Old 06-27-2007   #81 (permalink)
joe41
Finally Got Into First Gear
Default teething problems
Have A 07 900lt Kaw, 1800 Miles On It Now And So Far Have Had The Gas Line Blow Off, Severe Drive Belt Noises, Sounds Like I Have A Flat Tire Some Times. Back Fires When Strarting Engine When Hot, Back Brake Grinds When Applied. Vibrates After 60mph. . Thinking Of Dealing It For The New 1300 Yamaha In 08. Have Owned Lots Of Bikes But This One Is Annoying Me.
joe41 is offline   Reply With Quote
Old 06-27-2007   #82 (permalink)
chukster
drgus are bad, mkay?
chukster's Avatar
If you've owned that many bikes, then you ought to know that no bike is perfect and that there are fixes for just about everything.
2007 HD Electra Glide Standard
07 VN900 Custom - sold
chukster is offline   Reply With Quote
Old 06-27-2007   #83 (permalink)
joe41
guess i have been lucky, i have owned at least 20 motorcycles and have never had any bike give me so many problems in such a short time, but on the brighter side #22 bike in the near future.
ride safe
Old 06-27-2007   #84 (permalink)
zphreaky1
Kev in Phx
zphreaky1's Avatar
Well don't buy anything else from that dealer.
Kev in Phx.
'02 Meanie w/lot's-o-tasties (just a frame, motor, wheels, forks, swing arm now)
zphreaky1 is offline   Reply With Quote
Old 06-27-2007   #85 (permalink)
joe41
Default dealer
Will Not Be Buying Any More Bikes There As They Do Not Sell Yahamas
Old 07-01-2007   #86 (permalink)
psychosematic
psychosematic's Avatar
This is just a hp and top speed run on a trailer.
2007 1600 Nomad additions:
V&H Baggers
RED: 1st Run: 56HP 4th gear
GREEN: 2nd Run: 57HP 4th Gear
Blue: 3rd Run: 137 top speed 5th gear
-psychosematic VROC #24194
Black & Chrome 2007 1600 Nomad "BEEFY"
Cruisercustomizing.com
psychosematic is offline   Reply With Quote
Old 07-06-2007   #87 (permalink)
Trent257
Trent257's Avatar
just got the my bike jetted and tuned after adding hard krome pipes and dual hypercharger intake.
56.8 max hp and 80.4 max torque
anyone know the stock numbers for my bike?
anything i can do to increase these numbers, i was looking at a dyna 2000 ignition kit???
adam`
1994 vn1500a
Trent257 is offline   Reply With Quote
Old 07-06-2007   #88 (permalink)
Arkainzeye
DR#001
here is a whole bunch of dyno charts!!!
Thunder Mfg Online - Dyno Graphs
chris
Arkainzeye is offline   Reply With Quote
Old 07-06-2007   #89 (permalink)
zphreaky1
Kev in Phx
zphreaky1's Avatar
I don't have any exp. with the dyna's on a 1500 all the 15's I have had were fuel injected. You can always open it up though!
Kev in Phx.
Old 07-07-2007   #90 (permalink)
arbburn
Al
Default 2006 Nomad, Barons BAK, V&H, PowerCommander III
The blue line is with the PCIII 003 map (roadhouse and hypercharger) after installing the BAK. This map was recommended by DynoJet as a starting point until I could get the custom map developed.
The red line is with custom map.
End Result (Attached):
Max Torque: 89.5
Max HP: 67.5
Nice fairly-smooth curves.
arbburn is offline   Reply With Quote
Old 07-07-2007   #91 (permalink)
psychosematic
Max Torque: 89.5
Max HP: 67.5
What kind of bike?
Old 07-07-2007   #92 (permalink)
arbburn
Al
'06 Nomad.
Old 07-07-2007   #93 (permalink)
psychosematic
'06 Nomad.
I see that you just did the custom map today. Would you mind coming back and posting what your avg mpg is after a few tanks? I plan on doing the caddmann mod instead of the BAK. Which BAK did you use?
TIA
-Josh
Old 07-08-2007   #94 (permalink)
arbburn
Al
Josh,
I used the BA-2070-06 (Comet). If you look in my profile you should be able to make out what it looks like. If not, I'll post some pics of the left and right side.
The caddman mod is pretty cool. I think both the BAK or the caddman mod will supply more air than the 1600 could ever need (IMO). For me, I just really like the look of the BAK. I know some folk want the symmetry (something on the L and R sides of the bike), but I really like mine open. Also cutting out the crossover is a "no going back" kind of move.
Later,
Al
Old 07-15-2007   #95 (permalink)
BikerBeagle
Giggidy-Giggidy-Goo!
BikerBeagle's Avatar
I had my bike dyno-tuned last week. I don't have the results scanned in, but here they are:
2007 Nomad 1600
Odometer = ~1000
Caddman Air Mod (both sides, dual K&N filters)
B & H Baggers Exhaust
PCIII USB
First Run
(using Thunder Air/V & H Bagger PCIII map)
Max Power = 63.36
Max Torque = 76.94
Run Conditions: 91.46F, 28.80Hg, Humidity 30%, SAE 1.05
Last Run (after mapping)
Max Power = 65.67
Max Torque = 82.51
Run Conditions: 92.89F, 28.81Hg, Humidity 28%, SAE 1.05
I'm not sure how to read the air/fuel graph, but it shows a pretty much straight line across the graph at 13.56. Rev limiter seems to be at 5800rpm.
I know my numbers aren't all that impressive compared to some, but I had the guy "split the difference" between mileage and performance (he can apparently calibrate for max mileage or max performance ...I think it has to do with that air/fuel ratio). The dyno tuning center I went to was coincidentally 163 miles away, so I can say that I got 27mpg on the tank going there and 37mpg on the tank coming back.
I'm not getting any 'neck-jerking' power difference, didn't want to and wasn't expecting to. The real difference, for me, is in torque. It feels like I'm sitting on top of a Mack truck now. More than anything else, though, the whole acceleration range has been smoothed out ...I really can't describe it any better. That, and the increase in mileage, makes the whole thing well worth the money spent.
Word of advice/caution: I would not use any of the Thunder Mfg PCIII maps on a long-term basis. I had my concerns before, but the dyno proved that those maps are dumping gas by the bucket load in the lower rpm ranges. On more than one occasion, the guy who dyno'd my bike mentioned this ...places where the map was calling for high 20s/low 30s increases in fuel when the dyno showed only single digit increases needed.
Really, the best process is to use the "completely stock' map for your bike and get it custom tuned. Using one of the Thunder maps long-term can be harmful to your engine, imho.
BikerBeagle
2007 Kawasaki Nomad 1600
A biker knows why a dog sticks his head out of a car window.
BikerBeagle is offline   Reply With Quote
Old 07-18-2007   #96 (permalink)
LordGT
Millenium Vulcan Pilot
LordGT's Avatar
Send a message via AIM to LordGT
Talking Millenium Vulcan's Dyno
Here is the Before/After Dyno chart from my V2K, The Millenium Vulcan, Debadged. Now she REALLY shows off the Blue color...
Member of (Todd's V2K Custom Temptress Club) TV2KCTC #1
2006 V2K LTD
LordGT is offline   Reply With Quote
Old 07-18-2007   #97 (permalink)
runnerb0y
runnerb0y's Avatar
Anyone know of a reputable and proficient Dyno shop anywhere in NW Oregon (within 50 miles of Portland)?
After my pipes and PC III USB mods, I've really lost the low end and my mileage has suffered a bit. The bike ('06 Meanstreak) really pulls my arms off in the higher RPMs but has lost a noticeable amount of torque.
'06 Meanstreak with some personal touches
Historic Balch Hotel
runnerb0y is offline   Reply With Quote
Old 07-18-2007   #98 (permalink)
LordGT
LordGT's Avatar
If you go to the Power Commander website, they have a link to find a Dyno shop near you. That is how I found the shop I went to.
2006 V2K LTD
Old 07-18-2007   #99 (permalink)
runnerb0y
runnerb0y's Avatar
LordGT: Thanks for the advice! I've been to the PC Website and they list one right here in the small town of Hood River where I live. However, I've asked around and some people say the guy there doesn't know what he's doing.
I was hoping to find someone on the Forum that has had some dyno work done in or around Portland, Oregon, and could vouch for the quality of a particular shop.
Old 07-19-2007   #100 (permalink)
sureshot
sureshot's Avatar
Send a message via Yahoo to sureshot
I am thinking of a new bike.
1600
THE BIG Valcan 2000 ,
I like LOrdgt bike.alot.
I like power,and wonder if I would kick myself if I got the 1600.
WHAT YA THINK VuLCAN dudes.
What kind of gas milage is the big 2000 getting ?
Last edited by sureshot : 07-19-2007 at 01:08 AM. Reason: thinking of new bike next year.
sureshot is offline   Reply With Quote
