LinkBack | Thread Tools |
I miss you, Deron
![]() ![]() Join Date: Sep 2004
I've been trying to do some research on this. I can't get to my bike right now without a lot of trouble (I'd have to move three bikes around the garage), and I can't find anything in my service manual to answer my question. I'm hoping that someone can help me.
Does my 2002 1500 Classic FI have any factory-installed accessory connections? I read in another thread that some of the later-model Vulcans have them (two places mentioned were under the seat next to the battery and under the tank near the speedometer). I want to hook up a power outlet to my bike, not just for accessories but also to run a trickle charger, without having to hook it up directly to the battery. And I'd much rather tap into a factory-installed connection than have to run wiring from the battery itself. Thanks in advance for your help!
In memory of my friend Deron Harden. Life isn't going to be the same without him. |
#2 (permalink) | |
Try Ex tri ca tion
Gadget was able to tell me how much wattage my 1600 put out at 3000rpm. He can probably answer your question. http://www.gadgetjq.com/gadgetsfixitpage.htm
Slow Down |
TEXAS PATRIOT GUARD
Hi Julie,
I used the extra connections inside my headlight to install a cigarette light on my handlebars. Have used my GPS on it and I have my radio module hard wired into the headlight too. So far no fuses blown, all works well. You might even be able to rig up a plug in for the battery tender thru the cigarette lighter recepticle. Wayne Night Flight
Blue/Silver 2005 Nomad VROC # 17291 Phat II Risers AM/FM CD MP3 Garmin GPS Midland CB |
#4 (permalink) | |
Rebel Rider
Julie, as far as I know all the 1500 Classics have the connections under the seat, under the tank at the front, and in the headlight. I know my 05 has one under the seat on the left side next to the frame.
..... bluestringer 2005 Vulcan 1500 Classic FI V&H Longshots VROC #13910 GAVROC #159 |
#5 (permalink) |
Ahhh Crap
bluestringer is correct and if you remove the seat you'll see the one down in the wiring mess right next to the battery. If you don't have the stock air box you may be able to get to the one under the tank. The 1500 Classic has a very healthy electrical system and will run accessories galore.
Steve 2003 1500 Classic VROC 11660 RB 139 |
| Dumb female question | jukief | Kawasaki Cruisers | 39 | 09-23-2006 09:43 AM |
| zx6rr power commander/idle question | psycho_drama | Kawasaki Streetbikes/Sportbikes | 2 | 08-07-2006 04:55 PM |
| Dumb Question a from Newbie | rccnh | Kawasaki Cruisers | 2 | 05-21-2006 05:28 PM |
| Dumb question | tardster | Vintage Motorcyle Info | 8 | 06-28-2005 01:49 PM |
| Dumb question about replacing bulb | jukief | The Mechanics Corner | 5 | 06-04-2005 04:25 PM |
