Old 01-27-2007   #1 (permalink)
REFUGIO
REFUGIO's Avatar
Default Aiming the Lightbar Lights
Well...Another mod installed'
Installed my Cobra Lightbar last nite.It really looks good.
I upgraded to 55watt bulbs before I even installed it. It came with 25 watt bulbs. Man...those suckers are BRIGHT. The power source I used for the lights was from the aux lead inside the Headlight housing using a relay that is powered from the running lights. The lights come on as soon as the key is on. However they can be turned off as I also used the supplied switch.
Anyway.....What about aiming them (up and down)? Pulled up to the garage wall and stood the bike up level. What should I do?
Lights are now aimed higher than low beam but not quite as high as the high beams. Almost don't even need to use the bikes high beam. Seems to me that they may still be somewhat a annoying to oncomming cagers at night.I might have them aimed a little too high.
Where do most of you guys aim your lightbar lights?
On another note...Anybody ever crack their Lightbar lenses from running 55watt bulbs. They are kind of warm/hot when on for a while and sitting in the garage. Seems you could be riding along with the lights on and then all of a sudden....A little rain shower or something. My concern is a hot lense and then hit with cool rain water may crack em. This ever happen to anyone. Used to happen to me with cheap fog lights on my truck a while back.
Pictures at a later date.
2008 VULCAN 1600 NOMAD
REFUGIO is offline   Reply With Quote
Old 01-27-2007   #2 (permalink)
SirWilhelm
Another AARPr
SirWilhelm's Avatar
Did you put in the brighter bulb in the regular headlight, also?
Geez, you would have a spot light if you have the 85W low beam, and two 55W beside it. Don't let the animals or small children walk in front of it, they may get a tan or singed hair!
I remember my first HD had problems with the bracket for the headlight and I would be half way home from work and would have to get a rag to lift it up, and not burn my fingers, so I could see to get to the house. Didn't know about lock tight back then. Never worried about cracking the lens when it rained on it, just how hot the danged rag got before I could make it to the house.
Is the light bar with pedestal style lamps or are they hanging below?
Bill in SJT
2006 Vulcan 900LT
Ride long and prosper, young Vulcan.
Patriot Guard Rider
WB5ZAM
SirWilhelm is offline   Reply With Quote
Old 01-27-2007   #3 (permalink)
Desoto
667 Neighbor of the Beast
Desoto's Avatar
Send a message via MSN to Desoto
I adjusted mine excatly the same way you did yours but I have 35w bulbs. And they annoy some automobilists but at least, they see me coming. For them it's a little inconvinience but for me, it's my security. Since yours are 55w, you could adjust them a little lower.
Don't go where the path leads you, instead go where there is no path and leave a trail
Desoto is offline   Reply With Quote
Old 01-27-2007   #4 (permalink)
REFUGIO
REFUGIO's Avatar
Bill in SJT
Yes...I also have the 80/100 watt inthe headlight.....Got some serious light going on here.
The cobra bar I got has the pedestal style...They look good!!!!!
Blinkers go off to the sides. Did not think I would like the blinkers that way...but after the install,I now think they don't look too bad.
Old 01-27-2007   #5 (permalink)
Cabo
Can't find time to ride
Cabo's Avatar
If you look on Gadgets site there is a write up on how to adjust your head light, most are off from the factory, using the method you can set your headlight then the others a little lower and it works great.
http://www.gadgetjq.com/aimheadlight.htm
Cabo is offline   Reply With Quote
Oil and Temp lights stay on after starting... theweasel Kawasaki Cruisers 36 08-05-2006 11:51 AM
Is Yy Lightbar Causing Alternator Problem? ppark Kawasaki Cruisers 11 05-28-2006 11:06 AM
CWI Driving Lights, Part 2 NY_Guy Kawasaki Cruisers 9 08-08-2005 04:45 PM
F&S Lightbar Update RampRat Kawasaki Cruisers 4 05-16-2005 08:32 AM
F&S lightbar on 05 Nomad? centerpunch Kawasaki Cruisers 4 02-23-2005 06:31 AM
