kit? Boss Hawg Kawasaki Cruisers 16 05-26-2005 12:57 AM
