Can't find time to ride
I searched for an answer about how crash bars might affect cornering clearance, but I didn't find what I was looking for. Lots of stuff about bars, though, so I'm sure the answer is in there somewhere. Please forgive me for repeating a question that's been answered if in fact I missed an obvious post.
So, how do crash bars potentially affect ground clearance? I'm looking at the Cobra bars for my 900, but I regularly drag my floorboards. The boards, of course, are built to give a little when they contact the ground so that you don't push the bike off its tires when they scrape. The bars, of course, won't do that. I want the bars to protect in the even that the bike goes over, but I don't want something that increases the chances of that happening. Anyone with these bars on a 900 have info as to whether they would scrape before I ran outta room with the boards? Thanks! Steve
Steve 2006 Vulcan 900 2004 Ducati Monster S4R |
![]() Join Date: May 2004
Since I don't have a 900 my answer may not satisfy your needs... But on my 05 Nomad the stock OEM bars do not touch down until AFTER the floor boards have scraped and flexed up. And the few times I've scraped my floor boards I was so startled that I quickly righted the bike so going far enough to touch the bars was not a consideration.
As you mentioned going over far enough to fully flex the boards up means you are close to lifting the tires off the ground and at that point you are screwed and probably would want the bars to be there since you are about to go down and would want the bar protection for your legs... ![]()
05 Nomad/V&H Baggers/PCIII/Caddman Risers/Lights/Lowers/Chaps www.home.earthlink.net/~mthompson61 |
Giggidy-Giggidy-Goo!
I don't have the crash bars on my 900, but looking at some pictures posted, it looks like if you 'regularly' scrape your floorboards -and enough to worry about 'running out of room' - you are going to have problems with the crash bars.
Judge for yourself, though: http://forums.delphiforums.com/kawas...sages?msg=29.2
BikerBeagle 2007 Kawasaki Nomad 1600 A biker knows why a dog sticks his head out of a car window. |
#4 (permalink) |
![]() Join Date: May 2006
I have crash bars on my 900 classic LT.
It does not look like they would scrape. You will have to be really scraping your floorboards and then some before the crash bar would scrape. However, I don't regulary scrape my floorboards. I have scraped them a couple of times but the floorboards scrape way before the crashbars do... if they do.
2008 VULCAN 1600 NOMAD |
#5 (permalink) |
Top Gear Full Throttle
The Cobrs on my 1600 were designed to touchdown after, but I have a friend w/ cobras on a Suzuki and they hit first. Maybe you could email the company? Good Luck.
p.s. I fully expected to have to give up lean angle for the protection and comfort of the bars when I ordered them, but being able to do both is just an added bonus.
Blessed be the Lord my rock who trains my hands for war and my fingers for battle.Psalm 144:1 |
#6 (permalink) |
Turtle Wax Taster
I've scraped my floorboards several times, but never the crash bars. It depends on how they are shaped. A friend who just rode the Dragons Tail with me scraped his crash bars several times on his Suz Volusia and it scared the crap out of him.
06 Titanium Goldwing; Kuryakyn floorboards, Dullys, ISO Grips; fog lights, Utopia back rest; |
#7 (permalink) |
Wants better weather!
The Cobra bars are "fatter" than most. I had those on a Suzuki Volusia and was always paranoid about them. I had to be especially careful riding The Dragon because of this. I've seen these bars take bikes out from under people that corner too aggressively. I bought the MC Enterprises bar for my Vulcan 1500 as they are more tapered at the bottom and don't come out as far at the bottom as the Cobra does.
2003 Vulcan 1600 Classic - "Black Betty" |
#8 (permalink) |
Turtle Wax Taster
I've got Cobra bars on my 900LT, and I'm not an aggressive rider. In fact, I'm a fairly NEW rider, and have yet to drag my boards.
But bottom line, if you straighten the bike up, get behind it down low and look, the floorboards are gonna reach the ground BEFORE the Cobra bars do. If you're grinding your boards, that's a warning that you've reached about the max lean angle for the bike. You shouldn't have a problem with the bars clearing, unless you lowside, in which case you'll be glad the bars are there. Been there, done that, I've dropped my 900LT to the right side in a low-speed manuever. Only "damage" was the right-side mirror knocked out of alignment. Stepped off the bike, folded the kickstand down, butt-pushed it back up onto the stand, got back on and rode away with nothing damaged but my pride. Didn't even scratch the chrome on the bars. Luckily, pride heals quickly. Remember, the two top causes of motorcycle accidents are the cage turning left in front of you, and FAILURE TO NEGOTIATE A CURVE. If you're grinding boards on a regular basis, you're probably pushing the curve too hard. The 900 isn't a sport bike, don't try to ride it like one. Last edited by dgci : 10-09-2006 at 10:31 AM. |
#9 (permalink) |
PGR - BFC
![]() Join Date: Jul 2006
I have a two part answer, first check your location of your "rub-blocks." Mine were mounted on the front of my boards, although this allowed me a great lean angle for a cruiser, every time I scraped the boards it was the aluminum coming off the back of the board itself.
I moved my blocks to the other mounting location at the back. This significantly reduced my lean angle before I rub, but of course I'd rather sacrifice the blocks than the boards. All this was done prior to installing the 1 1/4" cobra freeway bars. I have since rubbed on numerous occaisions and the tought always goes though the back of my mind "don't hit the bars...don't hit the bars" as my grip tightens on the ISO's and on the seat! However after almost 3 weeks of riding with the freeway bar, I am positive you would need to darn near break a board off before hitting the bar. Cobra did a ggreat job of designing the lower angle to just catch the outboard edge of the board in case of a tip over, and still have it at a suffecient angle to lean her till you scrape and still be safe.
You say psycho like it's a bad thing... 06 900 LT 94 Black & Emerald 750 |
#11 (permalink) | |
I agree with you that it just doesn't pay to take chances in curves. But I think that if I never worked on my skills to the point where I was confident in leaning enough to scrape a board, I wouldn't be ready for a potentially dangerous situation. Cheers! Steve
#12 (permalink) |
Forensic Bug Splatter Analyst
I don't have much experience dragging the pegs (no crash bars on mine) but it certainly gets my attention in a big way when it happens. I definitely need lots more practice in the curves.
I read an article once, I think it was in Cruiser Mag. about how one of the test riders checked for ground clearance/lean angle. I am pretty sure he said that when he got on a bike he would get it up to about 60mph and then do a hard swerve and stay in his lane and scrape both pegs. To most that might not seem like much but to me it sure seems impressive. |
#13 (permalink) |
I can't speak for the 900 but on my 1500 Classic with the Kawasaki crash bars I cannot see how I could ever lean enough for them to touch. I've lightly scratched the floorboards on a few occasions but since I had them chromed a while back and would like to keep them that way I'm always very aware of how far over I am willing to lean.
1999 Vulcan Classic 1500 V&H Longshots w/quiet baffles Stage 1 jet and K&N Progressive springs F&S Lightbar and Memphis shades Slim Rigid bags w/Easy Bracket mounting system |
#14 (permalink) |
MadMac
I use MC Enterprises Engine Guard on my 2007 Vulcan 900 LT and the profile of those bars are a litte different than that of the Cobra bars, however I believe that the floorboards will touch down before the engine guards do. I would imagine that this concern is a consideration in the design and engineering of the various engine guards (crash guards) on the market.
MadMac 2007 Kawasaki Vulcan 900 LT Riding in the Great Pacific Northwest |
#15 (permalink) |
Rebel Rider
The Cobra Freeway bar did have problems hitting before the boards on the Vulcan 1500's. Don't know if they have corrected the problem or not. And not sure if the 900 would have the same problem.
..... bluestringer 2005 Vulcan 1500 Classic FI V&H Longshots VROC #13910 GAVROC #159 |
#16 (permalink) |
06 Nomad and 06 900LT
![]() Join Date: Aug 2006
We have a 900LT and If your scrapping your crash bars/gaurds IMO yuor pretty much going down at that point or damn close to it. i have riden my wifes 900 hard and never got close to scrapping her engine gaurds. I'm 240 as well.
"Better to be an Open Sinner then a False Saint" |
#17 (permalink) | |
Two Wheel Fun Runner!!!
![]() Join Date: Apr 2006
2007 Candy Cardinal Red and Metalic Titanium Go Nad Patriot Guard Member #114281 |
#18 (permalink) |
The Cobra "Fattys" on the 1600 do not hit before the floorboards. Dropped the bike a few times and the floorboards have always caught it, no damage to the bars.
- Rich 2006 1600 Classic Member CORVA, BRC Patriot Guard Rider |
#19 (permalink) | |
jerkybear's Vulcan
I was also forced out of my lane and during the avoidance maneuvers, hit the crash bars. I have yet to hit the floor boards. Just my little story. But they do look good on my LT. Craig
My God Jim, I think he's a Vulcan Craig Clakley 07 Ebony and Galaxy silver 900 LT Debaffled PGR |
#20 (permalink) | |
Patriot Guard Rider
![]() Join Date: Mar 2007
I have dragged my boards many times. My bars are scratch free. |
| Thread Tools |
