LinkBack | Thread Tools |
Hello to all,
Just removed the final drive unit to pack the rear of the drive shaft and grease the splines (front & rear) with moly60 lube. The bike has close to 6k on it. I packed 17 ml (clymers' manual) almost 3 teaspoon of moly 60 grease inside the shaft & spring. However, when I try to insert the final drive slowly back in, I see some grease coming back out passed the "O ring". I did this 2-3 times and I always have some grease come back out as I push the final drive back in. I made sure no air is trapped & inspected the "O ring" it seemed Ok. Did I maybe put too much grease, should I not worry about it or try to remove the final gear again and clean the extra grease off? Thanks in advance for all replies and happy riding! |
| ***1600/1500 Classic/Nomad/Meanstreak/Maurader - Photo Contest*** | Spok | Kawasaki Cruisers | 170 | 12-12-2006 06:12 PM |
| Removing rear tire on Vulcan 750! | AMH | Main Lobby | 10 | 09-15-2006 09:52 AM |
| Removing rear tire on Vulcan 750! | AMH | Kawasaki Cruisers | 3 | 09-14-2006 09:57 AM |
| 750 Vulcan rear end tear down & Motorcycle Lift | 2WheelFun | Kawasaki Cruisers | 4 | 09-26-2005 10:04 AM |
| Left rear turn signal situation vulcan 750 | kamafool | The Mechanics Corner | 2 | 08-23-2004 01:42 PM |
