LinkBack | Thread Tools |
Turtle Wax Taster
I installed kuryakyn Led's as my rear turn signals with a run turn controller. They flashed a little fast so I plugged in the load equalizer to the run turn controller and everything was fine. I have since installed Kuryakyn turn signal mirrors. I wired them up and its making all of the signals flash really quickly again although they all work. I have not installed the supplied load equalizer for the mirrors. I thought that the one I installed for the taillights should have taken care of the entire system but I guess I was wrong. I can access the wires that controll the front turn signals in the headlight. Can I wire the load equalizer here or should I wire it under the seat? If so which wires do I tap. The load equalizer has two violet wires and a black one. The front turn signal wire colors are blue for power, green is the flash turn, and black is the ground if I am stating their fuctions correctly. The instructions are for a Harley not metric so they really don't help.
Sick & Twisted Moderator
wish i could help 04 - i just had a buddy install those on a sportster
and they would'nt pull enough juice to blink - just came on faintly he added a box to fix the problem and its fine now
2004 - 1600 classic 1997 - 1200C harley sporty 1985 - 750 Honda Shadow VROC# 20171 Chromaholic #512 |
Cruising In Fourth Gear
I plan to do the same run/turn/brake controller mod to my Vulcan 800B w/ Kury large silver bullets. Can't work it until I've got the $$$ to get the holes in the fender fixed (and maybe add some ghost flames eh?).
In the meantime, I've side-mounted my plate. I've got a lighted frame for it but no installation instructions. There appears to be a hot wire with one of those "piggyback" splice connectors and a ground that can be placed anywhere. My question is this... where should I connect in so that the frame works like a running light without having to move it later when the r/t/b gets installed? [sigh] Maybe I should just drive with a dark plate until I do the r/t/b mod?
FOR SALE: '01 800B, candy red/gold, V&H SS, Dragon II air & ket kit, etc. |
#4 (permalink) |
Turtle Wax Taster
Pick. On my 04 Streak I also installed a side plate. The one I removed had two wires a h0t and a ground. Most lighted plate frames have two wires. Find the two wires that are running to the original license plate bulb and wire it there. It should have no affect on the run turn controller.
I installed the second load equalizer under the seat of my bike and it brought my lights back to the original flash speed for the Kury LED Mirrors I installed.. ![]() |
#5 (permalink) |
My stock license plate was lit by a clear (non-red) portion of the tail/brake light lens. Therefore, no separate wires for the old license plate light.
| Turn signal mod w/ pics | rbentnail | Projects and "How To" Write Ups | 9 | 10-03-2007 09:30 AM |
| Corroded Turn Signal? | kobender | Kawasaki Streetbikes/Sportbikes | 0 | 10-11-2005 03:08 PM |
| Turn signal failure, can't find the problem! | ridenagain | Kawasaki Cruisers | 5 | 08-24-2005 01:27 PM |
| Kuryakyn signal mirrors on the way | woodsie831 | Kawasaki Cruisers | 6 | 08-01-2005 08:49 PM |
| kury turn signal mirrors | woodsie831 | Kawasaki Cruisers | 2 | 07-29-2005 05:25 PM |
