#143 (permalink) |
bigmacholdthefries
I have a 900 custom with the Barons BAK, pipes and the pcIII,i'm running the advanced maps that are accessable from the Powercommander website ,shes of to the tuner on Tuesday to have some custom maps made so i will post the results Wednesday cheers
#145 (permalink) |
bigmacholdthefries
Here is the dyno results for my 900 custom (pipes pcIII and barons bak)i don't know how clear the pic will be but the figures read max hp = 51.71 max torque = 57.25 ,the guy doing the tuning was surprized at how rich the 900 was running
#146 (permalink) |
Wants better weather!
Thanks for posting a 900 with all three mods, air/EFI/pipes. I am assuming that the dyno you posted is the "corrected" version since I do not see any references to humidity/elevation, etc. I am surprised that you did not post the sheet that shows the air/fuel. And since you have the PCIII that they did not adjust it to bring it more to their liking. But then again the curves are pretty steady and leaning the air/fuel may not have improved performance. Did the tech say anything about that?
So it looks like adding the EFI ($300) and pipes ($400-500) added 3 more hp and 3 more lbs/torque compared to just adding a BAK. Well you just confirmed that is $800 I don't need to spend.... The dyno for my bike also showed it running a little rich but not enough to hurt anything and checking the plugs 700 miles later confirmed that. Compared to my posted dyno is your 900 running richer? Last edited by rod2625 : 03-12-2008 at 12:16 PM. Reason: typo |
#148 (permalink) | |
bigmacholdthefries
The bike feels very strong through its rev range now,maybe its me trying to justfy the $$ spent but she does feel very good,all in all very happy |
#149 (permalink) | |
Bishop's Performance - Dyno Info Again thanks for posting. In this thread we now have a dyno for a stock VN900, just a BAK (& Scootworks pulley), and yours with BAK/EFI/pipes. It gives folks something to think about. |
#151 (permalink) | |
McVulcans bike has all new BAK/EFI and pipes, I have no idea what EPA stuff would be there. Also bluemeanie's 800 showed lots of HP but he did not post the torque. I suspect that is the downside of his bike. HP is just lots of rpms. |
#152 (permalink) | |
![]() Join Date: Oct 2007
But its what i got and i enjoy it thouroughly. Kinda wished id never stumbled in to this thread though! Oh well thanks for the info. post all the dyno charts you guys want i for one will not be back to this particular corner of the forum! too disapointing.... |
#153 (permalink) |
Third Gear And Gaining
One more 900 Custom dyno to add to the mayhem. This one is the Custom with a Thunder Mfg. Teardrop Air Intake and a PCIII run in 4th gear. Corrected output as follows:
Max Power - 50.42 Max Torque - 53.09 I'm using map #1 from the Dyno website. The tech said I could do some minor tweaking to smooth out the curve a bit but it wasn't necessary as the air/fuel ratio seemed decently in order (sorry, no visual posting for that). Beyond that, I'm not gonna be able to give you too much more info. Kawi 900 Custom 30March2008 (Thunder Mfg. Air Intake, PCIII Map 1).pdf |
#155 (permalink) | |
This also confirms to me that bang for the buck, of the three, air/EFI/pipes, changing out the air intake provides the most performance increase. |
